FS Feeler: Complete Diverter Valve Relocation Kit for TSI
allset
NO LONGER FOR SALE
Seeing if anyone is interested in a complete (minus the DV valve) DV relocation kit for the TSI. Installed for less than 3 months and includes the BSH Throttle Body pipe which is doubled wrapped insulated against radiant heat soak, DV relocation adapter, DV oem location block off plate, all silicone hoses and couplers, pre-assembled VW OEM DV harness extension wire, etc.
I originally got the BSH TB pipe to run methanol and did the DV relocation for the performance benefits, aesthetics and sound. I'm going to run the methanol differently in the spring so i need a new different TB Pipe.
PM if interested.
Thx
Paul
PICS OF SET UP BELOW IN POST #2
(RETAIL $ IS WHAT I PAID NOT INCLUDING SHIPPING ($Green# is your price) )
Included in sale:
WILL SELL EVERYTHING TOGETHER OR WILL SELL THE BSH TB PIPE BY ITSELF OR DV RELOCATION PARTS AS A KIT BY ITSELF. WILL NOT PART OUT THE DV RELOCATION KIT ITEMS.
BSH DEI INSULATED, DUAL WRAPPED TB PIPE + DV RELOCATION KIT:$316 SHIPPED
DV RELOCATION KIT ONLY : $176 SHIPPED
BSH DEI INSULATED, DUAL WRAPPED TB PIPE ONLY: $140 SHIPPED
THE COST IF YOU HAD TO BUY THE BSH TB PIPE AND THE DV RELOCATION PARTS NEW: $ 460 PLUS SHIPPING
BSH DEI INSULATED, DUAL WRAPPED TB PIPE: $140
BSH
Integrated Throttle Body Pipe: $140 (Retail :$170)
Pipe comes with all parts, meth bung plugs, silicone elbow, DV stem plug,etc.
BSH TB PIPE is pre-wrapped w/ one layer of DEI Titainium Insulation covered w/ a layer of DEI radiant heat reflective "cool tape" to limit heat soak of the cooled air leaving the Intercooler entering the TB Pipe: At least $30 of DEI wrap FREE
DV RELOCATION KIT PARTS: $176
ATP TURBO
Relocation Adapter for stock diverter Valve 2.0T: $55 (Retail: $70)
3 bolt style 2.0T Block-off flange/plate for OEM DV location: $25 (Retail $30
SILICONEINTAKES.COM
1.5" silicone 45 degree: $13 (Retail $17)
1.5" to 1" silicone step down/reducer: $7 (Retail $10)
2.5" silicone T Pipe w/ 1.0" outlet/BOV port: $15 (Retail $20)
1.5” SS coupler: $6 (Retail $8)
1" double barb connector: FREE
1" x 4' SCEET Aircraft hose/duct (Never Installed): $25 (Retail $32
(Super light, flexible and strong. If requested I can seal the outside with black high temp silicone sealant for extra protection -hose is orange stock)
1" x 4' Radiator hose (running this now until the SCEET came in. Ur choice on which hose to use): FREE
FROM VW: (Parts used to make DV Harness Extension)
DV HARNESS EXTENSION IS FULLY ASSEMBLED AND LOOMED FROM VW OEM PARTS AND IS LONG ENOUGH TO CONNECT FROM THE STOCK DV HARNESS LOCATION BY THE TURBO TO THE DV @ THE RELOCATION ADAPTER ON THE BSH TB PIPE WITH EXTRA LENGTH TO RUN FOR AN OEM LOOK.
000 979 134 A: wire (x1) : $7.52
000 979 133 A: wire (x1) : $5.92
1J0 973 722 A: Connection housing to DV : $11.56
1J0 973 822 A: Connection housing to harness : $ 4.74
EDIT: HOSE CLAMPS WILL BE INCLUDED IN SALE FOR FREE
3 x 2.0" clamps -FREE
4 x 1.5" clamps -FREE
2 x 3.0" clamps -FREE
NOT INCLUDED:
-A Diverter Valve
Links to above:
ATP TURBO DV Relocation Adapter
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-VVW-212&Category_Code=
ATP TURBO OEM DV Location Block Off Plate
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=TP&Product_Code=ATP-VVW-259&Category_Code=
http://www.siliconeintakes.com/product_info.php?cPath=4&products_id=402&osCsid=d21e2da0b1781017334696fd230b52a2
http://www.siliconeintakes.com/product_info.php?cPath=2&products_id=120&osCsid=d21e2da0b1781017334696fd230b52a2
http://www.siliconeintakes.com/product_info.php?products_id=455&osCsid=d21e2da0b1781017334696fd230b52a2
1.5” SS coupler:
http://www.siliconeintakes.com/product_info.php?cPath=9&products_id=133&osCsid=d21e2da0b1781017334696fd230b52a2
1" x 4' SCEET Aircraft hose/duct:
http://www.aircraftspruce.com/catalog/appages/sceet.php?clickkey=11769
allset
pics of DV relo setup
Cwinne
Dam I want this. Any pix of it installed.
I also plan on running the awe tuning dv with this
allset
pics added.
So what exactly are the benefits of this setup?
moves DV away from hot turbo, cycles cooled air from charge pipe when actuated, more audible DV due to new location, and of course, because racecar.
allset
pics of set up is using a 4 foot radiator hose instead od the aircraft duct ( u cant see that hose any way in the pics) but that 4 foot hose listed above will come new and un used with the 4 foot rad hose. U can choose either to use.
svickstc
Haha thanks allset, your setup actually looks quite clean so props to that, I just figured any added piping would reduce slight performance but this setup def allows for easy cleaning and servicinb if needed
allset
its minimal piping, no perf loss noticed.
allset
prices now include shipping (i didint increase the original prices)
allset
ttt
allset
Why? Doing something new? Should gimme that setup so I don't have to set my own up. :) haha.
ok, ill throw in the peloquin too, and 200 cash. That sounds fair.;)
Not sure what im doing yet. Def moving the nozz back to the IC so may use the Neuspeed TB instead. This was just to see if any takers to motivate me to remove and install the other set up.
boki
I'm interested in your DV relocate set up - would you accept $150 picked up? Where in NYC area are you? I'll PM you my contact info so please text/call me. Thanks.
