Old 09-25-2012, 09:26 AM   #1
-yz-
-yz-'s Avatar
Drives: Golf R
Clutch Garble?
I'm hearing this freakish garbling noise coming from under the left/middle side of the dash every time the clutch is pushed in a few inches. More evident when I'm upshifting. I've confirmed I only hear it when the clutch is being engaged.
Anyone know what this is? Soundaktor? Car shifts fine otherwise, been like that since I took delivery.
-yz- is offline   Reply With Quote
Old 09-25-2012, 05:17 PM   #2
JettaRacer
Drives: 2012 R, 2011 335ix, 2010 R8 V10 etc
Does it sound like a pop can getting crushed under your foot? My car did that. It goes away once all the parts learn to work with each other.
JettaRacer is offline   Reply With Quote
Old 09-26-2012, 11:56 AM   #3
-yz-
-yz-'s Avatar
Drives: Golf R
yea, I can feel a very slight rumble under my foot too, when the clutch is pushed in about 1/4 of the way at the engage point. The whining/gagging sound under the dash is what's noticeable. How many miles on your car? I've got 1500m.
Old 09-29-2012, 04:44 PM   #4
ilimit
Drives: 2012 VW Golf R
I'm almost at 1k and it still does that sometimes -_-
It was more noticeable during the beginning.
ilimit is offline   Reply With Quote
Old 10-08-2012, 11:47 AM   #5
JettaRacer
I've got. 5500kms on my car now. It now only has typical clutch sounds on engagement. The crunchy sound disappeared after about 800km after I did a number of drives during which I just changed gears repeatedly, probably every 20 seconds, during a 45 min drive around town to get the parts to all break in together. It has been smooth as butter ever since. There is a click near the top of the travel of the pedal motion but that is normal for the pedal assembly.
Old 10-08-2012, 11:49 AM   #6
svickstc
svickstc's Avatar
Drives: Nike 6.0
how many miles on it, could it be Throwout bearing going already?
|Nikon|
Old 10-08-2012, 03:29 PM   #7
-yz-
-yz-'s Avatar
Drives: Golf R
I've got 1,600 miles on my car now. Still does what I described. Shifting response and everything still feels ok though. Doesn't feel like something is broken. But it is noticeable.
Old 10-09-2012, 12:50 AM   #8
hifichip76
Drives: MkVI GTI, 350z, Mazdaspeed 3
Hmm. I think that might be the same thing I just started a thread about. I only have barely 500 miles on mine. Nice to think it will go away as it breaks in. How many miles before yours got better?
Love the car otherwise.
hifichip76 is offline   Reply With Quote
Old 10-09-2012, 09:55 AM   #9
TimS
Drives: '12 Golf R
New parts need some time to bed into each other. Sometimes it happens right away, sometimes it takes a while. My brakes were noisy at first, my gearbox is still a little tight (that's what she said!), and my clutch chatters a bit (I just passed 600mi). Give it some time, and everything should sort itself out.
Just make sure you let everything warm up to operating temp before you push the car, and remember: These parts wear in faster the more you use them, so go for a drive (like you need to be told that)!
Old 10-09-2012, 12:25 PM   #10
JettaRacer
^ what he said.
My clutch noise at first really concerned me. Once I did my break-in drive the strange 'gritch' sound is completely gone. Regular driving will not likely make the 'soft drink tin can crushing' sound go away. You really need to go through a lot of shifts with a warm car to get the pressure plate and throw out bearing to mate. That is my suspicion about that particular noise. When I first had the noise and feeling in the clutch, I felt like my 8 year old clutch on my Nissan 200SX SE-R with a baked and dried out throw out bearing, so I was a bit worried. So as I said, I just drove the car around town for an hour just going up and down through the gears. Just shifting constantly. No hard driving, just regular traffic speeds, but just changing my gear every 15 seconds.
Old 10-09-2012, 06:53 PM   #11
-yz-
-yz-'s Avatar
Drives: Golf R
^ what he said.
I was messing with what's causing the noise again today. If I depress the clutch in while car is moving and put it in a point where it's 1/2 engaged... ONLY when I hit the gas is when I feel a little vibration under my clutch foot and when the sound happens. Is that still consistent with you other guys?
Also, it does seem to go away after about 5miles or so of driving.
Old 10-09-2012, 08:10 PM   #12
Carbon-13
Drives: 2013 Golf R
Mine is definitely noisy when cold. 1st to 2nd shift depress of clutch is very loud and clanky until warmed up. My S2000 was the same way with a little notchiness between 1-2 shift for the first 5 minutes and then was smooth as silk. One of the things that played a part in my decision to want to look at the R was the magazine write-ups which praised such a smooth transmission. I can't say that I totally agree with them. While it is a nice 6spd trans, it falls quite short of expectations of someone like me who came from a previous S2000 6 spd car known for having one of the best manual gearboxes in the industry.
Carbon-13 is offline   Reply With Quote
Old 10-15-2012, 04:00 AM   #13
keisuke_z
Drives: 2012 Golf R CSG
Hey when you say "click" - do you mean the feeling of the pedal popping into place? If so, that's actually not correct - I had my clutch pedal assembly replaced under warranty because of an ill-fitting part...
keisuke_z is offline   Reply With Quote
Old 10-17-2012, 03:08 PM   #14
-yz-
-yz-'s Avatar
Drives: Golf R
Mine clutch pedal is defenitely not 'notchy' and doesn't 'click'... it doesn't make any noise when it goes up and down actually. fyi.
