Old 11-03-2017, 08:01 AM   #1485
GreyGti1990
Drives: 2011 Gti 4-door
I replaced my tensioner and cam bridge at 80k miles. left the chain and guides alone. Brought it to a Indy shop that specializes in German cars. $1,500 out the door; admittedly it was on the high side of the price spectrum but they do a great job.
Chains and guides to be replaced at 100-110k mile hopefully.
Old 11-07-2017, 01:42 PM   #1486
Tony48
Tony48's Avatar
For anyone interested ECS has the OEM Ultimate Timing Chain kit on sale for $451.23. You have to go to the "Build Your Own Timing Chain Kit" and choose all of the OEM options. This way it's much cheaper than $530.86 for the "kit" but you get the same parts. I just ordered my kit.
Old 11-09-2017, 06:28 PM   #1487
GreggGTI
Drives: GTI
Hey guys. Long time lurker, here now with a question.
2012 GTI 2.0 TSI, tensioner blew up on me! I didn't expect it, but it's gone. Happened on shutdown and now won't start. I feel like it's bad, definitely jumped some links. It's been to two shops and both of them threw hands up. Weak! Now I'm bringing it to a foreign auto shop for a teardown and quote. I'm not sure if valves are bent or not.
My question:
I'm a decent shadetree mechanic ('79 VW bus restoration). I have seen a lot of used motors for sale about $2K+. If the shop is priced around that, is there anything stopping me from pulling the bad motor and putting in a new one myself? Are there any serious hang-ups to taking out the old one and putting in a new one? Would I need to replace the turbo or should the accessories still be trusted in light of the timing jump? I have a one-car garage and some available time coming up.
Thanks guys
GreggGTI is offline   Reply With Quote
Old 11-10-2017, 09:03 AM   #1488
Dans GTI
Drives: 2010 MK6
My question:
Thanks guys
If you can get the new motor complete for $2k i'd do that if i were you. If you have the tools and ability to swap the motor yourself then you should do it, its a pretty simple car to work on.
Old 11-10-2017, 09:06 AM   #1489
nvturbo
nvturbo's Avatar
Got mine done (main timing chain, tensioner, guides, etc) the other day. Just have to go pick up the car tomorrow. If it wasn't such a PITA, I would have done the replacement myself and saved some $$$.
Old 11-10-2017, 12:09 PM   #1490
GreggGTI
Drives: GTI
Thanks man. I have a set of tools, but it's mostly average equipment. Nothing extravagant. An engine hoist, jacks and socket sets. Like you said, it's simple to work on. If it's a 'take out the old one, put he new one back in' plug and play job, I'm not scared at all. I intend to get one with accessories already onboard.
I've seen the list of compatible 2.0t engines from other cars, are there any absolute deal-breakers? Like I said, I need a plug and play option. I plan to use the existing ECU, will all sensors be the same?
Thanks a lot
Old 11-10-2017, 01:03 PM   #1491
nvturbo
nvturbo's Avatar
It's a bit more involved than you think. I've done all types of work from suspension to internal parts replacement to motor swaps and I didn't want to tackle the job. It's not the end of the world difficult but it isn't easy either.
Old 11-11-2017, 05:29 PM   #1492
artemk93
artemk93's Avatar
Drives: 2012 KO4 GTI
Need opinions
Car is a 2012 at 67K miles. A local reputable shop checked and told me that I have an updated tensioner. I have also checked chain stretch through vagcom and got -3.0, which I believe is within the norm (-4,4). I am still worried about the tensioner failing.
Should I just get a new tensioner, and install it myself
or
should I get new chains, guides, etc and update everything?
There're couple DIYs for the tensioner update, it looks very doable, but I haven't seen any chain update DIYs, and don't know how complicated it is
artemk93 is offline   Reply With Quote
Old 11-11-2017, 06:42 PM   #1493
Dans GTI
Drives: 2010 MK6
Originally Posted by artemk93 View Post
Need opinions
or
So, you have a updated tensioner and your chain isnít stretched, and your car has relatively low miles. Why in the world would you want to waste money on replacing parts that donít need replacing?
Old 11-11-2017, 07:17 PM   #1494
artemk93
artemk93's Avatar
probably once a month on startup I can hear the rattle. I can never duplicate it, seems to happen on random. While chain is within norm, it will probably be out of norm before I hit 100k.
I am just trying to do some preventative maintenance, instead of waiting for everything to break.
Old 11-11-2017, 07:19 PM   #1495
Dans GTI
Drives: 2010 MK6
I doubt your hearing timing chain rattle at 67k miles. Your chain obviously is not stretched. Maybe your hearing something else?
Old 11-11-2017, 07:25 PM   #1496
artemk93
artemk93's Avatar
Sounds exactly like videos online, only on startup for a second or two. It never happens on cold engine, happens only when the car has been sitting for couple hours, so tge engine is slightly warm.
I have been reading this thread for a while, and my symptoms seem to be consistent with what others have reported
Old 11-12-2017, 04:13 PM   #1497
funnyfarm299
Drives: 2009 GLI
What did you wind up paying?
funnyfarm299 is offline   Reply With Quote
Old 11-12-2017, 07:56 PM   #1498
realcyberbob
realcyberbob's Avatar
How can you check the stretch with vagcom?
