Old 10-04-2017, 08:27 PM   #7603
SELA_MK6GTI
SELA_MK6GTI's Avatar
Originally Posted by webbry4 View Post
So I have been having some problems since I got my Stage 2 Tune. Around 2-4k rpm and most noticeable in 2nd and 3rd gear at around 50-60% throttle I get surging noises. I have integrated engineering tune, intake, and their downpipe. I spoke with them over the phone and I'm scheduled to bring it in. Any suggestions on what to look for or say so I don't get screwed by them or tell me its normal.
Does your boost circulate up and down when it surges? Did you upgrade your coil packs?
Old 10-04-2017, 08:32 PM   #7604
SELA_MK6GTI
The Random / "Stupid" Questions Thread
I use to have the same issue after a while but it was with another tune. What I learned/figured out is that when your car starts acting up and surging you just have to reset/clear the codes with the obd II scanner even if you don't have any codes. It's like a way of "resetting" the ecu sort of speak and it should return your car back to normal levels. That's in case it's not a coil pack issue or something else. You're car should run full power and boost without surging afterwards and you'll be happy lol that's probably what I.e. Is going to do anyways, they're probably just going to reflash your ecu but you could just erase the codes with a scanner and it should be fine
Old 10-04-2017, 09:49 PM   #7605
uglybastard
uglybastard's Avatar
As alex said - what coil packs are you running?
logs will tell the tale of this one.
..246.............. Insta
Old 10-04-2017, 10:47 PM   #7606
webbry4
webbry4's Avatar
Ive cleared it already and coil packs are R8 with iridium plugs all brand new. And I have no I idea if boost is fluctuating it feels like even power delivery through out. Have a guy running logs on this. The only symptom as of now is a surging noise. I also don't want to get screwed by IE by them saying it's normal when I know it's not.
webbry4 is online now   Reply With Quote
Old 10-04-2017, 11:07 PM   #7607
SELA_MK6GTI
Gotcha, unless you haven't upgraded your DV it could be possible. Maybe it's ripped or has a leak and is not holding boost properly
Old 10-05-2017, 12:10 AM   #7608
webbry4
webbry4's Avatar
DV+ seems to be in good shape a couple of local guys say it's the tune I think it might be that or the n75 valve
Old 10-05-2017, 12:14 AM   #7609
SELA_MK6GTI
It should be the tune bro, no use of spending unnecessary money. I thought it was the DV and n75 valve and replaced both and the problem still persisted. Just get it reflashed and it should help. You wouldn't want to spend the extra money like I did thinking it'll solve the issue lol
I had mine reflashed and it fixed the problem and then whenever it would act up after words I would just "erase" the codes and it would go back to normal
Old 10-08-2017, 08:50 PM   #7610
webbry4
webbry4's Avatar
I went to change my oil today after 5k miles from my last dealer service and noticed that it has a very small leak. Anybody know what this is from or how to fix it. It almost looks like they tightened it too much and bent the pan. Before anybody says anything I had the dealer use the magnetic drain plug.
Old 10-08-2017, 10:01 PM   #7611
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
I'm pretty sure I've seen people complaining about that plug leaking before.
Old 10-08-2017, 10:20 PM   #7612
webbry4
webbry4's Avatar
Lol ya I'm gonna put the vw one back in
Old 10-08-2017, 10:57 PM   #7613
PhthaloType
PhthaloType's Avatar
My previous 2.5s' drain plugs always leaked unless I put what felt like excessive torque on the bolt. My first oil change on my 2.0 TSI did the same thing. Maybe because I used a generic copper washer instead of OEM?
2013 GTI Autobahn
4-Door
6-Speed Manual Candy White Titan Black
Bone stock!
PhthaloType is offline   Reply With Quote
Old 10-09-2017, 01:41 AM   #7614
webbry4
webbry4's Avatar
Ya mine almost looked too torqued a rounded washer took care of it for the most part and has residue but no dripping as of now. I'll probably get a new pan and use oem plug and washers with factory torque specs from now on.
Old 10-09-2017, 02:46 PM   #7615
1ashchuckton
1ashchuckton's Avatar
Not sure what ECS uses for a washer, but a crush washer really does seal well. Not sure how it would work on that drain plug.
Old 10-09-2017, 03:20 PM   #7616
lilonespaz
lilonespaz's Avatar
My ECS oil plug leaked too. I went back to OEM style plug and it worked fine.
