Old 01-28-2013, 10:46 PM   #29
jerome99
jerome99's Avatar
Has anyone seen this one?
http://www.ngpracing.com/store/index...roduct_id=7762
jerome99 is offline   Reply With Quote
Old 01-28-2013, 11:14 PM   #30
lilfleck
Drives: '11 GTI Autobahn, DSG
Originally Posted by jerome99 View Post
Yeah, that's the drop in disc that I mentioned in the original post.
Tapped with my thumbs
Old 01-28-2013, 11:17 PM   #31
jerome99
jerome99's Avatar
so DXD is southbend? if so then that is the same drop in but for $337.50
Old 01-28-2013, 11:19 PM   #32
lilfleck
Correct on all accounts. How much is shipping though?
Old 01-28-2013, 11:21 PM   #33
jerome99
jerome99's Avatar
LOL $21 so in total it is the same price as the one in the group buy
Old 02-01-2013, 09:49 AM   #34
lilfleck
Updated OP with more info & links.
Old 02-01-2013, 09:52 AM   #35
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Spec stage 1
350 ftlbs
http://www.ecstuning.com/Volkswagen-...tch/ES2575809/
Spec stage 2
410 ftlbs
http://www.ecstuning.com/Volkswagen-...tch/ES2575820/
Spec stage 2+
450 ftlbs
http://www.ecstuning.com/Volkswagen-...tch/ES2575821/
Spec stage 3
500 ftlbs
Spec stage 4
500 ft lbs
http://www.ecstuning.com/Volkswagen-...tch/ES2575825/
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 02-01-2013, 10:40 AM   #36
lilfleck
Thank you. Added.
Old 02-22-2013, 10:38 AM   #37
lilfleck
This deserves bumpage for folks to read.
Old 02-25-2013, 12:46 PM   #38
D Griff
GolfMK6 Elite
D Griff's Avatar
Drives: POORVETTE
So, I haven't gotten to reading all of the reviews yet, but are you guys going with full clutch kits all finding rev hang to be reduced? This is one of my biggest gripes with my car... Could help me justify stage 2 plus clutch... if I would get more powah and less rev hang.
www dot dat forum doe dot com
D Griff is offline   Reply With Quote
Old 02-25-2013, 01:07 PM   #39
MaliciousMK6
MaliciousMK6's Avatar
Rev hang is more related to throttle tapering and the emissions equipment on the car. Getting a single mass flywheel will help with this but will never completely remove it.
Old 02-25-2013, 01:58 PM   #40
lilfleck
If you want rev hang to be less apparent on any clutch setup, make sure your out of boost when you shift. Shifting while the car is in vacuum will allow RPMs to drop quick.
Old 02-25-2013, 02:15 PM   #41
D Griff
GolfMK6 Elite
D Griff's Avatar
Drives: POORVETTE
That's what I thought, I just noticed it was mentioned in the OP.
I've noticed this. When I let off the throttle, then shift, they drop quite quickly. I've also noticed that if I shift at higher rpms the revs drop quicker, I figure this is just the ECU reacting to my more spirited driving.
Old 02-25-2013, 03:28 PM   #42
mattdibart
mattdibart's Avatar
Drives: '13 GTI 6sp MT
Is it safe to say that when I go stage two I should be okay with just the drop in disk? I would rather spend the money I save on a LSD rather then getting a full clutch kit.
mattdibart is offline   Reply With Quote
