Old 01-09-2013, 06:51 PM   #1
jmk007
Experience With Camber Plates?
I am considering camber plates for the track but I don't want any serious negative issues with them on the street such as noise. Yes, I know TT control arms are another way to get some camber without any adverse effects on the street. However, I am doing NASA TT and aftermarket control arms cost me 4 pts while camber plates cost me none.
I have run Vorshlag camber plates on a '99 M3 with no noise or other problems on the street. Vorshlag and Ground Control also make camber plates for the Mark V/VI, as does H2 Sport. Does anyone have any experience with camber plates on the Mark V/VI? If so, what were your experiences in terms of street and track?
Thanks...
SCCA & Midwestern Council W2W, '91 Spec Miata, 2007
NASA TTD Champion, Midwest, '99 M3, 2009
Midwestern Council HSAX Champion, BS, '10 GTI, 2010 & 2011
jmk007 is offline   Reply With Quote
Old 01-09-2013, 07:33 PM   #2
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
to start this out, here are some links...
http://www.golfmkv.com/forums/showth...t=78846&page=2
http://www.golfmk6.com/forums/showthread.php?t=24023
Old 01-09-2013, 08:16 PM   #3
Erwan
I have Ground Control camber plates. Not too hard to install and I certainly didn't cut the top of the strut tower. You can adjust the camber from underneath with the GC camber plates and I got them set to -2 when getting an alignment (and haven't changed it since).
Better turn in at the track and faster tire wear on the street
Old 01-09-2013, 08:19 PM   #4
aw614
Drives: 2011 CW MKVI GTI
You didnt have to remove the struts to adjust and just could jack the car up to adjust the plates?
Old 01-09-2013, 08:20 PM   #5
Erwan
Yes.
Old 01-09-2013, 08:36 PM   #6
jmk007
Appreciate the links...the cutting the strut tower is a little disconcerting but apparently necessary if you want to access through the top. The Bruce had a good suggestion in the last link of only cutting a portion of the strut tower.
Old 01-09-2013, 08:46 PM   #7
jmk007
Other than increased tire wear, have you experienced any other drawbacks such as noise/rattling...etc.? If you wanted to, are you able to get more than 2 degrees camber on the GCs?
Thanks...
Old 01-09-2013, 08:49 PM   #8
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Do the camber plates raise the ride hieght at all?
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 01-09-2013, 08:58 PM   #9
Erwan
Thanks...
Some small amount of knock when going over bumps on the street.
I think you can go slightly more than 2 degrees (but not much more) with the 'street/touring' plates. They have a race version which allows you to do more and also more caster adjustment.
No.
Old 01-09-2013, 09:22 PM   #10
the bruce
the bruce's Avatar
Drives: Mk.V GTI
To be honest I don't know if cutting weakens stiffness at all. The plate itself
should be stiff enough. The need to cut it depends on:
- damper (damping adjustment knobs)
- camber only or camber + caster adjustability
- adjustability from underneath like Erwan's GC plates
PICS
Old 01-09-2013, 10:00 PM   #11
jmk007
Excellent info guys...much appreciated.
Old 04-08-2015, 08:14 AM   #12
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
BUMP from the dead..... had the ST XTA kit installed with camber plates, currently getting my strut mounts cut today to access the damping adjustment easier but mainly to access the 4 camber plate allen key screws to adjust camber on the fly from the top.
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
Old 04-08-2015, 10:35 AM   #13
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
Thank you for the inspiration!
YouTube: HYDE16
Old 06-20-2015, 05:36 PM   #14
stevenchkim
stevenchkim's Avatar
Drives: '10 CW 6M QT Hatch
Good stuff Ryan. Was googling Ground Control camber plates when I ran into the pic of you dremmeling the strut tower tops like Dave did, and your car looks British racing green in that light!
CTS K04+APR v3.1|Neuspeed P-Flo|UR TBE|Neuspeed FMIC|DG Sigma6|TWM M1 Brnz|Eibach F&R Sways|GC Camber Plates|034 Eng&Trns mnts 50-d|EurosportACC Strut&Xbraces|UR under brace|ECS front end skid plate|KW V2|MFactory Helical LSD|SB S3 Endr|RB4045 BBK|Advan RS 17x8 ET47|HK V12 255/40/17|P3 Gauge|Depo Tails&5k HIDs|stud conversion 14x1.5 to 12x1.5+Raicer lug nutz|Raicer LEDs
<--Flickr
stevenchkim is offline   Reply With Quote
