Old 05-03-2013, 09:40 AM   #1
HFZ
Drives: GTI
GTI stalling on startup? CEL on
Having this exact issue... I guess since it's on youtube Im not the only one... Anyone had this fixed? Is it safe to run for lets say a 600 km trip?
http://www.youtube.com/watch?v=mJNRagRh6_M
Thanks in advance for your input!
HFZ is offline   Reply With Quote
Old 05-03-2013, 09:43 AM   #2
chrisisnapping
chrisisnapping's Avatar
Drives: Bye: GTI DSG Hello: Mustang GT 6MT
1. get vagcom, it'll tell you why you're getting the CEL
2. looks like you're getting multiple misfires - your coil packs are probably bad. Vagcom would tell you which cylinders are misfiring.
3. press down on your coil packs, make sure there is a good connection. try and see what happens.
4. go to the dealer to get them replaced
Old: APR Stage 2, UR Metal Cat/Resonator down pipe, Modshack Intake, BSH TB Pipe, Coolingmist DPI Meth
New: Stock for now.
chrisisnapping is offline   Reply With Quote
Old 05-03-2013, 01:25 PM   #3
corydd
corydd's Avatar
Drives: '10 CW GTI DSG Autobahn
Sounds like a misfire. Pretty common problem with these engines, but it's a simple fix. Try upgraded coil packs first and then spark plugs if necessary.
Coil packs: http://www.hstuning.com/product_info...1&vpath=33_289
Spark plugs: http://www.hstuning.com/product_info...6&vpath=33_289
Might want to carry an extra coil pack in your car so you don't get stranded on the side of the road if it happens again. Takes 5 minutes to swap 'em out with no tools needed.
'10 CW DSG GTI Build Thread & Flickr * APR Stg 1 * Depo Tails * Magnaflow CBE * OEM Lip * VW Motorsports Wheels * VWR Springs * Stoptech Pads * DeAutokey LED's * 24mm H&R RSB
corydd is offline   Reply With Quote
Old 05-03-2013, 04:45 PM   #4
FocalPoint
FocalPoint's Avatar
Drives: MKV GTI/MKVI GTI
I get this sometimes. Especially on a warm engine. (Example: I get up in the morning, drive to the 7-11 a couple blocks away, get a 5hr energy or coffee, get back in, and it'll do this)
Been doing it since I took delivery. Only issue is I never get a CEL for it. Otherwise I could finally figure out why it does this. Kind of sucks to have a new car choke to turn over.
Old 06-10-2013, 08:02 AM   #5
marco_mk6
Drives: 2011 VW GTI DSG 4 Door
Hey,
Have you had the problem fixed? I have the same problem with my 2011 DSG and dealer (park avenue VW in south shore , mtl) was never able to figure it out...
They did an ECU upgrade and for a while the problem was fine but it just came back when the weather started warming up in Montreal.
marco_mk6 is offline   Reply With Quote
Old 07-06-2013, 02:36 PM   #6
Poltergeist
Poltergeist's Avatar
Drives: The Pocket Rocket Mk6
anyone find out whats the problem with this?
2011 Black GTI lightly modded.
Poltergeist is offline   Reply With Quote
Old 07-06-2013, 09:59 PM   #7
Carbon Steel
Carbon Steel's Avatar
Are you driving a 2013 or at least still in warranty, call the dealer let him decided if you can drive or let him send a roll back...................
peace
Old 07-07-2013, 12:24 PM   #8
mr.zeros
Drives: Mk6 GTI
+1
That is my car in the video btw. This seems to affect MY2011 mostly if not exclusively. This problem is worst for me in the summertime. Nearly every time I go to start the engine after its been sitting for an hour.
mr.zeros is offline   Reply With Quote
Old 07-07-2013, 03:52 PM   #9
Carbon Steel
Originally Posted by mr.zeros View Post
+1
AND, have you taken it to a dealer to be fixed?
peace
Old 07-07-2013, 04:07 PM   #10
mr.zeros
Drives: Mk6 GTI
5 trips. 3 trips specifically for this issue. Opened case with vwoa at the time of the third trip. They found nothing wrong with the car. they blamed the issue on fuel quality. I was advised to no longer use shell or chevron and to use exxon. The issue was worst with shell fuel, but still occur with the other fuel companies. I always use top tier fuel, never the cheap stuff. My opinion was that vw was trying to pass the buck.
Old 07-08-2013, 05:24 PM   #11
NTT5418
NTT5418's Avatar
Drives: 2011 CSG GTI 6MT
Had the exact same issue for a while. Mine actually got to the point where it threw a CEL and took a few cranks to start. Took it to the dealer and after 5 hours, they replaced the HPFP due to low pressure. Not sure if that really fixed it though as it's happened intermittently since then
2011 Carbon Steel Grey GTI
NTT5418 is offline   Reply With Quote
Old 07-08-2013, 09:26 PM   #12
caradd
Drives: 2011 MK6
Such nonsense, used all brand of gas in many different cars with no issues related to fuel. They're making excuses. Get them to buy back the car and run far far away.
VW has gone down the toilet.
caradd is offline   Reply With Quote
Old 07-09-2013, 01:26 PM   #13
Poltergeist
ive been tracking this issue for a while now, some other threads about it:
http://www.golfmk6.com/forums/showthread.php?t=21459
http://www.golfmk6.com/forums/showth...ghlight=idling
someone managed to make it happen before dealership's eyes. they said it was fuel pressure problem. never got an update after that so I assume it was fixed? cuz ppl dont post if they got no problems.
Old 07-09-2013, 11:31 PM   #14
mr.zeros
Drives: Mk6 GTI
The dealership told me they checked the entire fuel system on my gti and found all pressures good for what it's worth. Who knows for sure. They drain my tank because the vw tech line diagnosed the problem as bad fuel. That didn't solve the issue, big surprise.
