Old 01-28-2015, 06:04 PM   #57
Pyotr
Pyotr's Avatar
Drives: STG2+ R, MK6 JSW
Mounted up my bar today, it fits perfectly, but unfortunately, i need to move my license plate. damn state laws! Due to the way the bumper is designed, i would opt for a 24" or larger bar the next time, since the bumper slopes in towards the middle where i bolted mine on.
I bolted my bar to the bottom to the bumper, note: if you also do this USE A CARBIDE DRILLBIT. it took me an hour, and a broken bit to finally break down and go get one.
Still working on wiring, but ill post up some images when i finally get the relay installed.
EDIT: wiring is on hold. found a wiring diagram for the car... and i have no bloody clue where to hook in, so im going to cascade two elays, so that the light turns off with the ignition switch
Pyotr is offline   Reply With Quote
Old 01-28-2015, 09:34 PM   #58
Fantasiamon
Originally Posted by Pyotr View Post
my fogs are my DRL's so i wouldn't want this blinding everyone as i drive around normally! i have a euro switch, and i was playing with the idea of using the rear fog switch as the switch for the light bar.
I was thinking along the same route. Rear fog for potential lightbar.
Sent using TapaTapaTalkeeTalk
Fantasiamon is offline   Reply With Quote
Old 01-28-2015, 10:21 PM   #59
Pyotr
Pyotr's Avatar
Im going to settle on a centre console switch, from CarStyle4you, specifically this: http://shop.carstyle4you.com/product...off-cover.html
since i dont have access to VAGcom coding to enable my rear fogs, this is the next best thing for me. someday i may switch it (pun not intended!) but i think this setup will work well enough for now.
Old 01-30-2015, 04:58 PM   #60
Pyotr
Pyotr's Avatar
Finished my install! pretty happy with the end results, need to aim it properly though. i do wish it was brighter though.
Finished wiring. Relay is a HELLA weather proof relay and matching harness
For now, its just switched with a simple switch until i get my proper one. i want this to look as OEM as possible
End result
yes, there are holes in my bumper from removing the plate, working on filling those is next.
EDIT: so after doing some nighttime driving, im really happy with the bar i installed. while headlights are more directed, this illuminates more around, especially the sides of the road. since i live in an area heavily populated with deer, this is very nice! right now between high beams and the LED bar, i can light up buildings from about a quarter mile away
Old 01-30-2015, 06:47 PM   #61
Looks pretty sweet.
Old 06-12-2015, 12:20 AM   #62
MK6 Will
MK6 Will's Avatar
Drives: 2011 Volkswagen GTI
Originally Posted by kwalton View Post
I did a little 12" led light bar in the grille and I love it. I could have done the 18" or 24" but my shop didn't have them in at the time. It works great on the backroads especially on foggy nights.
You can kind of see it here.
That's the setup I was thinking of trying. I'm still reading through the thread and it may be answered here soon but any concerns about the heat from that light affecting the intercooler?
MK6 Will is offline   Reply With Quote
Old 06-12-2015, 12:28 AM   #63
MK6 Will
MK6 Will's Avatar
End result
Looks good
Old 06-12-2015, 01:38 AM   #64
Andrew429
Andrew429's Avatar
Drives: 2011 GTI 2-dr
Originally Posted by 1PURDYmk6 View Post
That's mine!!! My friend just stumbled across this thread. I know I'm a little late to the party, but if anyone has any question, I'd love to answer them.
I kinda want to do this when I get a ski rack when winter comes again. That would be great on the drive back from the ski resort since the highway is pitch black with no street lights. Is there any other way of getting the wire inside the car if it's mounted on top instead of going through the door? Or I'll just mount one in the bumper? Does the light bar in the bumper illuminate farther down the road or is it just like the fog lights?
APR Stage 2 | APR Stage 1 & 2 Intake | Southbend Stage 3 drop in disc | USP Downpipe | RS3 Bushings | Vag-Com Tweaks | 35% Tints | Depo Headlights | OEM LED Tails | Stock Cat-back w/Aero Resonator |
Andrew429 is offline   Reply With Quote
Old 06-12-2015, 06:04 PM   #65
goose
Drives: Stage 2 GTI
sent via carrier potato
WHAAAAAAAAAAAAAAAAA TSUTSUTSUTSU
goose is offline   Reply With Quote
Old 07-28-2015, 05:17 PM   #66
SeanR
SeanR's Avatar
Drives: 2010 GTI BLK
If you are looking for better lighting at night a LED light bar is a must. I just mounted my 20" V2 light bar from www.briteniteled.com on my GTI. The install was pretty straight forward This bar is simply amazing the qualty is top notch and the customer service is great from Briteniteled.com. I will post up pics of the install and the bar at night. .
Pm me if you need any Vagcom coding in Bx, BK, Queens
SeanR is offline   Reply With Quote
Old 08-27-2015, 02:00 AM   #67
MK6 Will
MK6 Will's Avatar
So I forgot to post these when I finished but here's the finished product.
Sent from my SM-G920V using Tapatalk
Old 08-27-2015, 11:19 AM   #68
Looks good but I think you lose some cooling.
Old 08-28-2015, 05:55 PM   #69
MK6 Will
MK6 Will's Avatar
Ya, I thought about that too. I'm not worried about it cooling at night when I'd use it just because of the cooler nights but it still blocks some some stuff. I haven't had any issues with overheating but I'm not too sure how to tell if I get heat soak or not.
Drive it like you stole it
Old 09-10-2015, 02:34 AM   #70
MK6 Will
MK6 Will's Avatar
I took it on the track today. It was 92 outside and after driving it hard it didn't seem to make it run hotter. But if I'm getting heatsoak, I don't know. I'm not sure what the symptoms are of it here's some more pictures of it
