Old 11-28-2012, 11:56 AM   #1
lilfleck
Drives: '11 GTI Autobahn, DSG
Cold Start + Normal RPM = Weird?
Intermittently, I will start the car (cold outside; NJ winter), and the car will idle at the normal RPM as if it were warm. Normally (even during the summer), our cars will rev to about 1200RPM for a solid 30-40 seconds before slowly leveling out.
Anyone else experience this?
Old 11-28-2012, 12:01 PM   #2
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Happened to me once or twice. The ECU goes through its own checks often times and obviously, in this case, it thought it was fine to handle the startup load at a normal RPM. I wrote it off as a quirk.
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 11-28-2012, 12:07 PM   #3
TRUboost
Drives: '12 CSG GTI/'13 CW GLI
This. The ECU is a wasteland of things us mortals are not meant to understand lol.
Just like my headlight start up sequence which only works 20-30% of the time.
TRUboost is offline   Reply With Quote
Old 11-28-2012, 12:09 PM   #4
SkullV
I hate this ECU
Old 11-28-2012, 12:10 PM   #5
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
my car idles down when my egt's reach 700 degrees. i ♥ my p3 gauge.
Old 11-28-2012, 12:15 PM   #6
MKVInce
MKVInce's Avatar
Drives: 2012 CW GTI 6MT, 2007 OB G35 Coupe
Happened to me many times. Mostly when the AC/Heater is automatically on when I turn on the car.
2004 G35 (sold)
2007 G35 (current)
2012 GTI MK6 (sold)
2013 Evo X (sold)
2015 BMW X3 (current)
MKVInce is offline   Reply With Quote
Old 11-28-2012, 12:17 PM   #7
grambles423
Limited Activity
Agreed. TOo many bugs to sort out sometimes. But that's the nature of German "over complication" of systems.
I noticed a huge difference in working for Mercedes then changing to Honda. Same idea.......waaaaaayyyyyyyy different design principles.
Originally Posted by SkullV View Post
I hate this ECU
I love it for what it can do, but I do agree....its too "quirky" to really justify stepping outside the OEM realms.
As it should. Standard procedure. But this case is just a "bug" that happens every so often. I'd almost like to see the ECU's readiness checks and startup sections to see if it actually was thinking it was warm when started.
Old 11-28-2012, 01:31 PM   #8
TurtleJames
TurtleJames's Avatar
Yup, happens to me also from time to time. I'm happy when it does. No car pee shivers for me!
2011 GTI Autobahn DSG | APR K04 | APR IC | Unitronic DSG Stage 2| Carbonio CAI | Neuspeed TOP | UR DP | Magnaflow CBE | P3 Boost Gauge |Unibrace UB / XB |OEM+ Interior / Exterior : Golf R LED Tails | RNS-510 | VW Rear View Camera | Dash Cubby | Under Seat Drawers | Euro Cup Holder | etc. | Q.T. McWhiskers Laser Defense System | VCDS and OEM RVC Services in Northern NJ |
TurtleJames is offline   Reply With Quote
Old 11-28-2012, 01:33 PM   #9
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
Same here
Sometimes it does high RPM starts & sometimes it doesn't.....very quirky
2017 Passat VR6
2017 Passat R-line
Old 11-28-2012, 01:57 PM   #10
lilfleck
Whew, glad I'm not the only one. Thought I was imagining things.
Just like women.
I hear you on the headlight start up sequence. I love when they dance, but I can't make them dance when I want them. Damnit, even more like a woman.
Old 11-28-2012, 03:21 PM   #11
CMD
I've also experienced this on occasion and wondered if all was ok. From the sounds of it, just another German quirk to love
CMD is offline   Reply With Quote
Old 11-28-2012, 03:25 PM   #12
Mceric01
Drives: 2012 2dr CSG
Funny thing. Today is the first time that's ever happened to me. 39 degrees F out this morning. Completely cold start. I was worried but now I feel better!
APR Stage 2 Tune 93 - APR Carbonio Intake stage 1 - SPM Catless Downpipe - Southbend Stage 3 Drop in Clutch Disk - Driver Gear Springs - Hotchkis Front & Rear Sway Bars - 18" TSW Nurburgrings wrapped in Bridgestone Pole Positon RE970AS - Passport Escort Redline w/Escort live - Suntek CXP Tint; 18% rear 3 windows, 70% front 3
Mceric01 is offline   Reply With Quote
Old 11-28-2012, 03:26 PM   #13
DonC@DriveSPM
DonC@DriveSPM's Avatar
Drives: 09 KO4 GTI, 90 Corrado 1.8T, 06 GLI
If your parking brake is still on, the lights still go through the motions, but the lights aren't actually on.
Edit - someone might want to double check my statement
DonC@DriveSPM is offline   Reply With Quote
Old 11-28-2012, 03:32 PM   #14
tunner2307
tunner2307's Avatar
Drives: '12 GTI
Same here...weird
tunner2307 is offline   Reply With Quote
