Old 10-13-2012, 04:12 PM   #15
carsfeverguy
Drives: 2010 Gti
straight from Modshack's website
"On the Boxster, the calipers mount to the rear of the hub leaving the larger of the pistons as the trailing piston (the brembos have 2 sized pistons). If you do not swap the crossover tube and Bleed nipples to the opposite side of the caliper and then swap car sides, the larger piston will be the LEADING one when mounted in front of the axle. Simple fix. Racers say this could lead to a little pad taper. You'll also need to install some anti-squeal pads as the solid mounting leads to more noise with the Brembos.""
Basically this will lead to poor wear pattern of your pads as well as braking clamping force that is not as effective, diminushing the benefits of this great setup
Get it redone.
Old 10-13-2012, 09:52 PM   #16
candc8
Drives: 4 dr mk6 tdi
so will the squeal go away if i do the calipers correctly or would i have to still get the anti squeal pads?
candc8 is offline   Reply With Quote
Old 10-13-2012, 11:55 PM   #17
carsfeverguy
Drives: 2010 Gti
I have the squeal with them mounted correctly and with the antisqueal pads... I need to get Ceramic Pads to get rid of that. Then again, I abuse my discs with Racing compound pads every now and again when tracking, which probably doesn't help, even if I am using regular factory compound for daily driving.
Old 10-16-2012, 02:17 PM   #18
inc55
inc55's Avatar
Install the calipers correctly. There is a science to having one piston larger than the other. Get stoptech pads and anti vibration dampeners which cost 100 bucks for 4 and there shouldn't be any squeal. Don't forget to bed the pads in. If squeal still persists then perhaps new rotors should be used with new pads.
Old 10-16-2012, 02:23 PM   #19
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Sounds like a tedious process with an unsure outlook. This is what has kept me away from the Porsche upgrade
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 10-16-2012, 03:09 PM   #20
carsfeverguy
Drives: 2010 Gti
Grapes surely are sour when you can't reach them... Just saying.
This setup is so far superior to the setup you are running it's not even funny, I know because I used to run it. The only issue here is installing something properly with the correct components.
Old 10-16-2012, 03:11 PM   #21
grambles423
Limited Activity
There's no denying its a good setup, but what percentage has the issue? What all can go wrong, etc. etc. Most BBKs are a simple bolt on and bed procedure. This seems to have an after taste. If its really THAT simple, I'll definitely look into it again.
Old 10-16-2012, 03:53 PM   #22
carsfeverguy
Drives: 2010 Gti
Changing pads for track duty or otherwise takes 10 min or less...
Really the defining difference is the confidence and brake pedal feel.
Needless to say that with track pads and I also added titanium plates (to avoid boiling the fluid)the car was outbraking lap after lap m3s 1m coupes etc, especially at the end of the day where everyone was fading.
And let's not forget that 16 inch wheels still clear for the winter.
Old 10-16-2012, 03:59 PM   #23
Modshack
Modshack's Avatar
Exactly.....
Old 10-16-2012, 11:57 PM   #24
tman
tman's Avatar
Drives: around randomly looking for GTI's
I'm definitely running a similar setup. After looking at all the bolt on options that provide the same level of service, you can't have better bang for buck than with this setup.
Ebay has plenty of caliper options as well.
Steve, what would be the best place to find mounting hardware for these calipers to fit the GTI.
Terence
Website | facebook | twitter | flickr
2012 Golf GTI 'Serron' (UG)
tman is offline   Reply With Quote
Old 10-17-2012, 12:50 AM   #25
carsfeverguy
Drives: 2010 Gti
apikol or dieselgeek
Old 10-17-2012, 09:55 AM   #26
Modshack
Modshack's Avatar
apikol or Performance Diesel Engineering
Fixed that fo ya! This is the kit I have.
http://performance-diesel.com/index....aa2c914ec6ac36
Old 10-17-2012, 09:56 AM   #27
grambles423
Limited Activity
Good quality kit?
Old 10-17-2012, 10:21 AM   #28
carsfeverguy
Drives: 2010 Gti
Apikol
The site says 986, but they also fit 987 callipers that I am running
