Old 05-11-2010, 04:23 PM   #1
m4ci3k
m4ci3k's Avatar
Drives: 2010 CW GTi
Shifting
What is the best RPM's to shift at?
I've read 5-5.5k is best for our powerband but would like more opinions
I am DSG.
Thanks in advance
m4ci3k is offline   Reply With Quote
Old 05-11-2010, 04:40 PM   #2
TDR-380
Formula 2 Champion
TDR-380's Avatar
Drives: 2.0 TDI, R
wrong section. It depends on the style of driving. I am assuming racing then some members recommend 6k? I have a TDI and for the sake of fuel economy I switch around 2-2.5k rpm. When I accelerate and want to feel the torque I switch around 4k rpm.
Old 05-11-2010, 04:50 PM   #3
m4ci3k
m4ci3k's Avatar
Drives: 2010 CW GTi
Yes while racing
Old 05-11-2010, 08:14 PM   #4
future10gti
first few gears you can rev a little higher then 5.5k but once you hit 3rd and beyond stick to about 5.5k
future10gti is offline   Reply With Quote
Old 05-12-2010, 01:03 AM   #5
msm00b
msm00b's Avatar
I feel less torque, pull, and acceleration after 6k as compared to 4-6k rpms in the higher gears (3-6). First two gears I'm usually hitting redline before a shift ... partly because you still get good pull, but mostly because you can hit redline so damn fast.
msm00b is offline   Reply With Quote
Old 05-12-2010, 07:33 AM   #6
Bender
Bender's Avatar
Drives: 2014 Focus ST
5.5k - anything above that is wasted as you will be making more power down low than up high.
Old 05-19-2010, 12:50 PM   #7
bubuski
El Moderador
bubuski's Avatar
Drives: MK6 GTI 5-door TR
I say rev it all the way past redline and let the gearing do its job, but what do you consider powerband?
Looking at a GTIs dyno graph,
Shifting at 6800rpm brings the rev back to ~4900rpm which has the meat of horsepower but torque dropping pretty soon which make it feel as if there is less pull(not as much torque).
Shifting early at 5500rpm drops the rev back to ~3600rpm which has less horsepower(than @5500rpm), but you are dropped in the meat of the torque.
HP or TQ?...Which makes the car go faster as they usually switch places at about 5200rpm? Debate away.
Old 05-19-2010, 05:04 PM   #8
robbop111
Drives: 2010 gti mkvi
uh.....uh......i dont know!
robbop111 is offline   Reply With Quote
Old 05-19-2010, 05:43 PM   #9
micah360
micah360's Avatar
Drives: 2010 GTI - 2011 Routan SE
normal driving I usually shift around 3.5-4k.
micah360 is offline   Reply With Quote
Old 05-19-2010, 05:46 PM   #10
Turbo GTI
Drives: MKV
HP
Turbo GTI is offline   Reply With Quote
Old 05-20-2010, 12:08 AM   #11
GunMetalGTI
GunMetalGTI's Avatar
Drives: 2010 DSG 2 Door GTi
stay as high as you can in the actual torque curve until you get to the last gear you plan to be in and floor it.
GunMetalGTI is offline   Reply With Quote
Old 05-20-2010, 06:43 AM   #12
msm00b
msm00b's Avatar
