Old 12-21-2017, 10:29 AM   #7813
notovicrious
notovicrious's Avatar
Drives: 2011 GTi 2.0T
Originally Posted by tylorr83 View Post
I put in a halogen 194na, not an LED. I knew going LED meant vagcom.
Oh ok, did you try and flip the bulb? Maybe something to do with polarity?
Old 12-21-2017, 10:39 AM   #7814
tylorr83
Drives: 2013 White GTI DSG 4 door
I will give that a shot tonight when I get back home! Didn't even consider that. Thanks!
His: 2011 GTI 6spd Candy White APR Stage II, BSH True Seal Intake, APR Downpipe, SpeedyRacer catback, H&R Touring Cup Kit (MEMBER OF THE 140K+ MILE CLUB)
Hers: 2013 GTI DSG Candy White, Injen Intake (MEMBER OF THE 60K+ MILE CLUB)
tylorr83 is offline   Reply With Quote
Old 12-21-2017, 12:00 PM   #7815
notovicrious
Np, if the light was on it should be fine but itís worth a shot.
Old 12-21-2017, 09:30 PM   #7816
AGEE4
AGEE4's Avatar
If I have a 2013 GTI, when will I first need to smog my car?
AGEE4 is offline   Reply With Quote
Old 12-21-2017, 10:59 PM   #7817
TakmaN
TakmaN's Avatar
Drives: 2011 CW GTI 6MT
Anyone know what direction the front sway bar end links should be attached to the strut/shock body? I had coilovers installed a while ago and was working under my car today and noticed that they're installed opposite of each other on the driver and passenger sides.
The driver side has the joint facing the front and the nut facing the rear of the car and the passenger side has the ball joint facing the back of the car and the nut facing the front. Is it supposed to be like this? If not, can anyone chime in on the direction it's supposed to face? Seems odd but wanted to ask.
2011 Candy White GTI 6MT
Mod List: Unitronic Stage 1 | Neuspeed P-Flo | VMR 810 | ST Coilovers | Magnaflow Catback | Dieselgeek Sigma 6 | OEM LED Tail Lights w/ LED Reverse | Newsouth Boost Gauge | Boomba Shift Knob | Euro Switch | Euro Cup Holders | OEM Front Lip | Blind Spot Mirror | Soundaktor Delete | VAG-COM Coding
Wish List: Unibrace UB | FFE Shift Bracket Bushings
TakmaN is offline   Reply With Quote
Old 12-21-2017, 11:45 PM   #7818
sterkrazzy
sterkrazzy's Avatar
Drives: mk6 gti
If they're oem it's the only possible way you can do it. I noticed that when I swapped to aftermarket endlinks. I changed it so it was in the front on both sides, but idk if that was the right thing to do lol...the way the oem endlinks were set up just seemed so wrong though.
Old 12-22-2017, 02:17 AM   #7819
TakmaN
TakmaN's Avatar
Thanks! I was tempted to try turning the driving side front sway bar end link around since it took a bit of wrestling for me to get the sway bar onto the end link bolt. The passenger side slid right on perfectly. Note that this is the stock sway bar and end links.
Old 12-22-2017, 05:37 AM   #7820
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
You have them installed properly
If you're lowered (since you're on coilovers)....it might take a little more force, since the sway bar & the mounting tab will be in a slightly different location from stock now (the sway bar probably rotated too, in the bushings, so it won't just "easily" connect to the strut)
2017 Passat VR6
2017 Passat R-line
Old 12-22-2017, 07:24 PM   #7821
SirClimax
SirClimax's Avatar
Drives: 2014 CSG GTI
DSG GTI can do at least 103mph on cruise control. Not sure how much higher I am willing to go...
Sent from my SAMSUNG-SM-G920A using Tapatalk
"As the Spice Girls would say, Spice up Yo Life!" - robeeeerob
"Yeah but house stuff doesnt make your house go faster" - uglybastard
COBB Stage 2/SPM Turboback/IE Intake/Airlift Performance V2/Golf R Front Brakes/Tyrolsport Caliper Stiffening Kit/Slotted Rotors/Stoptech Pads/SS Lines/RBF600 Fluid/Neuspeed Rear Swaybar & Endlinks/VMR V701
SirClimax is offline   Reply With Quote
Old 01-04-2018, 07:37 PM   #7822
DASVDUB
DASVDUB's Avatar
Anyone on here done stud conversion kit?
DASVDUB is online now   Reply With Quote
Old 01-08-2018, 08:31 PM   #7823
joshmoni
Drives: VW Golf mk6 TDi
Front parking sensor harness connection location.
Basically,
I have front parking sensors as standard, but recently i fitted a new front bumper which came without the parking sensor holes. I didn't have the correct tools to make the holes so i left it a little while. In the meantime i simply tied the parking sensors somewhere under the bonnet.
There i am one day driving along, the parking sensors come loose and somehow end up under my wheel. They're now gone...
Upon buying some new parking sensors and making the holes in the bumper to fit them, i cannot find where the harness is meant to connect to? (Like where do they connect to the car to receive power ect.)
Anything that results in the location of said connector will be rewarded with a firm thank you.
joshmoni is offline   Reply With Quote
Old 01-08-2018, 10:15 PM   #7824
uglybastard
uglybastard's Avatar
Originally Posted by joshmoni View Post
Basically,
after some digging around this thread might be helpful http://www.golfmk6.com/forums/showthread.php?t=51758
..246.............. Insta
Old 01-08-2018, 10:16 PM   #7825
uglybastard
no, but what do you want to know about it
Old 01-09-2018, 12:55 AM   #7826
DASVDUB
DASVDUB's Avatar
Best kit to buy in case anyone has done it lol.
