HSTuning
Most of the MK5/MK6 chassis cars coming through the shop recently have had signs of subframe movement. You can see in the picture above that there is an area where there is no red paint on the chassis. This, combined with clunking that usually happens when changing directions are the most obvious symptoms of this problem. We put together a little kit to eliminate this issue. It includes 4 new bolts, and 2 shims. The shims were originally designed for the Passat, but we've had great luck using them on all MK5/MK6 chassis cars. This kit eliminates the wasted shank bolts, and replaces them with a stronger bolt from the B5 chassis cars. We've used these on the cars that get used for autocross and road course and it completely eliminated the movement.
Follow this link for more information, and to purchase:
http://www.hstuning.com/product_info.php?products_id=3607
