Old 01-09-2013, 05:30 AM   #29
Winston57
Drives: 2012 GTI 5-Dr
Originally Posted by HardCandy View Post
Yes it will handle stage 1 power, is the short answer.
Some people have experienced clutch failure with no mods so it dose indicate that VW's clutch assemblies are not the best.
The issue with stg2 is the added torque from the after market down pipe, 20+ lb feet of added torque at various if not all of the rpm range is going to put a lot more stress on your tiny OEM vag clutch unit.
And from my understanding VW will replace your stock clutch under warante if it starts slipping even with a stg 1 or 2 car. I hade some issues with motor mounts and my friend / service writer for VW said the issue was clutch related and they would be happy to tear it apart but because my clutch is not OEM they would not warrantee the work or parts. had the clutch been the OEM unit it would be included in the warante.
The catch 22 to having VW replace a slipping OEM clutch on a stg2 or higher car is that likely within a very short period of driving under WOD your "new" OEM clutch will fail again.
Yes some peoples OEM clutch can hold stg2 even k04 without slipping (these are rare cases)
Most mk6 gti's OEM clutch disk/assembly including my own failed immediately after going to stg2 power.
As for a aftermarket clutch upgrade there are a few choices,
1.Drop in disk to be used with the OEM dual mass flywheel $400
2.clutch disk, pressure plate and single mass lightened flywheel. $1200-$1500.
Labor for the clutch should be around six hours $90- $140 per hour.
thread jack over.
Many Thanks! To OP - sounds like a Stage 1 (done well) for part of your $1k would be a good start!
Winston57 is offline   Reply With Quote
Old 01-09-2013, 07:25 PM   #30
Ina12K04GTI
Drives: 2012 GTI, APR K04/ supporting mod
If I only had $1000 I would go stg.1 & save until I could afford a decent suspension. Don't forget with an after market suspension, you still need a install and alignment.
Ina12K04GTI is offline   Reply With Quote
Old 01-10-2013, 09:16 PM   #31
intellistar
intellistar's Avatar
Drives: 2012 GTI 6MT DBP
Stage 1 w/ 91/93 and 100 OCT tune. Spend the remaining money on 100 OCT gas and enjoy. Next step item: summer tires.
intellistar is offline   Reply With Quote
