Old 02-11-2013, 12:57 PM   #1
vwgti2.0t
Drives: 2011 CW GTI
*****2.0t build thread
Stock Info
2011 VW GTI 2.0T
Candy White
Sunroof Package
6MT
RCD-510
18" Detroits
Engine Mods
APR Stage 3+ (GT30)
APR Injectors
APR Modular Boost Tap
Aquamist HFS-4 V3.1 Direct Port Meth
ARP Head Studs
AWE Turbo Outlet Pipe
BFI Stage 2 Motor Mount
BFI Stage 1 Full Trans mount
BSH Throttle Body Pipe
Cobb MAF Block Off
Deka ETX16L/M6 to SAE Adapter/ Custom Mount
Eurodyne Tuned by myself
Fluidampr Crank Pulley
Godspeed Intercooler and Hoses
IE Forged Rods
K&N Large 6" Filter
Magnaflow 3" Catback
N2MB WOT Box
NGK BKR7EIX Plugs @.028
Powerflex Small dogbone bushing
R8 Coilpacks
Spectre 3" Velocity Stack
Synapse DV
TTRS LPFP Controller
Vibratechnik Subframe amount
6.6 Bar Fuel Filter
Transmission Mods
Diesel Geek Six Sigma Short Shifter
FFE Positive Engagement bushings
OEM Dual Mass Flywheel
OEM Metal Shifter Cable Bracket
OEM Steel Shift Forks (1-2, 5-6)
Peloquin LSD
Southbend upgraded pressure plate and stage 3 disk
USP Stainless Clutch Line
Suspension/Tires/Wheels
BF Goodrich G-Force SportComp2 225/40R18 Tires (summer)
Bilstein PSS (B14) Coilovers
BSH Rear End Links
Custom Under Body Brace
Custom 3" Frame Notch
H&R 24mm Rear Sway Bar
H&R 26mm Front Sway Bar
Motorsport Hardware Wheel Stud Kit
Neuspeed RSE07 Bronze 18x8 ET45
OEM Detroits on Michelin X-Ice (winter)
OEM TT Strut mounts and bearings
Spulen Adjustable Endlinks
Tyrolsport Deadset Kit
Unibrace XB
Whiteline WALK KCA-316
Whiteline W0503 Front Position FLCA Bushings
Whiteline trailing Arm Bushings W0504
Brakes
Stoptech Slotted Front Rotors
ECS Drilled/Slotted Rear Rotors (Will be converted to Stoptech's at some point)
Porsche 4 pot Brembo's (NQSBBK)
StopTech Street 309.11070 front pads
StopTech Street 309.14560 rear pads
USP Motorsports stainless steel braided brake lines
Interior
Aesthetic Creation Dummy Stickers
LED Door Puddle Lights
NewSouth RedLine Boost Gauge
NewSouth Vent Pod
OEM Euro Switch
OEM Dash Cubby
OEM CarGo Rear Liner
OEM CarGo Rear Liner Velcro Blocks
OEM GTI Monster Mats Kit
OEM Euro Cupholder
OEM Aluminum bottle opener
OEM Aluminum glove box handle
OEM USB Button Charger
Raceseng Slammer Engraved Shift Knob
Removed Visor Airbag stickers
USP Interior LEDs 6000k
Valentine V1
Audio
Alpine S-Type 6.5" Components up front
Custom Side Mount Fiberglass Sub Box
JL CleanSweep
Memphis 12" Subwoofer (Dual 4 ohm in parallel)
OEM RNS-315
OEM Backup Camera
Rockford Fosgate R400-4D
Rockford Fosgate R250-1D Sub Amp
SOT-976 Wire Harness
A Ton of 16 Gauge Wire
2 Gauge Power Wire
Exterior/Cosmetic
Color Matched Emblem Inserts
Custom Hidden Hitch
DeAutoKey LED Reverse Light
DeAutoKey LED Rear Turn Signals
Ed's Dark Red LED Tailights w/ fog
Ed's Black housing Xenon Headlights
Gloss black front and back emblems
Gloss Black bumper center section
Gloss black grill stripes
LED Mirror Puddle Lights
Morimoto Elite 5000K HID's
Nokya 2500K yellow Fog Lights
OEM Euro-Lip CW
OEM Euro Bumper
OEM Backup Camera
Plasti-dipped rear reflectors
Racing Dash License Plate LED's
Yellow Lamin-x Front Fogs
35% Llumar Tint all around
VAG-COM
Confirmation honk off
DRL disabled
Gauge sweep
Seatbelt chime off
Teardrop wiper
Window up/down with FOB
Other stuff I can't remember...
