Old 11-28-2012, 04:49 PM   #15
michel
Drives: 330ci
yup, mine does the same thing.
michel is offline   Reply With Quote
Old 11-28-2012, 05:39 PM   #16
TRUboost
Drives: '12 CSG GTI/'13 CW GLI
Originally Posted by lilfleck View Post
Whew, glad I'm not the only one. Thought I was imagining things.
Just like women.
I hear you on the headlight start up sequence. I love when they dance, but I can't make them dance when I want them. Damnit, even more like a woman.
Lmao so true. The worst part about it is its completely random. I've tried it in park, park with e-brake, drive, reverse, upside down, during a j turn. Nothing.
TRUboost is offline   Reply With Quote
Old 11-28-2012, 06:12 PM   #17
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
my service reminder ding goes off when i start the car but if i start the car and quickly get out it wont beep until i get back in.
Old 11-28-2012, 06:50 PM   #18
acewayne
acewayne's Avatar
Drives: 09 BMP GTI
I recently started parking my car outside and I was wondering the same thing. Upon searching I came across this on golfmkv and golfmk6. Makes sense I suppose.
Originally Posted by lextildeath View Post
To understand this you must first understand why the car is loud in the first place. Your ecu is programmed to start and hold a raised rpm at startup to warm up the cat quickly in order reduce startup emmissions. This is only on pzev cars.
The reason your car is not doing this anymore is because it is too cold out. The ecu won't allow raised rpms on startup below a certain temperature in order to reduce cold start piston wear.
Originally Posted by tmw2442 View Post
When it is below a certain ambient temp, the ecu does not run the cat warm up cycle to minimize the cold start wear on the engine
Originally Posted by DRedman45 View Post
moding is like smoking, we all know its bad, expensive, and hurts your chances with some women...but its addiction
acewayne is offline   Reply With Quote
Old 11-28-2012, 10:25 PM   #19
bburns36
bburns36's Avatar
Drives: '13 GTI Conv/SR/DSG
I noticed that if I leave mine outside overnight and it's less than 32deg F in the morning, the secondary air pump doesn't run, and i get the normal 800rpm-ish idle immediately on cold start. Or so I thought...
This morning it was 43deg in my garage, and the pump didn't run. Or actually, after 10 seconds it kicked on for maybe half a second (dimmed the headlamps even) and then back off. I can't figure it out. I heard somewhere that under 32deg it won't run the pump in case there's moisture frozen inside it, which would kill it.
Also last week with a semi warm motor the SAI pump came on for 10sec as I was backing out of the garage but wasn't on immediately at startup.
Disconnected Soundaktor, Jetta Climatic, and no more catback...
bburns36 is offline   Reply With Quote
Old 11-28-2012, 10:51 PM   #20
tmw2442
Drives: Mk6
Intermittently, I will start the car (cold outside; NJ winter), and the car will idle at the normal RPM as if it were warm. Normally (even during the summer), our cars will rev to about 1200RPM for a solid 30-40 seconds before slowly leveling out.
Anyone else experience this?
When the temperature is low enough the ecu does not use the map to heat up the cat quickly for emissions. Instead it use the low rpm (warm) idle map to reduce cold start wear on the engine.
tmw2442 is offline   Reply With Quote
Old 11-29-2012, 09:04 AM   #21
steady-_-eddy
steady-_-eddy's Avatar
Drives: 2012 GTI / 6MT / Sunroof w. Nav.
This also started happening to me recently when the temperature here in NY dropped to below freezing in the morning.
I go to turn the car on and it turns on just fine but doesn't make all the noises and doesn't REV up to 1200 like it normally does. I thought it was something wrong with my car, but I see its happening to a number of people.
steady-_-eddy is offline   Reply With Quote
Old 11-29-2012, 09:53 AM   #22
boosted27
boosted27's Avatar
Drives: 2011 CW 5 Door GTI
Happens to me! And I usually let the car run in the morning for that 40 seconds until it drops . I usually just figure its been good amount of time when this happens.
boosted27 is offline   Reply With Quote
Old 11-29-2012, 10:04 AM   #23
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
The point in this thread is that the RPMs DONT rise upon cold starts. You crank the car and it stays at idle RPMs.
But yes. Always wait for the RPMs to drop before you take off.
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 11-29-2012, 10:19 AM   #24
lilfleck
Drives: '11 GTI Autobahn, DSG
Yep.
Excuse the cel...
**Sorry for the large size, not sure how to resize easily**
Tapped and talked.
Old 11-29-2012, 11:29 AM   #25
flyguy27
flyguy27's Avatar
Drives: 2013 328i Sport line
So, is it a bug if we all seem to have this happen or an intentional design?
Stock with Style
OEM FRONTLIP SPOILER|LED INTERIOR LIGHTS|RED FOOTWELL LIGHTS|GTI SEAT INSERTS|GTI DOOR SILLS|OEM LED CHERRY TAILS|REVERSE CAMERA|SEAT DRAWERS|RNS 510|
flyguy27 is offline   Reply With Quote
Old 11-29-2012, 12:03 PM   #26
NYCRabbit
NYCRabbit's Avatar
Drives: vw
It is intentional...read posts 18 & 20 on page 1 for explanation.
NYCRabbit is offline   Reply With Quote
Old 11-29-2012, 12:13 PM   #27
MKVInce
MKVInce's Avatar
Drives: 2012 CW GTI 6MT, 2007 OB G35 Coupe
Happened to me again this morning. I'm not too worried about it.
2004 G35 (sold)
2007 G35 (current)
2012 GTI MK6 (sold)
2013 Evo X (sold)
2015 BMW X3 (current)
MKVInce is offline   Reply With Quote
Old 01-07-2015, 12:25 PM   #28
Richyroxx
Drives: 2013 csg 4dr
My car hasn't ran cold start rpm for about a week now and I was very worried because I just installed a unitronic intake hoping that didn't screw with the ecu but after finding other members having this problem I feel much better
Richyroxx is offline   Reply With Quote
