Old 04-11-2013, 09:40 AM   #1
ElusiveGTI
Drives: 2010 VW GTI
Exclamation Problems After APR Stage 1 Tune
So I got my car tuned yesteday and it was fine. Drove home to issues enjoying the extra boost. The shop who tuned my car told me that my Forge Bypass valve was "junk", so I bought the OEM part and had it installed after I left the shop. Still no problems after install. Later that night I went to start my car and it was not turning over correctly and taking a long time to start. So I shut the car off and restarted it, in which it started. However, the car will not idle correctly and my check engine light is on. Seems like its missing around 1.2k RPMS and Bogging out around 800 RPMS. I tried to turn my car off and turn it back on, no help. So I tryed to switch into stock tune to try and fix it, still light was on. Then I went home. Dismorning I went to start my car to go to work and it would not start alltogether. When it finally decided to try and turn off some oil pressure or oil something poped up into the screen that shows MPH and what not. I quick shut the car off. Turned back on and started right up. Still idling horribly. Driving to work the car runs fine. Called my tuner shop but they cannot diagnose without having the codes. So after work I have to hook it up to get the codes, my buddy has a diagnoser.
Fingers crossed it isnt something bad... Considering I drove 1.5 hours yesterday to get tuned.
Anyone have the same issues? Suggestions?
ElusiveGTI is offline   Reply With Quote
Old 04-11-2013, 10:22 AM   #2
Lou Maiuri
Drives: One Tray Fi
Change your coil packs and spark plugs and you will be misfire free. #1 problem on tuned boosted applications are misfires caused by coils and plugs. I just ordered them preemptively for my 135i as I know they are problem prone. Nothing is wrong with your car so don't stress out, just order Audi r8 coils from Dave @HStuning and get yourself some new spark plugs
Lou Maiuri is offline   Reply With Quote
Old 04-11-2013, 10:32 AM   #3
ElusiveGTI
Drives: 2010 VW GTI
And this would cause the check engine light?
Old 04-11-2013, 10:32 AM   #4
ElusiveGTI
Drives: 2010 VW GTI
Also how much is this gonna cost me. I feel like I'm starting a money pit.
Old 04-11-2013, 11:17 AM   #5
ElusiveGTI
Drives: 2010 VW GTI
bump
Old 04-11-2013, 11:34 AM   #6
maxtdi
GolfMK6 Elite
maxtdi's Avatar
Most likely coils... What are the codes? We can't help you until you post em up.
Old 04-11-2013, 11:38 AM   #7
ElusiveGTI
Drives: 2010 VW GTI
Codes will be posted later tonight. Thanks for the help!
Old 04-11-2013, 11:45 AM   #8
DSGVW
DSGVW's Avatar
Drives: 2012 CSG GTI DSG
I'd be praying for coilpacks as they are a cheap fix and 95% of all misfire issues. I would put money on coilpacks and/or spark plugs. Get both and change all of them - 20 minute job even for a newbie.
Just a wrench and a spark plug socket and you are golden. Check the gaps on the plugs to ensure proper spark.
Old 04-11-2013, 11:46 AM   #9
MaliciousMK6
MaliciousMK6's Avatar
Its a common problem, no worries lol. At most coilpacks and plugs.
Old 04-11-2013, 11:55 AM   #10
ElusiveGTI
Drives: 2010 VW GTI
Fingers crossed this is the issue. Will the codes tell me this is the problem?
Old 04-11-2013, 12:39 PM   #11
corydd
corydd's Avatar
Drives: '10 CW GTI DSG Autobahn
This happened to me after Stage 1 too. R8 coil packs did the trick.
'10 CW DSG GTI Build Thread & Flickr * APR Stg 1 * Depo Tails * Magnaflow CBE * OEM Lip * VW Motorsports Wheels * VWR Springs * Stoptech Pads * DeAutokey LED's * 24mm H&R RSB
corydd is offline   Reply With Quote
Old 04-11-2013, 01:25 PM   #12
ElusiveGTI
Drives: 2010 VW GTI
replace them all in one shot or only the ones that need it? and should I replace the spark plugs as well?
Old 04-11-2013, 01:30 PM   #13
Lou Maiuri
Drives: One Tray Fi
And stop driving it around while cylinders are misfiring.
Old 04-11-2013, 01:36 PM   #14
MrMke
MrMke's Avatar
Drives: 2011 CW MK6 GTI Autobahn
Good idea to pick up some new r8 coilpacks....
Just curious.....where are you located....and what shop did the tune?
GIAC Stage 2 / AWE TBE / AWE Boost Gauge / APR Carbonio Stage 1&2 / Sigma Six SS / DG Springs / H&R Sways / UNIbrace UB & RB / Golf R LED Tails
MrMke is offline   Reply With Quote
