Old 01-30-2013, 01:21 PM   #1
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
Intercooler Discussion – Looks can be Deceiving
In 2006, APR began development of the APR Front Mount Intercooler System for VW's 2.0T engine. This came after being commissioned by Volkswagen of America to create the ultimate performance hardware for their R-GTI Concept car. A North American Nation Wide Tuner Challenge was held by VW and participation was extended to APR and other tuners in the industry. The results, which were overseen by the SCCA and several automotive magazine editors and journalists, proved APR powered vehicles set the bar by a large margin in all performance categories and the APR prototype intercooler and Stage III turbo system were made available to the public.
In recent years, many intercoolers similar in appearance have entered the market. This came shortly after several overseas companies began copying designs and selling them for pennies on the dollar with any company's name on the hoses and end tanks. Many of these items can be found online using APR's own product photography, but the actual product is a far cry from the original in almost every way, shape and form.
The purpose of this thread is to address the differences between APR's intercooler in terms of performance, quality, fitment, support and more. This will not only help you to spot a fake being passed off as an APR intercooler, but also see the quality and fitment differences of the USA-manufactured APR Intercooler and the competition's overseas-manufactured intercooler. Our testing data will further illustrate the impact on performance, which proves looks can be deceiving.
Intercooler Performance Testing:
To measure the performance difference between two intercooler cores, APR conducted back-to-back testing, on the same day in order to control data as tightly as possible. The test vehicle was fitted to APR's dyno with the room's exhaust and coolant fans set to a controlled value. Six dyno tests were conducted while data logging various engine variables in real-time using APR's ECU Explorer software. Data not available from the vehicle's ECU, such as the pre-intercooler boost and temperature, were collected with extra sensors installed before the intercooler's inlet.
Starting Conditions (APR Intercooler vs “Similar Looking” Intercooler):
  • Ambient Temp: 84.9 °F vs 81.1 °F
  • Ambient Baro: 29.3 in-HG vs 29.3 in-HG
  • Ambient Humidity: 36% vs 35.3%
  • IAT in the Intake Manifold: 94.1 °F vs 86 °F
Starting conditions were nearly as identical as possible. However, the "Similar Looking" Intercooler core tests were conducted in more ideal conditions with an intake air temperature 8.1 degrees less. Ambient temperature was also 3.8 degrees cooler.
Testing Information:
  • Dyno Run Length: 12 seconds
  • Time Between Runs: 5 seconds
  • Number of Runs: 6
  • APR Testing Time: 3:38:47 PM
  • Competitor Testing Time: 5:18:09 PM
The APR Intercooler was tested first. Upon completion of the tests, the vehicle was removed from the dyno and taken to the workshop. The APR Intercooler was removed and the competitor's intercooler was installed. Finally the car was reconnected to the dyno and testing continued.
Results:
The APR intercooler core preformed dramatically better than the cheaper alternative.
By 7,000 RPM, on each of the six runs, intake air temperature was no greater than 6 °F from the starting IAT of each run and during three runs were actually 4.05 °F LESS than the starting temperature of each run. The competitor's core didn't fair so well, seeing as high as a 17.55 °F increase in intake air temperature from start to end on a single pull. See graphs posted below for IAT during each pull.
By the sixth back-to-back run the APR Intercooler had no problem reducing post IC intake air temperature at 7,000 RPM. Temperature dropped from as high as 330.4 °F down to 103.55 °F. However, the cheaper alternative struggled to reduce intake air temperature below 120 °F by the third dyno run, despite better starting and ambient conditions.
A six run average showed the APR Intercooler starting with IAT's at 103.55 °F, which dipped as low as 100.175 °F around 5,000 RPM, with a final temp of 104 °F by 7,000 RPM. The competitor's intercooler showed a six run average starting IAT of 103.33 °F which rapidly increased to 114.35 °F.