Old 02-11-2013, 05:05 PM   #2
Kyle Butler
Kyle Butler's Avatar
Drives: The wife's 4cyl Accord
Looks great! Really dig the engine bay and bikes.
Kyle Butler ::.
OEM Golf R Tails : VW Karthoum 18" Hankook Ventus v12 ::.
Kyle Butler is offline   Reply With Quote
Old 02-11-2013, 05:15 PM   #3
FLtrooper
FLtrooper's Avatar
Drives: No Mas VW! Hola Audi!
Nice kwaks!
My OEM+ K04 MK6 GLI
Sticking to two wheels from now on!
FLtrooper is offline   Reply With Quote
Old 02-11-2013, 08:00 PM   #4
swfloridamk6
swfloridamk6's Avatar
Drives: 2010 CW MK6 Manual
Looks good. #notvortexapproved.
swfloridamk6 is offline   Reply With Quote
Old 02-11-2013, 08:34 PM   #5
dbutcherMK6
Drives: GTI MKVI
how did you get your engine bay to look so organized and clean?
dbutcherMK6 is offline   Reply With Quote
Old 02-11-2013, 08:38 PM   #6
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
oooooh the black wheels looks nice
Old 02-11-2013, 08:45 PM   #7
vwgti2.0t
Drives: 2011 CW GTI
Thanks!
Originally Posted by FLtrooper View Post
Nice kwaks!
Love them
Haha I guess not. I love the vortex style thing, but I'd rather go around turns fast
Not sure. Just clean really. Could be the picture also.
Thanks! Can't wait to get them on.
Old 02-13-2013, 07:34 PM   #8
vwgti2.0t
Drives: 2011 CW GTI
HPA dogbone mount installed. I really like it a lot. What I though before was slop/jerkiness from the clutch was actually the POS BSH insert I had. Everything feels much tighter and I feel NO vibrations, even with the BFI motor/trans mounts. HS Tuning has these in stock!! By them!!
And here's a little video on how bad it sucks to try and launch with snows. But at least here's no wheel hop
http://youtu.be/o058MtVUJ8I
Old 03-04-2013, 08:48 PM   #9
vwgti2.0t
Drives: 2011 CW GTI
Some things happened today!
Cleaned wheel wells and turned the coils back down. Fresh painted 710's go on Friday
Also picked up some maintenance supplies. Oil/filter. Updated timing tensioner/sealant/crank bolt. And four injector kits in case any of them come out when I take the intake off to clean the valves. Also have 3 bottles of rbf600 to flush my brake fluid. It's going to be a long Friday to say the least!
Old 03-05-2013, 12:22 AM   #10
GreasyGinzo
GreasyGinzo's Avatar
This doesn't look like its installed all way in the cavity. I may be wrong because I haven't been under my car since mine was installed but pretty sure it was flush with the bottom of the subframe
Build Thread / Life Story
Old 03-05-2013, 08:19 AM   #11
vwgti2.0t
Drives: 2011 CW GTI
You are the second person to say this, but I am positive it's in all the way. Thanks!
Old 03-05-2013, 10:59 AM   #12
GreasyGinzo
You should send that picture to HPA and see what they say.
Old 03-05-2013, 11:13 AM   #13
vwgti2.0t
Drives: 2011 CW GTI
It works fine and it's fully up against the dogbone and the bolt is torqued to spec. It's just the picture.
Old 04-23-2013, 01:56 PM   #14
vwgti2.0t
Drives: 2011 CW GTI
Well I haven't updated this for a while.. First post is all updated with current mods. Since last time, I've completed and installed the brace I made for under the car. Also installed a Deka ETX16L lightweight battery and made a custom braket for that. Finally I ordered a Unibrace XB today. Only thing left for this year is an alignment and new tires!
