Old 12-02-2012, 07:30 AM   #1
andrei_don
andrei_don's Avatar
Drives: golf gti mk6
APR K04 Golf GTI: dyno 396hp/528Nm APR 100oct flash + 3 intake comparison + video!
Hello!
Here is my 09' VW Golf GTI MK6 DSG.
Current specs:
- APR Carbonio intake stage1
- APR K04 turbo kit
- THS intecooler kit
- Ultimate Racing catless resonated downpipe
- APR RSC catback
- APR V2.0 Software(91,93,100oct)
Dyno pulls were done on SuperFlow dyno (http://www.superflow.com/) that's capable of measuring actual tranny losses
With Modshack VDTA intake
Modshack VTDA intake draw some skepticism due to fairly small universal K&N used in these intakes. I liked this intakes setup because it’s one of the quietest if not THE quietest intake on the market. Modshack’s low price didn’t hurt either.
There were also 2 more intakes on hand at Morendi – the dyno shop and one of APR dealers in Moscow. We had a chance to test Modshack vs. VW Racing (ITG) and APR\Carbonio and see is there is (if any) difference between 3 of them.
So the plan was to do 3 runs on each intake, take 10-15 minutes for engine to cool down and swap out the intakes and continue with the next intake. Personally, I was pretty skeptical and did not expect to see any gains beyond 4-5 hp:
Modshack VDTA- K&N cone filter
APR Carbonio- K&N round straight filter
VW Racing- cone filter
The results were pretty surprising for us – see below:
This intake was loudest on the dyno and I was pretty sure it would be most effective in terms of power gains. Turned out… I was wrong. It posted lowest HP gain but did post some respectful torque and also resulted in best spool time! I personally think the fairly low numbers come down to the filter element used as it is probably more restrictive than a typical K&N. It does look the business though with its track-inspired design.
This intake was making a noise that could be described as “hissing” thanks to its slot-like opening but the end-result was mind-blowing… Its filter element has the largest surface area and that, coupled with thermal insulation properties of its carbon fiber housing resulted in significant gains over VW Racing intake – APR\Carbonio posted a 17hp! Needless to say, the visual aspect is just something special compared to other intakes.
Overlay of all 3 intakes’ dyno plots
And the end-result – APR K04 100 octane (RON) run:
I am very happy with the results!! As with intakes, I was pretty skeptical with running 100 octane gas – I was expecting to see something in the 15-20hp neighborhood. Obviously, the software has also been adjusted to run 100 RON gas, otherwise there’s no way we would’ve seen almost 400hp. I was a bit uneasy running 100 octane gas so I had an EGT sensor installed “just in case”
We were all very relieved to see the EGT numbers not creeping higher than 800 degrees, even after 3 back-to-back runs on the dyno. The temperature remained below 810 degrees even after a couple of back-to-back 100-200 kmh runs through 2-3-4-5 gears all the way through redline – this just proved the software as well as gas quality.
So we decided to give it a try in real life and make some runs vs. some of the popular cars that we have over here.
Here are some videos:
Dyno
100-200km/h = 9,6-9,7sec for example BMW M3 E92 100-200km/h = 10,7-10,8 :-)
APR K04 VW Golf GTi MK6 405.3hp/576,1Nm APR 100oct flash
andrei_don is offline   Reply With Quote
Old 12-02-2012, 07:50 AM   #2
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
Old 12-02-2012, 07:55 AM   #3
mikeleemk6
mikeleemk6's Avatar
Drives: Shadow Blue GTI MK6
nice!!!
Old 12-02-2012, 08:44 AM   #4
Corsair
Drives: Volkswagen Golf GTI VI June 2010
Awesome!
Corsair is offline   Reply With Quote
Old 12-02-2012, 01:19 PM   #5
trd420
trd420's Avatar
Drives: 2015 S3 Prestige+Performance Pack
Great numbers!!!
Now 2015 Audi S3 Prestige + Performance package, DTUK & K&N drop in. Running E-85 blend
Had 2011 MK6 GTI Unitronic Stage 2+ (K04)
Had 1989 MK2 GTI VR-6 Swap
trd420 is offline   Reply With Quote
Old 12-02-2012, 05:09 PM   #6
Jeka
Drives: 2012 MKVI GTI CSG 6spd
Super (Супер)
Jeka is offline   Reply With Quote
Old 12-02-2012, 05:33 PM   #7
hotshot100
Drives: Gti Mk6
nice number thanks for the sharing
K04 Club Member #79
Mart Mk6 Build Thread
hotshot100 is offline   Reply With Quote
Old 12-02-2012, 05:51 PM   #8
PRND[S]
PRND[S]'s Avatar
That's a very nice write-up, I appreciate the data and nice pictures and videos.
Old 12-03-2012, 03:05 AM   #9
andrei_don
andrei_don's Avatar
Thanks for reviews!
OZ vs Stock R18 Rims weight:
unsprung weight
Old 12-03-2012, 01:56 PM   #10
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
Awesome review!
Old 12-03-2012, 03:39 PM   #11
SuPeR GTi
SuPeR GTi's Avatar
Drives: 12' GTI MT
pretty cool. makes sense that the intake and software are designed around each other. which clutch are you running?
Old 12-03-2012, 04:04 PM   #12
ViRtUaLheretic
ViRtUaLheretic's Avatar
Drives: 2009 GTI
lol @ 400hp
I have a dyno saying my car has over 900ft/lbs of torque at 1000rpms, want me to post that up?
::APR stage2::BSH - Intake,Mounts,TB Pipe,RSB::Eurojet Ceramic Coated TBE::Phoenix Rising - FMIC::
::Devils Own DVC-30 5xDO1::Neuspeed ::Whiteline::BC Racing - BR coils::OSIR::HPA-DSG::INA::
::Flik FTDs::245x40x17::Unibrace::Bildon::Porsche 17z BBK::Hawk - HPS::034::Tyrolsport::
Read this for TSI INFO/FAQ
ViRtUaLheretic is offline   Reply With Quote
Old 12-03-2012, 04:07 PM   #13
SkullV
So these HP numbers are theoretical crankshaft numbers based on what percent of drivetrain loss?
Looks like:
  1. APR Carbonio: 365.9hp/349.24tq
  2. Modshack: 354.5hp/349.75tq
  3. VWR: 349.0hp/351.37tq
Looks like the Carbonio is worth the added noise that some perceive. Thanks for the great comparison!
Old 12-03-2012, 04:10 PM   #14
socal87
socal87's Avatar
Drives: Black '12 GTI Sun/Nav 4dr 6MT
I'd like to see numbers of K04 on 91 octane with Carbonio and APR TBE.
Favorite Color: EXPLOSIONS
Likes: EXPLOSIONS
Dislikes: Not-EXPLOSIONS
Jubblies. That is all.
socal87 is offline   Reply With Quote
