Old 04-20-2013, 05:05 PM   #15
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
I have about 10 logs on my work computer. Will post soon.
Ill also grab some Stage 2 logs.
More data the better!
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 04-20-2013, 05:08 PM   #16
grambles423
Limited Activity
Also, the intake logs from the technical sticky can be pulled here too
Old 04-20-2013, 05:13 PM   #17
A_Bowers
A_Bowers's Avatar
Drives: MKVI GTI
Ya mean these
Its been quite a while since I've posted a Technical Understanding thread with some hard data and calculations to further feed our minds. Since most of the conceptual basis of the earlier threads were.....for the least bit.....theorhetical and quite possibly boring, I decided to do a little experimenting (with help from NS01GTI) to collaborate data to compare stock intake with drop ins and aftermarket intakes.
Test Requirements:
- APR K04 93OCT Runs (~366hp ~380tq)
- APR IC (will affect IATs but will remain consistent)
- 3rd and 4th Gear Runs (Data was collaborated in 4th gear due to sample size and output.)
- Consistent Ambient Runs (Or at least within a +/- 5*F Tolerance from our Nominal)
- Stock Intake is a CBFA Intake with no modifications
- VWR Drop in incorporated the deletion of the baffle at the bottom of the air box
- Carbonio was done in two stages: Stage 1 only and Stage 1+2 (PENDING DATA COLLECTION)
- Same stretch of roadway was used
- Variation in Starting RPM Ranged from 200-300RPM in 4th (~2200) and 200RPM in 3rd (2700).
- Redline will be assumed as the normal redline but some logs will be shown past 6600RPM due to the DSG Stage 2 flash (7100RPM Redline) that was added mid testing (DSG Tuning added Post VWR Drop in, Pre Carbonio Stage 1)
Results:
Stock Intake
3rd Gear Run:
4th Gear Run:
Thoughts
Immediately you can see that the stock box will not hold boost properly throughout the entire rev band. Sort of a "dying effect" much like the stock turbo sees.
Boost control is smooth in the midrange which correlates with the peak condition you see intially. Still, the "butt dyno" registers a loss in the system and takes away a lot of the "raw" manly feeling of the K04. You can see the discrepancy from requested and actual better in the 3rd gear log.
Some thoughts in my build thread about the construction of the stock box:
Takeaway: Stock box is not efficient enough to hold and maintain boost through the rev band an on into the upper RPMS. Also, stock box shows higher IATs up the RPM band even with the APR IC.
VWR Drop In Filter
4th Gear Run:
Comparison
So what does this mean? It seems that the drop ins will actually help alleviate some of the down low restriction and allow the turbo to spool quicker, but will not give any added flow up top. Since in fact that two MAF rates look IDENTICAL at redline, I would be safe to say that its simply not worth it. The boost still dies sharply after the "point" has been reached where the flow just cannot keep up with the requested pressure.
Dont mind the lower value for the Drop in filter for boost at the final point. This could be % error in between measurements on different days. The point to take away is that it did not ADD any "breathing" at higher RPM. Ipso Facto......the stock intake box is just too damn restrictive for the boost to keep matching requested values at the last 1/3 of the rev band.
Takeaway: While a drop in allows for some down low flow to spool slightly quicker, up top the car still cannot meet its requested boost. You're still choking the car at upper RPMs
Carbonio Stage 1
4th Gear Pull:
Looking over the logs, the carbonio decreases lag and onset WAY faster than the VWR drop in and Stock filter and flows more in the higher RPMs, thus allowing to hold boost easier (0.29psi discrepancy between Specified and Actual)
Peak MAF Readings
Stock Intake: 236.4
VWR Drop In: 235.8 *******Difference can be error between measurements
Carbonio Full: 258.8
Difference in Peak and Redline Hold
Stock Intake: 5.51psi
VWR Drop In: 5.61psi
Carbonio Full: 3.9psi
Difference in Requested and Actual at Redline
Stock Intake: 2.2psi
VWR Drop In: 2.03psi
Carbonio Full: 0.29psi
Takeaway: Data speaks for itself. An aftermarket intake is definitely worth while. Especially one that is sealed off from the engine bay and only pulls cold air from outside the vehicle.
Carbonio Stage 1 and 2
Take Away:
1) More MAF: ~6.2g/s higher (On a 9F hotter day)
2) More Boost Requested: Almost 1psi higher in the upper RPMs
3) Faster Request (Quicker Spool) in Lower RPMs:
4) Slightly Faster Response to Peak: 200RPM Sooner
5) Higher MAF Readings in the Mid Range Except under boost control
6) Equal Tempearture discrepancy from Start to Finish: 5-6*C
All in all the turbo is working less strenuously to boost better but the peak will come quicker asking for the Wastegate to dial it back quicker. This is mostly why people find hesitations in after market intakes besides the Stage 1 portions. However, I dont find too many driveability problems with this.
Additional Intake Comparison Data (Carbonio vs. Modshack)
Thanks to the help of NS01GTI, we were able to get an accurate depiction of the clear differances between the two common intakes seen on this forum. One for Noise control, the other for high performance. Its ultimately the end user's decision to make a choice and what they would like, but for some fun, we decided to take the same data that we did in the previous setup:
4th Gear Run Carbonio:
4th Gear Run Modshack:
Comparison Graphs:
What I immediately saw was the discrepancy in reuqested boost values and actual values again. It seems that the Modshack, while not having the restriction like the stock box, still shows upper RPM boost loss from requested. MAF vales were also very considerably different in the midrange that we couldnt just say there was "variation in the runs" Almost 50-60g/sec more.
The driver also noted the "butt dyno" difference between the two. At upper RPMs the car just felt out of breath.
