Old 02-22-2013, 03:26 PM   #15
U-20T
Drives: BT GTI4Motion
Originally Posted by 2013R View Post
I guess no one has tried the Golf R master cyl on the GTi yet. Bleeding that thing would be a bitch..
same size so why
Old 02-22-2013, 09:03 PM   #16
the bruce
the bruce's Avatar
Drives: Mk.V GTI
All Mk.VI GTI should come with the 23.81 mm MC.
If in doubt check part number on MC or PR number on the sticker in your trunk:
Golf 5 R32 (2008er) 1K1 614 019 L (ATE)
Golf 5 GTI (2008er) 1K1 614 019 L (ATE) + 1K1 614 019 K (ATE) + 1K1 614 019 F (Bosch)
Golf 6 GTI (2010er) 1K1 614 019 L (ATE) + 1K1 614 019 K (ATE) + 1K1 614 019 F (Bosch)
TTRS & RS3 (2010er) 8J1 611 021 E (ATE) - 25,4 mm
LHD cars only !!
1K1 614 019 L = 23,81 mm
1K1 614 019 K = 22,20 mm
1K1 614 019 F = 22,20 mm
8J1 611 021 E = 25,40 mm
Index L ... 1AC, 1AT, 1AS
Index K ... 1AC, 1AT, 1AS+1LL, 1LJ
Index F ... 1ZC, 1ZE, 1ZF, 1ZP, 1ZD, 1LJ
TTRS & RS3 ... 1AT, 1AS
PICS
Old 05-14-2013, 10:18 AM   #17
valj
Drives: Golf 6 GTI DSG
up to the thread - any update on other brake kits?
valj is offline   Reply With Quote
Old 05-21-2013, 07:48 PM   #18
the bruce
the bruce's Avatar
Drives: Mk.V GTI
Here we have Audi TT-RS and Wilwood calipers (included in their 328 mm kit for GTI):
piston area
1. stock front:
O2 RS/Golf/GTI - Ate FN3 54 mm: 2290 mm˛
S3/R32/R - FNRG 57 mm: 2552 mm˛
2. aftermarket - fits properly:
AP Racing 6-pot CP7068 (355x32 ) > 2350 mm˛ (special version of CP7040-caliper for Golf V/VI, Scirocco etc.)
AP Racing 6-pot CP5570: 27.0 + 31.8 + 38.1 > 573 mm˛ + 794 mm˛ + 1140 mm˛ = 2507 mm˛
Audi TT-RS: 36 + 40 mm > 1018 mm˛ + 1257 mm˛ = 2275 mm˛
Boxster: 40 mm + 36 mm > 1257 mm˛ + 1018 mm˛ = 2275 mm˛
Boxster S: 40 mm + 36 mm > 1257 mm˛ + 1018 mm˛ = 2275 mm˛
993 Turbo: 36 + 44 mm > 1018 mm˛ + + 1520 mm˛ = 2538 mm˛
Brembo GT 'A-caliper': 40 mm + 36 mm > 1257 mm˛ + 1018 mm˛ = 2275 mm˛
Stoptech ST-40: 38 mm + 34 mm > 908 mm˛ + 1134 mm˛ = 2043 mm˛
Wilwood FNSL6R: 41.1 + 28.4 + 28.4 mm > 1330 + 636 + 636 mm˛ = 2602 mm˛
Mov'it:
4s2 - 36 / 44 = 2538 mm˛
4s3 - 36 / 44 = 2538 mm˛ (u.a. als VAG-Kit mit 322x32er Scheibe, geht unter 17")
4m6 - 36 / 44 = 2538 mm˛
6m1 - 28 / 32 / 38 = 2554 mm˛
3. aftermarket - mismatch:
Forge: 707 mm˛ + 1046 mm˛ + 1164 mm˛ = 2917 mm˛
Mov'it:
4s4: 40 / 44 = 2777 mm˛
4s5: 38 / 46 = 2796 mm˛
6m3: 30 / 34 / 38 = 2749 mm˛
Brembo 8-pot RS4/R8/Gallardo: 28 + 28 + 32 + 32 mm > 2840 mm˛
Brembo 8-pot RS6 : 4192 mm˛ (!!!)
996 Turbo: 40 + 44 mm > 1257 mm˛ + 1520 mm˛ = 2777 mm˛
Q7/Touareg/Cayenne (there are 3):
34/36/38 mm : 907.920 + 1017.876 + 1134.115 = ~ 3060 mm˛
32/36/38 mm : 804.248 + 1017.876 + 1134.115 = ~ 2956 mm˛
30/34/38 mm : 706.858 + 907.920 + 1134.115 = ~ 2749 mm˛
4. master cylinder:
- 22,22 mm > 388 mm˛ (some Golf V, some Scirocco etc.)
- 23,81 mm > 445 mm˛ (Golf V R32, Golf V GTI, Golf VI GTI, Golf R, Scirocco 2.0T + R)
- 25,40 mm > 507 mm˛ (RS3 + TT-RS)
5. rear:
GTI/RS: C38 > 1134 mm˛
S3/R32/R: C41 > 1320 mm˛
Movit 4m1: 28 / 30 = 1323 mm˛
Movit 4m2: 28 / 30 = 1323 mm˛
Pi * Radius˛ = area
PICS
Old 05-28-2013, 04:56 AM   #19
valj
Do I understand correctly that Cayenne calipers will work poor on my mk6 gti?
Old 05-28-2013, 10:30 PM   #20
the bruce
the bruce's Avatar
Drives: Mk.V GTI
Right, mate.
You'd suffer from front biased brake balance, increased pedal travel and softer pedal feel.
PICS
Old 05-29-2013, 01:29 AM   #21
valj
Thank you for the info!
Old 05-29-2013, 04:12 AM   #22
U-20T
Originally Posted by the bruce View Post
Right, mate.
my pedal is stiffer and shorter than factory 17zs, bais isnt terrible either its there but usable. I did drive a brembro specific bbk 330mm 6 pot vs mine and the bais is a lot harsher for some reason than the cayanne setup.
Old 12-26-2013, 04:15 PM   #23
BETO GLI
Drives: VW Golf GTI 35 AE MKVI
Hi Bruce,
Do you have any info regarding to VW Racing and HPA 6 and 8 front BBKs, as Wellington as HPA's rear BBKs?
Thanks and Merry Christmas!
Beto
BETO GLI is offline   Reply With Quote
Old 02-01-2014, 02:55 AM   #24
BETO GLI
Bump!
Old 02-19-2014, 02:03 AM   #25
ncampos976
Drives: 2013 GTI Autobahn
I currently have ttrs brakes on my car. I have been considering swapping to a ttrs master cylinder.
ncampos976 is offline   Reply With Quote
Old 03-15-2014, 12:45 PM   #26
A3SBQ
A3SBQ's Avatar
Drives: Audi A3 SB 2.0tfsi/TSI quattro DSG
Does anyone knows if the MC from the TTRS/RS3 fit our brake booster? Is it a strait fit?
A3SBQ is offline   Reply With Quote
Old 03-15-2014, 03:19 PM   #27
BETO GLI
+1, if so that'll be a great upgrade!
Old 05-31-2014, 08:17 PM   #28
the bruce
the bruce's Avatar
Drives: Mk.V GTI
Sorry, mate. Still no confirmed info about this.
I just read, if you want (or need) to swap the booster as well, you'd
need to grab the RS3's as the TT-RS booster won't fit the Golf/GTI.
FWIW, the new Audi S1 quattro also comes with the 25.4 mm MC,
while the current Mk. VII GTI and R still have the 23.81 mm one.
PICS
