Old 04-29-2010, 01:08 PM   #1
chapusin
chapusin's Avatar
Drives: and drinks
rough idle?
Not sure if I should call it a rough idle because I believe that definition is used when your idle rpm's are jumping up and down, but has anybody else noticed when you get to a stoplight, the idle is so smooth but then suddenly rough little spots appear? they are definitely noticeable, it's like if you're driving through a road made of silk and there are some rocks here and there, sorry that's the best explanation i could find I switched to only tier1 gas thinking that was the problem but it's still the same
chapusin is offline   Reply With Quote
Old 05-07-2011, 10:55 PM   #2
johnny_p
johnny_p's Avatar
Sorry to bump an old thread, but..
Mine does this. Have you taken it to the dealership? I don't get any CELs, the engine has intermittent shaky spots at idle. Drives fine otherwise.
johnny_p is offline   Reply With Quote
Old 05-25-2011, 07:31 PM   #3
kthor703
kthor703's Avatar
I've been having some idle problems too a few times randomly. It dips to 600 and stays until I tap the throttle. Then it idles normally. What's up?
Old 05-25-2011, 07:35 PM   #4
dbest6808
Drives: 2010 GTI DSG
I've noticed this as well, mostly when starting up the car in the morning on a cold start. it kinda twitches a few times randomly then smooths out. I don't think its any problem if your revs are dropping though that may be an issue but I experience this with steady rpms.
APR Stage 2 NTP (V1.2), Carbonio Stage 1+2 Intake, AWE DP, S3 Intercooler, 18" Gunmetal VMR 701
dbest6808 is offline   Reply With Quote
Old 05-25-2011, 08:49 PM   #5
hondadude
Drives: 2010 MK VI Gti
Mine is a little rough in the morning with a cold start, but usually evens out pretty quickly.
hondadude is offline   Reply With Quote
Old 05-26-2011, 12:34 AM   #6
MEGTi
MEGTi's Avatar
Drives: 2010 GTI Black 4dr 6mt
I've had this happen twice and both were completely my fault. First was the scariest... stalling and low RPMS. Turns out my BSH stage 2 pipe was disconnect toward the back heading to the turbo.. (kinda sucks cuz you are clamping 2 rubber hoses... one wants to slip out or buckle). Ok, second problem was my boost gauge. I didn't buy one of those nice boost taps I just bought the standard kit... well the rubber hose from it touches my carbonio intake and melted a boost leak into it. Just fixed that the other day... good luck those have been my 2 scares.
APR Stage II.2 - 35% Tints - Carbonio Intake - BSH Stage II Intake - 42DD Downpipe - Borla Exhaust - R Tails - NewSouth Vent Boost Gauge/Forge Tap - Forge Spacer - Rockford T400-2/JL12w3 + Sundown 125.2/Kappa Perfects6.1
MEGTi is offline   Reply With Quote
Old 11-09-2017, 08:17 PM   #7
Fyodor Dostoevsky
Drives: 2013 MK6 GTI 6MT Cdn Base Model
chapusin & johnny_p:
Did you ever find out the cause of the rough idle problem you posted about back in 2015?
I have a similar issue with my 2013 GTI. Mine is 100% stock and only 17k miles (27.5k km). During idle, normally when the engine is warm, sometimes the engine 'stumbles' every few seconds, as if a cylinder didn't fire correctly. But there are no MILs lighting up on the instrument cluster. However, sometimes the engine runs perfectly smooth as well. The dealer did a 'scan' and reported "no codes stored".
Fyodor Dostoevsky is offline   Reply With Quote
Old 11-09-2017, 10:11 PM   #8
BlueE30
BlueE30's Avatar
Drives: 10' TR GTI 6M and an E30 325 Turbo
Likely coils that are on their way out.... I believe most rough idles are coils or carbon build up... Replace your ignition coils with R8 ones and you'll never have to worry about it.
2010 TR GTI APR Stage 1 Fully Loaded, APR Carbonio, R8 coils, Rotiform 19's, Koni Coilovers, CTS subframe reinforcement kit, CTS Billet Torque Arm Insert, CTS rear subframe bushing kit, LED Golf R Tail Lights, Xenon Headlights, VCDS changes (DRL's, windows, gauge sweep, etc) and timing chain tensioner updated!
1987 BMW E30 325 Turbo - Too extensive to list.
BlueE30 is offline   Reply With Quote
