jerome99
alright i'm forever alone so i don't have anyone that can test the shifter while i watch. i did move my intake and remove the battery tray to get to my shifter links to install the 42dd bushings today. with the clear open area i played with the shifter mechanism and it looks like when it goes up (which i'm sure transfers to shifting right on the shifter) it drops back down to the middle point. when i push it down (which i'm assuming left on the shifter) it doesn't bounce back up. i disconnected the linkages to install the bushings and now when i play with the shifter, it acts as it should. so if i look at the linkages in my hand, how would i be able to tell it's binding on something? is it possible that it's the shift lever itself? i'm kind of at the point where if i install it back in the car and it works, i'm just going to pretend it didn't happen. but while they're out i'd love to know what to check specifically.
hope that all makes sense
well look for a lack of grease on all the rub points and make sure you lube up the slider and the pivot point that the side to side linkage fits on. throw that baby back on and see what happens
