Old 02-03-2018, 10:08 PM   #7855
DarienMidnight
Drives: 2012 vw gti 4dr autobahn
Farts depend on if you have a cat or not. Looks like you do have one. So it'll be less loud then catless. If you enjoy the sound who cares. If you want more loud, then remove cat or muffler.
My catback has no mufflers only resonator. And yes I'm catted DP. I guess the next move is maybe a resonator delete on the aftermarket catback..hope it doesn't sound ugly . If so can it be welded back on without any further issues ?
Baltimore Maryland
APR stage 2 / r8 coils / APR stage 1&2 intake / AWE CBE/ APR catted DP so basically i have and APE TBE ( FMOIG: YoungRios_ )
DarienMidnight is offline   Reply With Quote
Old 02-04-2018, 01:11 AM   #7856
DASVDUB
DASVDUB's Avatar
Do you have smog in Maryland? If not just get a catless downpipe.
Old 02-05-2018, 06:13 PM   #7857
Dub_Polo
Dub_Polo's Avatar
Drives: 2011 GTI DSG
Looking into the Enkei Performance PDC wheels, but they're 8" instead of my 7.5" Detroits. Is it that much of a different and would they rub more? Also would I still be able to put a 225 Michelin PSS on a 8" tire or would it be stretched?
Mk6 Gti DSG l COBB Stage 1+ l BSH Race Intake l R8 Coils l Raceland Ultimos l
Dub_Polo is offline   Reply With Quote
Old 02-05-2018, 06:16 PM   #7858
Roctre
Roctre's Avatar
Drives: 2011 CW GTI
They will fit perfectly fine and should never rub. That is the recommend no headache wheel set up for these cars. 225 will fit great on them.
Old 02-05-2018, 11:18 PM   #7859
pdan
pdan's Avatar
Drives: 2009 VW Jetta TDI (sold), 2013 GTI
So I was changing my oil the other day and decided I should probably check the timing chain tensioner. I have a 2013, so I assume I would have the updated one but something like this I donít exactly want to assume.
After watching the humble mechanic video on it he recommends getting a new plug after you pry your old one off in case you warp the cover and could develop oil leaks. Is this something that should be ordered, or is it a very remote chance of happening?? Iíd happily order one, just want to know if itís something everyone usually does.
pdan is offline   Reply With Quote
Old 02-06-2018, 02:42 AM   #7860
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
It depends on the offset too, btw
2017 Passat VR6
2017 Passat R-line
Old 02-06-2018, 08:58 AM   #7861
DASVDUB
DASVDUB's Avatar
IIRC you don't need to take the timing cover off the mechanism to check what revision you are... I know Jay745 could clarify as he's done a ton of them in Chicago.
Old 02-06-2018, 08:53 PM   #7862
KFahey
KFahey's Avatar
Drives: 2011 MK6 GTI-MT
I would just replace the plug it's super cheap, I replaced mine when I checked.
Sent from my SM-G935V using Tapatalk
APR K04 V3.1 | Unitronic CAI | CTS TBE | NewSouth Boost Gauge | R8 Coils | RSR Clutch Kit | OEM LED Tails | VWR Springs | KONI Yellow Front Struts | GFB DV+ | CTS Intercooler | 034 Street Mounts
KFahey is offline   Reply With Quote
