http://www.hgp-turbo.de/golf-vi-sonderumbau.html
Special Conversion Golf VI R
Special Conversion Golf VI R with R36 Turbo engine / 530HP / 700NM / 6-speed DSG
Special Conversion Golf VI R with R36 Bi-Turbo Engine / 745PS / 925NM / 7-speed DSG
On 3.6L bi-turbo engine with an output of 745PS / 925Nm with 7-speed DSG transmission from Audi RS3 (for hand control not possible)
Consisting of:
2 exhaust manifold with length and molded exhaust housing (surge charging) from Nickelguß
2 HGP R28 turbo compressor housings with cast
Compression reduction by steel intermediate plate and piston machining
Exhaust down pipes on 2x88mm 2x70mm
Large-volume aluminum intake tube with additional MPI nozzles
2 large volume intercooler left and right in the wheelhouse
High-quality silicone suction u. Pressure Hoses
Modified engine control unit
Changed FSI high pressure pump
Additional fuel system
Stainless steel exhaust system on 1x88mm 2x70 (original tailpipes in optics)
Reinforced DSG eight-plate clutch
Changed DSG software
Boost pressure, oil temperature and digital speed display in the original speedometer instrument
Change the vehicle's electrical (engine harness)
R36 engine (new or used available)
7-speed DSG gearbox (new or used available)
Specifications and Prices
Power: 745 hp / 548 kw
Torque: 925 Nm
Price incl.: On request
http://www.hgp-turbo.de/tl_files/fahrzeuge/golf_6_r/Golf6r20.jpg
