Old 01-23-2013, 04:53 AM   #1
ahuang1983
Drives: Golf R
slight vibration on the brake pedal
Hey guys
I don't know what happened. But ever since I got my stage 2+, I have been getting slight brake pedal vibration that comes and goes randomly. Its not bad, but it feels like when you have clutch on engage point and holding on the brake pedal. Not as shacky but that's the closest feeling I can explain. Any ideas why? Couldn't find any answers on the forum.
ahuang1983 is offline   Reply With Quote
Old 01-23-2013, 07:49 AM   #2
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Originally Posted by ahuang1983 View Post
Hey guys
What sort of intake are you running? Check to make.sure its not rubbing on the lines.
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 01-23-2013, 08:12 AM   #3
ahuang1983
Drives: Golf R
I am running the cts intake but it was fine before the tune. Actually when I got the tune done, they gave me a prototype heat shield and installed it for me. At first I thought the heat shield was the issue, so I got them to remove it today. But the vibration is still there. Also, I think the fsi setup is a bit different from tsi. All the vibration threads I found was tsi with intake.
Old 01-23-2013, 12:54 PM   #4
davesxx01
davesxx01's Avatar
Drives: 2013 .:R
I had it also. It's your tube resting on top or really close to the brake reservoir cap. FSI and TSI both have the exact same problem with A/M intakes.
'13 Golf R
My GTI 313 WHP! Build thread
Old 01-23-2013, 04:13 PM   #5
ahuang1983
Drives: Golf R
Sorry what does it look like.
Old 01-23-2013, 04:26 PM   #6
davesxx01
davesxx01's Avatar
Drives: 2013 .:R
No problem, it's at the 90* bend in your intake tract. (below) The intake pipe rests on it and vibes through your brake pedal.
Easy fix! Just loosen the clamps at both ends and pull up slightly on the pipe. Be sure to leave a couple fingers clearance between the pipe and the cap.
PM me your cell and I'll send you a couple pics if you want.
'13 Golf R
Old 01-23-2013, 04:31 PM   #7
menios80
menios80's Avatar
Drives: golf mk6 gti
This is the place the metalic brake lines..if you see in the second photo mine was scratched from the intake..and i had the same problem..
Στάλθηκε; από το; GT-I9300 μο;υ; χρησιμο;πο;ιώντας Tapatalk 2
menios80 is offline   Reply With Quote
Old 01-23-2013, 08:39 PM   #8
ahuang1983
Drives: Golf R
Thanks guys! Ill try it out tonight!
Old 01-23-2013, 08:43 PM   #9
Bino
Bino's Avatar
Drives: 2010 White GTI 2 Door
I had the same issue with my ape stage 1 and 2 pipe. I checked all my clearances and it went away. You should be fine after the small adjustment.
Bino is offline   Reply With Quote
Old 01-25-2013, 12:34 AM   #10
ahuang1983
Drives: Golf R
Thanks guys! Its fixed now! We should sticky this for tsi/tsi people with aftermarket intake!
