Old 04-19-2017, 10:05 PM   #519
GTI2Slow
GTI2Slow's Avatar
Drives: Slow
So you installed the MC dry?
Mk5 slumming it up in your Mk6 forums.
GTI2Slow is offline   Reply With Quote
Old 04-20-2017, 12:41 AM   #520
BringerOdeath
BringerOdeath's Avatar
Drives: 2011 GTI Candy White
There was some fluid in it from the wrecked car the pullled it from still in it.
Old 05-06-2017, 10:32 AM   #521
ViR
ViR's Avatar
Drives: GTI
Originally Posted by mikejsmith1985 View Post
SUCCESS!!!!
So I feel like an ass hat for all the crap I've posted and time spent trying to figure out how to improve the pedal feel. Today we got the bright idea to crack open the lines at the MC and low and behold AIR! How that happens after pushing all the fluid I've pushed through the system with the power bleeder is beyond me but pedal is good now. Just a light softness at engagement and then firms up like your pushing against a brick wall if you really stand on them. So I attribute my undetected union leak and air trapped in the MC for all my heart ache on this.
So I don't intend on going forward with the stand alone vacuum pump for the booster at this point. With this setup the brake pedal and the gas pedal seem to sit at the exact same height. I prefer the brake pedal to be just a bit higher so I'm probably going to 3D print a shim to it between the pedal and the locking clip for the booster push rod. I'll have to modify the clip a bit but no rush on all this. Right now I'm just happy to finally have what I was looking for with the feel of this pedal
Good work! I'm happy for your success. Took 2 days to read 38 pages and it was very interesting.
Thanks to your research now I know that I dont want to go with your MC setup, too much hassle hahaha!
One question though, whats your rear setup? Toureg OE is bolt on or you had to get custom parts?
2013 VW GTI Wolfsburg Edition | APR Stage 2 93 | APR Carbonio CAI | Custom 3" DP | Koni Coilovers | Unibrace UB | StopTech | GFB DV+ | R8 Coils | NGK Iridium |
ViR is offline   Reply With Quote
Old 05-06-2017, 10:39 AM   #522
ViR
ViR's Avatar
Drives: GTI
Does anyone know if there will be any issues installing TTRS MC on stock GTI brakes?
I will have it shipped before the 18Z and was thinking to instead of right away..
Old 05-06-2017, 11:12 AM   #523
GTI2Slow
GTI2Slow's Avatar
Drives: Slow
You will have 30% less pedal travel and the pedal will be really firm, I would hold off on it.
Old 05-06-2017, 11:54 AM   #524
BringerOdeath
He has the touareg rear 4 piston brakes with golfr rear calipers as ebrakes. Yoi have to use a special bracket. Ecs sells the dual calipee bracket kit.
Old 06-04-2017, 01:28 AM   #525
drakore
Hey everyone,
I just put in my TTRS MC and reservoir and I tried to power bleed my lines but air is coming out through this on the reservoir (see picture).
How are you guys plugging that tube?
Thanks!
Sent from my SM-G930W8 using Tapatalk
drakore is offline   Reply With Quote
Old 06-04-2017, 02:12 AM   #526
BringerOdeath
Originally Posted by drakore View Post
Hey everyone,
Thanks!
That's for the clutch line that feeds into the clutch master cylinder and throwout bearing. The MC came off of manual Tranny car. You are going to have to come up with a rubber cap or something to cover it up.
Old 06-11-2017, 03:43 AM   #527
MacRadiators
MacRadiators's Avatar
Drives: Leon FR
I found these part numbers with 25.4mm MC
Is there any difference between LHD and RHD pumps? i cant find photos of rhd pump to compare to lhd
8J2611021D RHD
8J1611021E LHD
8J1611021A LHD
MacRadiators is offline   Reply With Quote
Old 06-11-2017, 09:50 AM   #528
BringerOdeath
8J2611021D RHD
8J1611021E LHD
8J1611021A LHD
The rhd ones have the line connections on the opposite side so it doesn't work
Old 06-11-2017, 12:06 PM   #529
GIACUser
GIACUser's Avatar
Drives: 2008 MKV EFR7163
I have just ordered all my parts for an 18z and rear 4 piston kit.
For the rear I purchased a kit from Fabless dot com that provides the necessary special mounting bracket and it utilizes the small Wilwood e-brake calipers to replace your lost parking brake capability rather that keeping your original rear caliper in place to use only as a parking brake. LINK
Wilwood parking brake caliper LINK
Also ordering RS3/TTRS MC from HS Tuning with modified reservoir. LINK
| 2008 GTI under construction as of July 2017 looking for 500whp| EFR7163 | LSD | DriverMotorsport tune | UNI custom DSG tune | Aquamist W/M | Brembo brakes f/r |
| YCW Coilovers | fifteen52 fender flares | 18x10 w265/35 Michelin SportCup2 | Recaro Speedseats |
Old 06-11-2017, 04:01 PM   #530
MacRadiators
Drives: Leon FR
The MC is pretty expensive, half price here