The graphs below show the post-IC intake air temperature for the APR intercooler and the competitor's intercooler from each dyno pull.
Manufacturing, Material and other Specifications:
The all aluminum investment cast end tanks of the APR Intercooler are cast in the USA to ensure a repeatable design, high tolerances and direct access to our casting partners should an issue ever arise. The raw end tanks are each machined in house at APR. The inlet and outlet pipes on the APR intercooler are much larger than stock and larger than our competition's.
The long and smooth neck on the inlet and outlet allow for a clean mounting surface to avoid boost leaks.
APR machines unnecessary aluminum from the side mounting points to lower the intercoolers weight as much as possible. The end tank castings were designed not only for fitment and airflow, but also weight savings. This is why the APR intercooler's end tanks are sharp and geometric compared to the rounded generic design of the competition's intercooler. The APR Intercooler is around 5 LBS lighter than the competition's.
The APR intercooler core is manufactured in the USA to APR's exact specifications. In this application a staggered and louvered fin design is the best choice, which is backed up by our internal testing of several core designs. When selecting core fin density, pressure drop must be considered. Increasing density will result in more pressure drop across the core, which means the turbo will work hard to create the same pressure in the manifold compared to a freer flowing core.
Through testing of several different densities, APR found a balance between cooling and pressure drop to achieve the best possible results. A dense core was most beneficial in this application due to the intercooler core’s dimensions as well as the end tank design. Through CFD analysis, APR’s engineers designed end tanks which promote use of the entire intercooler core, rather than the first few rows. This was further backed by the density of the core, which promotes filling of the entire end tank plenum for even charge air distribution. Intercooler width was carefully selected to maximize surface area without disrupting end tank design as a wider core design showed less even distribution of charge air across the upper portion of the intercooler.
The APR intercooler core is 16.25" tall, 2.25" thick and 23.2" wide.
Core Thickness Comparison
APR Intercooler Core Overview
APR Intercooler Core Ambient Air Path
Competitor Core Front Ambient Air Path
APR Intercooler Core Charge Air Path
Small manufacturing anomalies and defects in the massive intercooler core's surface can lead to small boost leaks which left untested are extremely difficult to locate. APR guarantees leak proof operation, as each assembled unit is pressure tested to 30 PSI.
The specific design of the APR intercooler hoses allows for smooth airflow into and out of the intercooler. The multi-ply hose material will not swell under boost and the stepped APR Easy-Flow Silicone hose design allows for a smooth airflow transition from one pipe to the other. The competition's hoses typically do not feature this design addition, resulting in turbulent airflow as seen below.
Casting Quality:
Words cannot describe the absolutely tremendous difference in quality between the castings of the APR Intercooler and the competition's. Every edge and surface of the APR intercooler is razor sharp and free of defects while the competition's is riddled with casting flaws, loose tolerances, voids, extra casting pieces ready to fall off and enter your engine at a moment's notice and other strange casting attributes associated only with the worst practices in the industry. Expect the inside of an APR intercooler end tank to be smooth and specific for routing intake air while our competition's are littered with extra mounting knobs producing into the design which disrupts smooth airflow.
Competitor Core End Tank Casting Issues
Poor casting quality extends beyond just looks. It impacts all of the following:
  • Performance – Airflow through end tanks
  • Fitment – Poor tolerances
  • Weight – Extra unnecessary casting attributes
  • Leaks – Casting voids are prone to leaking
  • Engine Safety – Casting flack can easily break free and enter your engine
Competitors have attempted to hide these defects from customers through painting, power coating, sanding and polishing end tanks, but this only superficially mask the issues.
Fitment:
The APR Intercooler fits perfectly. The competition’s is not even close. The following areas are known issues with the competition’s intercooler:
  • Every mounting point
  • Every screw hole
The competition's intercooler will loosely fit into each mounting point while other factory components must be bent to line up with the screw holes. In some cases, the screw holes are so far off or filled with excess casting material, they have to be retapped before they can be installed increasing labor costs and reducing the shop's profitability which will have to be made up in other areas.
