Old 03-13-2013, 12:42 PM   #1
erball
erball's Avatar
Drives: Rolling burnouts
DIY: TSI Timing Chain Tensioner Update
Here is a simple DIY for updating your timing chain tensioner. This was done over the course of an afternoon with both myself and Eurocars from MKV.
I would not recommend doing this job without the factory tool to hold the cranckshaft (necessary to remove the crankshaft bolt), or a 1/2 impact gun. Removing the crankshaft bolt is very difficult without it. I would also not recommend doing this without very short triple square bits (necessary for removing the lower engine mount).
This is not an idiots guide, and if this makes you feel nervous, I would avoid doing the job yourself.
Remove noise pipe:
Pull off washer fluid fill tube:
Unbolt the overflow tank and move it out of the way:
Pull the fender liner & remove Turbo outlet pipe:
Drain Oil:
Support the engine with a jack and block of wood:
Remove passenger side engine mount:
Remove engine mount bracket: (going to need short triple squares here for the three bolts)
Remove dipstick: (2 torx screws)
Tape over dipstick hole to avoid debris entering the oil pan:
Remove serpentine belt:
The notch on the crank pulley will have to line up with the mark on the front cover: (this puts cylinder one to TDC)
Mark on crank pulley:
Remove crank pulley and unbolt front cover. There is one bolt underneath the serpentine belt tensioner that is quite difficult to get to. You have two options: remove the belt tensioner entirely, or (the much easier method), remove the pulley itself, and retract the tensioner to have enough clearence to get to the last bolt holding the cover on. Zip tie timing chain together and pull tensioner:
Install the new tensioner and pull the retaining clip to allow piston in the tensioner to push on the guide:
Special tool: We made this to hold the crankshaft in place. We ended up using this in conjunction with an impact gun to pull the bolt. There is a factory tool to do this, and it's pretty cheap.
Let me know if you guys have any questions and I'll do what I can to help.
Big Turbo Build Thread.
erball is offline   Reply With Quote
Old 03-13-2013, 02:54 PM   #2
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Doesn't seem too hard.
Thanks soooo much for the DIY
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 03-13-2013, 02:57 PM   #3
xHeartcoreboyx
xHeartcoreboyx's Avatar
Drives: '10 CW 2DR GTI DSG
How do you know if you need to replace it?
Sent from my iPhone with typos
SOLD -> MK7 R
Old 03-13-2013, 03:17 PM   #4
erball
erball's Avatar
It's really not hard, just need to be prepared ahead of time.
I would strongly recommend getting a new cover, but others have made due without. I know i bent mine pretty thoroughly when I switched them. My persistent timing rattle has completely gone away though.
Needless to say I'm pretty happy.
Old 03-13-2013, 03:28 PM   #5
Desert MVIGTI
Drives: 2012 United Gray 4D 6M GTI
No freaking doubt.
I should be able to roll coal all day long, this isn't fucking France.
Desert MVIGTI is offline   Reply With Quote
Old 03-13-2013, 03:51 PM   #6
xHeartcoreboyx
Hmm a small question is too much for you guys?
SOLD -> MK7 R
Old 03-13-2013, 04:15 PM   #7
Zillon
Drives: Dat R53, doe.
If you're getting close to the end of your powertrain warranty, might be a good idea to replace it with the latest revision.
The tensioner failures seem to be hit and miss, but if it does fail, goodbye engine.
Honestly, this is not anywhere near as bad as I thought it would be. Great writeup.
Old 03-13-2013, 04:20 PM   #8
xHeartcoreboyx
I am out of warranty. Any video of the noise it makes?
SOLD -> MK7 R
Old 03-13-2013, 04:39 PM   #9
ViRtUaLheretic
ViRtUaLheretic's Avatar
Drives: 2009 GTI
Added to the TSI FAQ, Thanks!
::APR stage2::BSH - Intake,Mounts,TB Pipe,RSB::Eurojet Ceramic Coated TBE::Phoenix Rising - FMIC::
::Devils Own DVC-30 5xDO1::Neuspeed ::Whiteline::BC Racing - BR coils::OSIR::HPA-DSG::INA::
::Flik FTDs::245x40x17::Unibrace::Bildon::Porsche 17z BBK::Hawk - HPS::034::Tyrolsport::
Read this for TSI INFO/FAQ
ViRtUaLheretic is offline   Reply With Quote
Old 03-13-2013, 05:38 PM   #10
DBESTGTI
DBESTGTI's Avatar
Drives: 2011 Stage 2 GTI
The are no symptoms. In the extremely rare instance that it does actual fail you'll know it when the car doesn't start
Old 03-13-2013, 05:41 PM   #11
Bruno2000
Drives: 2010 GTI 2dr red
x2, I would like to hear it too.
2010 RED GTI, 2-doors, MT, APR Stage2 v1.2, B&B Turboback, S3 Intercooler, Carbonio intake Stage1&2, STD Coilovers R1, H&R R-swaybar, BSH full mounts kit, Whiteline bushings, Forge short shifter kit, Front-Brakes stage3, Unibrace UB, XB, Michelin PSS, O.Z. Black Ultraleggera ESP OFF!
Bruno2000 is offline   Reply With Quote
Old 03-13-2013, 07:34 PM   #12
Mustache rash
I plan on doing this at 50000 miles....
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 03-13-2013, 08:53 PM   #13
tampa_mk5
tampa_mk5's Avatar
Drives: 09 MKV DSG
Thank you for this OP!
tampa_mk5 is offline   Reply With Quote
Old 03-13-2013, 09:26 PM   #14
erball
erball's Avatar
For those requesting a video of the sound, here is a video the previous owner posted of my car. It's on startup and sounds like a metallic rattle/ring.
http://youtu.be/yCLSXCO3NU0
