Old 12-27-2012, 02:56 AM   #29
littleazn248
littleazn248's Avatar
Drives: Audi SQ5/ F30 335i
Originally Posted by MaliciousMK6 View Post
Great mod, i heard the 4 and 6 pot Toureg brakes fit as well. great priced brake upgrades is a closely guarded secret!
Yes the touareg calipers fit. They are the same as the cayenne six pot brembos but, are overkill imho. I think the Boxster 4pots are the most reasonable for this car. But then again I'm not speaking from experience and you guys do some crazy things.
Formula 1 Pinnacle F:50% R:15% / Smoked Side Markers/Modded Torque Insert/ Depo R LED Tails/ Neuspeed Springs/ Koni Strt/ aFe Pro-Dry S drop in
littleazn248 is offline   Reply With Quote
Old 12-27-2012, 03:01 AM   #30
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
i love my 6 pots i get amazing braking power.
Old 12-27-2012, 03:16 AM   #31
littleazn248
How are those endos lmfao.
Old 12-27-2012, 03:19 AM   #32
MaliciousMK6
MaliciousMK6's Avatar
I went through your build thread earlier, I didn't realize those for 6pot they are beastly!
Old 12-27-2012, 04:06 AM   #33
GTI_likeurmom
GolfMK6 Elite
Drives: Veyron 16.4
its not like that. no endos. i still have yet to upgrade the rears. moar braking!!!!!huhahahha.
Old 12-27-2012, 05:11 AM   #34
littleazn248
Craziness
Old 12-27-2012, 06:41 AM   #35
tman
tman's Avatar
Drives: around randomly looking for GTI's
Just what I was looking for!! Thanks!
Terence
Website | facebook | twitter | flickr
2012 Golf GTI 'Serron' (UG)
tman is offline   Reply With Quote
Old 12-27-2012, 10:44 AM   #36
quality_sound
Drives: '13 4-door Golf TDI
Doesn't ECS stock a caliper carrier? EVOMS used to as well. I haven't looked in a while. It's a great upgrade. I did it on my last Passat and it's noticeable to say the least.
quality_sound is offline   Reply With Quote
Old 12-27-2012, 10:54 AM   #37
quality_sound
Originally Posted by Modshack View Post
Good luck with the Install. These have been awesome on my car..
5.5 pounds lighter per side too which is a difference you can feel..
You will need the Porsche Vibration dampers as well (not cheap) as this set-up is naturally noisy
Pics and install: http://public.fotki.com/ttschwing/gt...brembo-brakes/
I'm not trying to be argumentative, but how are you feeling the weight difference? I know it's technically not sprung weight, and a reduction in inspiring weight is always good, but it's not rotating mass either. When I did this upgrade I didn't notice any difference other than the braking.
Old 12-27-2012, 11:51 AM   #38
hockeystar17mnj
Drives: 2010 GTI 2 Door MT
Unsprung weight such as calipers, carriers, suspension components etc assist with the compression and rebound of your suspension, think of it this way. take a 10lb weight and swing it left and right, now take a 5lb weight and swing it left and right... which one can you swing faster with less effort?
Same thing applies with unsprung non rotating mass. The less weight you have the faster your suspension can react to potholes, rapid left & right turns, braking, acceleration.
hockeystar17mnj is offline   Reply With Quote
Old 12-27-2012, 03:58 PM   #39
Modshack
Modshack's Avatar
/\ This!
I happen to be very sensitive to chassis dynamics so it's definitely a difference I can feel (you may not)..I've done this on other cars with similar results. Between my brakes and wheels I'm down 7.5 lbs per side. In Unsprung weight, this is pretty substantial..
Brembo:
Stock Boat Anchor:
Old 12-27-2012, 10:17 PM   #40
hockeystar17mnj
/\ This!
Brembo:
Stock Boat Anchor:
So aside from having 4 pistons & a monoblock caliper vs 1 piston floating caliper. They are 5.6lbs lighter than the stock setup!
With so many threads about "weight reduction" this definitely is one of the more important.
reducing Unsprung non rotating mass(calipers, carriers, suspension components) will help your suspension do its job better.
reducing unsprung rotating mass (calipers, wheels, tires) will help your car brake better, accelerate faster, & help your suspension do its job better.
Old 12-31-2012, 04:36 AM   #41
hockeystar17mnj
calipers are here. just waiting on lines, bolts fluid rotors & pads.install will be shortly after
Old 01-03-2013, 09:08 PM   #42
hockeystar17mnj
rotors arrived today,apikol lines are waiting at the rents house, picking them up tomorrow along with mounting bolts. still waiting on super blue fluid, rotor screws, triple square bit and vibration dampers from pelican parts.
last purchase will be stainless rear lines & carbotech pads