All mounting points and screw holes on the APR intercooler are in the correct location. They are machined in house to ensure proper sizing and proper thread pitch.
With very little communication or factual exchange of information between our competitor's and their overseas suppliers, fitment issues will pop up all the time. There's no fixing the issue either as the competitors don't own the tooling used to cast each piece. They are simply purchasing parts from random vendors, many of whom have actually copied bad design, further pushing tolerances out of spec. Depending on the factory pumping out the parts, it will either fit one way or another way.
Support:
Included with every APR Intercooler System is a printed and spiral-bound instruction manual covering each step of the detailed install. Most competitors include no directions at all. If you ever run into a problem, you can simply call APR for support as we currently staff more employees who have installed an APR Intercooler than many companies employ in their entire company.
The APR Intercooler also comes with a lifetime warranty which is an important aspect often not discussed. Many companies have the ability to offer "lifetime warranties" but many of these companies do not stay in business for long periods of time. Once they're out of business, you'll have no way to get a replacement part should you ever need one. It's not uncommon to hear of a customer getting into an accident and in the process ripping a hose or damaging some other component. In those cases, we can quickly and easily ship the customer a new hose to aid in the repair but for the companies out of business or the ones purchased through cheap EBay outlets, there are no replacement parts when the need arises.
Finally, if the install is not for you, no worries! APR's vast dealer network makes installation at a local shop easy. For those who don't have an APR shop in town, our included instruction manual makes the process a walk in the park, saving you money spent on unnecessary labor.
Power:
A performance intercooler system needs to dramatically lower intake air temperature to a level that’s acceptable for creating safe and reliable power. It needs to continue doing over a long period of time without “heat soaking.” Heat soak is when an intercooler becomes so hot it’s unable to cool the intake air effectively.
There will be many who will look past casting quality, fitment flaws, lack of support and so on simply to save a few dollars and many may be under the impression the data we've shared above does not translate to any real world differences in power.
During our testing on the dyno, we were able to prove without a shadow of a doubt that the performance differences are massive. As mentioned above in the testing notes, each intercooler was tested back to back without a cool down period to measure temperature changes, vehicle operating variables and most importantly, power loss. Analyzing the average power losses after the turbocharger spooled showed an incredibly small 6.8 WHP loss across the power band with the APR intercooler system. However the other core lost an average of 30.1 WHP across the power band.
On average, the APR intercooler was able to retain 23.3 WHP over the cheaper alternative which throws it into the same league as a major upgrade even though it's being compared to what many would already consider an "upgrade."
This industry is filled with many trick and gimmicks but you will not find this when you purchase APR products. This is why you often hear the bitterness of poor quality is remembered long after the sweetness of a low price is forgotten.
Old 01-30-2013, 01:26 PM   #2
GunKata
MILFn00dzHunter.com
GunKata's Avatar
Everybody knows GunKata > *.*
No GunKata, no care.
Chicago Car Network
I can haz 350z racecar?
Old 01-30-2013, 02:41 PM   #3
smrtypants44
smrtypants44's Avatar
Drives: 2012 135i
Right, cause a giant "comparison" vs The Intercooler Which Shall Not Be Named, which is actually a thinly disguised Ad for the APR intercooler isnt a gimmick. I mean seriously APR, this belongs in the Vendor section. If you want me to take you seriously put up a scientific test vs other branded intercoolers and we will talk.
Old 01-30-2013, 02:44 PM   #4
Arin@APR
Arin@APR's Avatar
This is 100% a technical and scientific test.
This is an ADVERTISEMENT for APR because the results were extremely favorable towards APR. There's no need to disguised that fact and it's far from a gimmick.
Old 01-30-2013, 03:26 PM   #5
KurtP
KurtP's Avatar
Drives: diesel jeep
Looks good Arin. Core quality plays a huge roll in how well an intercooler works.
huh?? How does adding the name of the other company suddenly make it "scientific"??
