There were comments about bulbs not fitting into HID Projector housing, so I did some testing, I tried an OEM Osram D2S bulb, 2 aftermarket bulbs including the ones I'm including in my HID kits, as well as the H7 bulb.
The results were they all fit, the OEM Osram bulb fitted the best, the other aftermarket bulbs needed a small push to get them in. No trimming or anything unusual was necessary.
It's important to get the notches to line up, or they just wont fit. The black cover went on top and twisted into place without issue.
The H7 halogen bulb I managed to get in as well. Have a look at the photos.
Just wondering, and this may have already been answered but can I rewire these to work with my OEM bixenon bulbs? I love the R black housings!
Ordered a set of lights and morimoto kit from TRS. The lights from ed shipped, but the can bus harness in the hid kit is backordered.
Is it worth installing the headlights when they arrive using my stock halogen bulbs, or would I be creating extra work for myself? Is it easy to install the hids with the lights already on the car?
Or should I ask TRS to split ship, and install the hids now without the can bus harness or relay? The 3five ballasts state they have canbus/ error canceling built in, so it seems the can bus harness could be redundant.
And can anyone tell me if you would need extra hardware wiring to install without the harness? It looks like the bulbs come with a redundant harness with spades -> 9006 that you could use to connect the factory h7 harness to the ballast input. So you would be running the factory harness directly into the ballast, and the ballast directly to the d2h bulb. It would certainly make for the cleanest install without the huge relay or can bus box.
Thoughts? Or should I just be patient and wait an extra 2 weeks to install?
Sent from my Galaxy Nexus using Tapatalk 2
Sun went down and I just went out to check the cut off. Looks good. Didn't even mess with it. I will do final adjustments after I install hids. Just wanted to make sure I wont be blinding anyone in the mean time. Wont take much to fine tune.
The halogens look really good in there. I don't notice any difference, better or worse, over the stock housing regarding output. Not sure I will gain much from the HID kit. If you are doing it as a cosmetic mod the HIDs are definitely optional. Besides the bulb temp, projectors look like projectors whether they have halogen or xenon bulbs. The projectors even give the halogens that rainbow effect at the cutoff.
Not crazy about the LED city lights. They are very blue compared to the halogen bulbs. Anyone know the temp? 6000k? Are they accessible/changable? I will probably vag-com them off if I can. Or just use them as DRLs. They don't look good contrasting the yellower light. And I'm getting 4300k morimoto 3fives so I don't reckon that will be too different.
Yea i tried vag-com and no luck and with the parking light bulb i have looked all over and nothing other then a circuit board with 2 wires solder.
