Old 02-25-2013, 04:11 PM   #43
lilfleck
Drives: '11 GTI Autobahn, DSG
Originally Posted by mattdibart View Post
Is it safe to say that when I go stage two I should be okay with just the drop in disk? I would rather spend the money I save on a LSD rather then getting a full clutch kit.
Yes, that would work. There are plenty of folks using it w/o any issues. The disc itself is rated for big power. As long as your flywheel and pressure plate are in good shape, everything should be fine.
Old 02-25-2013, 10:08 PM   #44
mr wrong
Drives: 2017 Golf Alltrack
Is this solution suitable for the stock dual mass flywheel and K04 applications?
What drop in disc are people using with the dual mass flywheel?
mr wrong is offline   Reply With Quote
Old 02-25-2013, 11:22 PM   #45
Brunkel
Brunkel's Avatar
Drives: 2013 UGM GTI; 6-speed manual
This is a great thread, and in a way it's making me reconsider going stage 1 due to the cost of replacing a clutch if need be. This is the first manual transmission car I've every owned and have only been driving stick for 4 months. So, I don't really have much to compare our clutch to and I went into buying a GTI biased b/c a bunch of friends sang praises about the GTI's manual transmission saying, "It's smooth, and real easy to drive." I find it kind of jerky from 1st to 2nd, and the clutch is smooth, but I wish it had more resistance. Considering some other hardware options to improve shifting besides dropping a boatload on a new clutch kit...perhaps a torque mount insert and a short shifter?
Build Thread
Hi-Def Detailing
Brunkel is offline   Reply With Quote
Old 02-26-2013, 10:41 AM   #46
lilfleck
Yes, and yes. Allset has been using this setup with his K04 for more than 20k (I think 30k).
As noted in the first post, South Bend Stage 3 Drop In and the Clutchmasters FX350/300 disc + CM Pressure plate.
You'll get smoother with the shifting. 1-2 is a tough one. Consensus has been either shift really early (just get the wheels moving) or apply some throttle when letting the clutch out in second. Become smoother/slower w/ you clutch modulation--you will get it.
I don't have any input on the insert or ss. I have yet to do those. It is on my agenda to tighten things up. I can't really feel the catch point well on my car and I wear a different pair of shoes everyday for work, gym, and weekends.
Old 02-26-2013, 11:22 AM   #47
Norsk
Drives: '16 DBP GTI SE PP 6MT with LP
I have been doing some research on NLS Clutch Shims. Chris from CBTuning mention about it to me.
Yesterday, he emailed me that the customer with a '11 GTI has the clutch shims installed last week and is very happy with the results. It has solve the issues he was having with SBC clutch.
For me - I am considering on putting the NLS shims along with the new CM FX350 hopefully around in March.
NLS Clutch Shims:
http://nothingleavesstock.com/online...30&id=13912883
http://forums.vwvortex.com/showthrea...t-now-for-sale!
Hyde16 has those as well - http://www.golfmk6.com/forums/showthread.php?p=744654
Norsk is offline   Reply With Quote
Old 02-26-2013, 11:36 AM   #48
lilfleck
what do these do? I'm not sure I entirely understand how it works.
Old 02-26-2013, 11:43 AM   #49
Norsk
To solve the drifting, shifter getting stuck in reverse, 1st gear, or 2nd gear. It would crawl forward or hard to shift. Clutch wouldn't disengage sometime.
I have SBC Stage 2 Daily Kit, it's hard to shift, shifter get stuck in reverse, 1st or 2nd or 3rd gear. It's not friendly in heavy traffic. Higher engagement point. Sometime, it gets sticky. That's why I was considering about getting the Shims to be installed with the new FX350 kit.
Old 02-26-2013, 12:23 PM   #50
lilfleck
I've never experienced this before... I would imagine if you have an aftermarket clutch setup, it shouldn't either...
Anyone know how this actually solves the problem and what the actual problem is?
Old 02-26-2013, 12:31 PM   #51
realcyberbob
realcyberbob's Avatar
I went from stock transmission, to just short shifter, to short shifter + FX350 clutch kit, to short shifter + FX350 + ECS Dogbone/Torque mount insert.
The short shifter alone made shifts much more crisp, it was a huge difference and was one of my favorite mods. The addition of the FX350 was also a big difference, mostly in performance of the clutch and not really any change in the shift feel (you can read more here: http://golfmk6.com/forums/showthread.php?t=51717). By adding the dogbone/torque mount insert it increased the vibrations but throttle response seems better. The shifter might be a little more crips as well.
Old 03-05-2013, 09:28 AM   #52
lilfleck
Updated with more info on Sachs Stage 3 Kit option:
*I found a review of SACH's stage 3 daily kit. I'm not sure if its a 100% kit from Sachs as it uses other manufacturers:
Sachs Stage 3 Daily clutch - this is same cover in South Bend Stage 3 Kit
Clutchnet Organic sprung hub disc ( 6 rivits on hub vs 3 on the OE sachs)
Four Season Steel Billet FW for TSI ( 8 bolt flange) - 18 Lbs
Luk release bearing
Added MaliciousMK6's review.
Old 03-08-2013, 11:20 AM   #53
lilfleck
Added Mustache Rash's video review.
Old 03-08-2013, 10:17 PM   #54
kern417
Drives: '09 Jetta
fx400 initial impressions
do a burnout.
Old 03-08-2013, 11:01 PM   #55
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Kern, do you happen to have 42dd shifter bushings or any modified/ aftermarket side to side bracket?
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 03-08-2013, 11:20 PM   #56
jerome99
jerome99's Avatar
looks like your side to side linkage is binding. they should be able to fix that relatively easy.
2011 GTI Build Thread
K04, Godspeed DP, Godspeed IC, CM FX-350 w/DMFW, H&R Coilovers, Boxter-S BBK,
jerome99 is offline   Reply With Quote
