Old 04-09-2016, 10:21 AM   #211
lilzim
Drives: CW MkVI 6MT
Hey, if anyone still checks here can I get some opinions?
Some info here. I'm in a 2010 GTI, K04, APR intake and downpipe. I've got 100k miles on the car, 80k are K04. Recently needed a new clutch. Decided to take the time to also go from a custom tune to the APR v3 tune. I'm running 93 octane. After the tune, the car just felt flat. Boost kicks in and then it just seems to die off. My boost gauge shows that boost peaks at 20-23psi and then just constantly drops from about 4k rpm on until it's dropped to about 12psi. From looking at the logs, it appears that's not the case, but I'm wondering why I see that on the boost gauge. N75 seems to drop off early (or be all over the place). And on two of my runs, my throttle valve angle went to about 50% after boost kicked in even though the accel pedal was pegged the whole time. Injection timing looks high too, but I'm new to logging data and looking at this stuff. Any opinions from the pros? Any other things I could log to get a better picture?
lilzim is offline   Reply With Quote
Old 04-15-2016, 03:15 AM   #212
mraaf
Drives: 2011 MK6 GTI
Your lambda looks leaner than mine. I have 0.78-0.75 WOT
REVO 3
mraaf is offline   Reply With Quote
Old 04-20-2016, 03:57 AM   #213
A.S.K
Originally Posted by RaySkodaTSI View Post
Hi All,
I've a Skoda Octavia Mk2 1.8TSI 6MT (EA888mk2). Ran Stage 2(JBS Map, Milltek RacePipe and Non resonated catback, Spullen Boost Pipes & GFB DV+) for 15k kms without issues.
About 2 Weeks ago installed a APR K04 Turbo & APR 93Map, and I'm getting persistent overboost CEL (P0235) and limp mode ~ 4th Gear at 6500rpm.
Video of Overboost issue on track - https://www.youtube.com/watch?v=v4IjGTeEqYE
Log from the track.
Attachment 49467
Spoke with APR and they recommended putting all stock parts back.
Put all stock parts back in except the APR Carbonio Stage 1. Replaced the Spullen with the Stock Pancake pipe, and the GFB DV+ with the Stock DV. Did a full boost leak test.
Sealed off the intercooler exit, blocked off all Breather Hoses and PCV. Pressurized the Turbo inlet first upto 10PSI, then all the way upto 30PSI, and looked for leaks. Nothing found.
Results - Nearly SAME! Havent got a EPC light yet, as max speed I was able to achieve was 170kmph, and the EPC+Limp used to occur at 188Kmph in 4th Gear.
Attachment 49466
Can any of the guru's chime in as to what this could be. The car ran perfectly fine with Stage 2 tune (JBS) for over 14,500kms and never ever got a boost issue or overboost MIL.
Hi ray
you can check N75 small pipes from three side way in & out then go to check your wastage from free play.
Sent from my GT-N7100 using Tapatalk
A.S.K is offline   Reply With Quote
Old 05-02-2016, 12:02 PM   #214
shaolinmastr
shaolinmastr's Avatar
Drives: 2010 UG GTI
GTI Data Logging Compendium
Eurodyne Maestro
FrankenTurbo F23T, 3" DP, Magnaflow CB, APR Stage 2 CAI, R8 CP, BSH TP, ATP FMIC, Frankenturbo TOP and NGK BK8EIX
4th gear pull, 65 degrees, 1289'.
2010 GTI MKVI UG Mabotech Tuned F23T 360whp Daily Driven
BUILD THREAD
shaolinmastr is offline   Reply With Quote
Old 07-19-2016, 10:26 PM   #215
Ronnie_B
Drives: 2013 GTI 4DR Wolfsburg 6MT
Did you ever figure out why your throttle valve angle dropped to ~50% despite your pedal position being 100%? I'm experiencing a similar issue.
/// 2013 Wolfsburg GTI w/ leather, APR Stage 1 v2.4 93 tune, RSR Clutch, iABED RMS, Carbonio Stage 1 Intake, Vibrant Resonator on stock catback, Diesel Geek short shifter, NewSouth Boost Gauge, SuperPro ALK, Stoptech 309 Pads, Motul RBF600 Fluid, Michelin PSS on OZ 17" Omnia (Summer), Michelin Pilot Sport A/S 3 on Serrons(Winter), Depo R LED Tails.
Ronnie_B is offline   Reply With Quote
Old 12-27-2016, 09:04 AM   #216
jysaw
Drives: GTI
Unitronic Stage 2
Unitronic Stage 2
APR Carbonio Intake Stage 1&2, 3" decat downpipe
I have been experiencing hesitation especially in higher gear. The hesitation is felt when accelerating in higher gear without downshifting. LTFT is 0.5% at idle and -11.7% at partial.
My data log as below.
https://drive.google.com/file/d/0B60...ew?usp=sharing
Any thoughts?
jysaw is offline   Reply With Quote
Old 01-03-2017, 10:23 PM   #217
jysaw
Drives: GTI
How do you determine boost leak from the log?
Old 01-03-2017, 10:34 PM   #218
mraaf
I will looking at too low actual vs spec boost while high N75 duty cycle
REVO 3
