I know this can be done with a VAG COM which I don't have but wanted to know if anyone had done the following to reset a DSG to factory shift points.
1 Put your key in the ignition and turn ignition to the on position (don't start the engine!)
2 Hold down the gas pedal pressing the button under the pedal for at least 20 seconds.
3 Let foot off pedal and start car. Be sure that you do no turn ignition off because that will void the reset
(not so sure it still works)