A quick thought about the sound differences:
Takeaway:
1) Carbonio has more mid range MAF and a quicker spool time.
2) Ambient conditions were different to each run but both IATs got down to the same temperature (~33*C)
3) Modshack has an almost 2psi difference between requested and actual at a higher RPM. The Carbonio seems to hold the boost more.
4) Carbonio log was started at a lower RPM, yet spooled quicker than the Modshack which started almost 200RPM quicker. The Carbonio log was the "hotter" of the two logs in terms of IATs
Conclusion
All in all this was a very fun excersise and it really showed some similarities and differences amongst OEM design, drop ins and aftermarket competitors. While it was VERY hard to keep some variables consistent, we still managed data that can be judged as sufficient for analyzing.
Furthermore, even if the data speaks so much, it helped me (and probably others) understand more of the flow dynamics involved in our little TSI engines. Where's the performance compromise? Where's the sound compromise?[/quote]
MKVI CSG GTI ///
Old 04-20-2013, 06:03 PM   #18
allset
allset's Avatar
sub'd
Old 04-20-2013, 06:11 PM   #19
mdhollis
mdhollis's Avatar
Drives: S3
This thread is a winner. Good job Bowers.
Thanks for getting my info in here JR
mdhollis is offline   Reply With Quote
Old 04-20-2013, 06:22 PM   #20
timneedscoffee10
timneedscoffee10's Avatar
Drives: 2011 VW GTI w Sunroof
Good deal... I'm going to log tomorrow, so it's great to have some independent reference material to compare against!
I'll most likely not post mine here until I get my new clutch, and break it in. The clutch slip causes odd looking dips mid-run... But I'll definitely contribute here in the next few weeks.
Old 04-20-2013, 06:35 PM   #21
A_Bowers
A_Bowers's Avatar
Drives: MKVI GTI
I can't take all the credit. It was more John's idea than anything, I just put it all together.
MKVI CSG GTI ///
Old 04-20-2013, 06:40 PM   #22
John@Unitronic
GolfMK6 Official Vendor
John@Unitronic's Avatar
Drives: MK3 TTRS
Great thread. Looking forward to seeing the data. If anyone needs assistance graphing, etc., email me.
As for the logs, might I suggest the following as a general reference...
Use the "Adv. Meas Values" logging function and enabling "Turbo" mode for higher resolution. You can log 12 channels at once using Adv Meas Values.
001-1 (Engine Speed / RPM)
003-2 (MAF)
003-4 (Ignition Angle / Timing Advance)
020-1 (Timing Pull / CF Cyl 1)
020-2 (Timing Pull / CF Cyl 2)
020-3 (Timing Pull / CF Cyl 3)
020-4 (Timing Pull / CF Cyl 4)
031-1 (Lambda [x 14.7 for AFR])
054-4 (Throttle Plate Angle %)
114-4 (N75 Duty Cycle % Actual)
115-3 (Boost Specified)
115-4 (Boost Actual)
I would recommend only doing the runs after engine is to full operating temperature from 2000rpm to redline for the most accurate results. I prefer 3rd gear because its much safer for the street as the speed as you reach redline is lower.
Since you can only log 12 channels at once, you'll have to substitute if you need diff data...
031-2 (Lambda Specified)
054-3 (Accel. Pedal Position %)
114-3 (N75 Duty % Specified)
230-1 (Rail Press Specified)
230-2 (Rail Press Actual)
014-3 (Misfire Sum)
001-2 (Coolant Temp)
The more consistent the logs, the more comparable they'll be for you guys.
UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
Web: GetUNITRONIC.com | Tel: (866) 341-2447
Follow us on: Facebook | Instagram | Twitter
John@Unitronic is offline   Reply With Quote
Old 04-20-2013, 06:54 PM   #23
John@Unitronic
Drives: MK3 TTRS
Rather then other threads leading OT...
Old 04-20-2013, 09:07 PM   #24
FLtrooper
FLtrooper's Avatar
Drives: No Mas VW! Hola Audi!
Sir, an email has been sent! Just took some logs, Perhaps the information is worthy of being graphed.
Thanks for being an assist to the community!
My OEM+ K04 MK6 GLI
Sticking to two wheels from now on!
FLtrooper is offline   Reply With Quote
Old 04-21-2013, 01:52 AM   #25
Djunited
Djunited's Avatar
Drives: K04 GTI
Nice thread here.
Here are my logs of my UPsolute tuned CTS K04
BUILD THREAD bczracekar VIDS
Old 04-21-2013, 08:46 AM   #26
mdhollis
mdhollis's Avatar
Drives: S3
Originally Posted by Djunited View Post
Nice thread here.
I'm just displaying your logs so we can see....
Old 04-21-2013, 08:54 AM   #27
Djunited
Djunited's Avatar
Drives: K04 GTI
will take more logs once i get my intercooler, top and tbp. wonder what could change in the logs. maybe more g/s, less timing pull and better hold?
Old 04-21-2013, 08:59 AM   #28
NS01GTI
Drives: 2012 GLI K04
I look forward to seeing these.
Your logs look good. I'm not sure you'll see much more boost up top; as it is you're actual is matching requested. You could see more g/s. I'd say the two biggest improvements (measurable by VAGCOM anyway) would be a little less timing pull and lower IATs. You should try and get some IATs logs before you put on the new parts.
K04 Club Member #15 - 2012 GLI DSG
UNITRONIC Tuned K04 - UNITRONIC Stage 2 DSG - UNITRONIC TBE - APR FMIC - Carbonio Intake - Neuspeed TOP - AWE Boost Gauge - HPA SHS COILOVERS - HPA Red Motor Mount
NS01GTI is offline   Reply With Quote