What were you expecting to see in a scientific test of intercoolers other than horse power and pre and post temperature?
They put every relevant number you could want to see in an intercooler test in this thread justifying the higher cost of an APR unit. Had Arin actually listed the name of the company who's intercooler they used, 5 people with that one would already be in here complaining that Arin "bashed competitor x".
Im pretty sure at some point someone who bought the intercooler they used can come in and say "uh, hey, that looks like mine, which is brand x."
There is so much more than just flow that goes into what makes a quality intercooler important. Pressure drop and temperature are huge. The more temperature drop the intercooler provides and how quickly the materials used bleed off heat is what determines how hard you can push the motor with your given turbo set up/fuel. If the intercooler has excessive pressure drop, doesnt bleed off heat well, or doesnt cool as well, the motor will not be able to run as aggressive a timing curve as it could otherwise.
There is a reason good stuff costs more than not as good stuff.
Given all the talk about SPM parts of late, I dont think this post from APR is ill timed or unwarranted. No one at APR is bashing any other company in this post. They are just asserting that their stuff is the best on the market and they arent afraid to charge a higher price that the quality/performance justifies. They aren't trying to be the cheapest.... If the added quality/performance isnt worth it to you, then hit a lower cost vender or ebay.
KurtP is offline   Reply With Quote
Old 01-30-2013, 03:36 PM   #6
allset
allset's Avatar
ive gone through 3 IC set ups. APR's IC consistantly logged the lowest IAT's in multiple back to back runs.
The physical quality is easily identifiable at first glance. I bought a scope to use for diag and fishing out the occasional lost screw in the engine ( im 1 for 1 on that).
I also scoped inside the hot and cold side port stems of the APR IC; pretty far in as the scope has a 36" extension and i can confirm the above info of the interior.
Old 01-30-2013, 03:45 PM   #7
Arin@APR
Arin@APR's Avatar
Anyone worried about the backorder need not worry any more. Here's a couple hundred intercoolers in production. Each box holds quite a few cores oh and when they ship out to you, we don't pack them in peanuts, we now use specifically cut foam to ensure it's not damaged during shipping.
Boxes of Intercooler Cores (use your imagine to count the number of cores in each box):
End Tanks:
Welding:
Units up for cleaning and testing:
End Tank cutouts for shipping:
Several units headed out the door:
Old 01-30-2013, 05:52 PM   #8
lamb110
lamb110's Avatar
Drives: Your mom
Oh just an FYI for everyone... You don't need a bore scope to look at the inside of APR's intercooler, you can use your iPhone... Yea the inlet / outlets are that fuckin big.
I fap to porn. I wont lie.
Old 01-30-2013, 06:48 PM   #9
Arin@APR
Arin@APR's Avatar
Old 01-30-2013, 07:02 PM   #10
lamb110
lamb110's Avatar
Drives: Your mom
iPhone picture:
Old 01-30-2013, 07:02 PM   #11
J-Cooz
J-Cooz's Avatar
Drives: 2010 Golf Sportline
Sick. Quality product made in the USA. Any haters can guy buy Chinese POS copies that have no testing or background knowledge behind them.
If my car had one, it would be an APR.
You sound like a clueless trolling piece of shit.
J-Cooz is offline   Reply With Quote
Old 01-30-2013, 07:40 PM   #12
turboteig
turboteig's Avatar
Drives: 2013 Golf R
Cool
Agreed, a little out of my budget or I'd own one.
turboteig is offline   Reply With Quote
Old 01-30-2013, 07:41 PM   #13
Arin@APR
Arin@APR's Avatar
I remember saving my pennies for one when I was a customer. I have to say, the purchase felt good all said and done. : )
Old 01-30-2013, 10:20 PM   #14
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
I want this intercooler
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
