Old 05-25-2013, 08:24 AM   #1
Toledo R
Drives: GOLF GTI
How to Build a 9 Second GOLF GTI, by solving Direct Injection Fueling problems
Taking the GOLF GTI into the 9s
I have been watching for a long time the many efforts to increase the fueling capability of Direct Injection engines, and I just wanted to let you all know that if you think "Out of the Box", the solution is simple.
You only have to fit the AUDI TT RS HPFP on the TFSI engine.
To do that, you either need to have someone cast, or CNC machine a new Variable Valve timing cover, which will have the TT RS pump mounting points to put the pump in the right position. Then you need to make a Trilobe cam profile, to match the one that comes on the TT RS exhaust cam for the roller cam follower.
The LOBA 2.5 TT RS HPFP, is good to 700HP+ on a 5 cylinder engine, possibly more on a 4 cylinder. If you can convince any of the companies which make uprated HPFP components, to make a slightly larger diameter piston, you immediately get a pump which will be good for 700WHP, which will rev easily (and reliably) to 9000 rpm. There are companies that make bigger pump pistons for the TFSI pump already. Here is an example from HPFP UPGRADE
FOR EXTREME VW FANATICS: Taking the GOLF GTI into the 8's and 7's
Now that you know that 700WHP is easily possible, I would like you to know that it is also possible to double that output, simply by fitting a second TT RS pump. This of course is more complicated, but it is doable by anyone with CAD skills and access to a CNC Mill.
If you look at the TT RS HPFP, you will see that it is all contained on the Cam Carrier, and it is not difficult to design and then CNC machine a 4 cylinder Cam Carrier which will have a provision to mount the TT RS pump, in exactly the same way that the factory has done on the 5 Cylinder engine. To do this, Software Tuners will need to get involved, in order to resolve the issue of Fuel Rail Pressure Regulation with 2 pumps.
One of the problems the designers of the FSI system had, was to minimize Fuel Rail Pressure Pulsations, and one of the ways they did it, was to adjust the volume of the Fuel Rail and lines, to act as a Damping Chamber. This means that you will have to have 2 separate fuel rails, with 2 HP return valves and 2 fuel returns to the tank. It will take some development, but I think it is possible.
If you are lucky, you could get away by using the single pump signal to control both pumps, provided their cam timing is identical in relation to crank rotation. One way that you can reduce Fuel Rail pulsation, is to stagger the 2 pump lobes by 60 degrees, so that there will be a Fuel pressure event, every 60 degrees, instead of 120 degrees. This is a lot more complicated, and will probably require an extra ECU, just to control the second pump solenoid valve, with its own timing settings. The 1500 WHP GOLF will probably be the work of one or more of the Big VW Tuners, who will compete for Bragging Rights, so they should be able to deal with the Electronic side of this fueling Upgrade. Twin HPFP Racing applications will require Billet cams to drive the pumps.
Now that you have solved the Fueling problem of your cars, you can go crazy on turbo size, but always remember that big turbos have a lot of lag, and that means terrible street driveability and a slow spooling and revving engine. I have thought of a simple way to reclaim the spool characteristics of small frame turbos, and I have put it in PDF form, which you can find in the following link. It will be quite easy for you to get ATP TURBO or other VW Companies to make this quick Spool, High Torque, Twin Scroll Turbo Housing. I have uploaded it on the BOX.
Quick Spool, High Torque Twin Scroll Exhaust Housing
The reason you need to get as much torque as possible in the lower rpm range, is because if you have the necessary traction, it has a tremendous effect on the speed by which the engine goes through its rpm range. If you look at the following picture, you will understand what I mean. 4WD GOLFS are heavy, and they need a lot of torque to accelerate. They don't have a problem with traction, as BOBA Motoring has proven with the 8.6 second GOLF 2 VAMPIR.
Here's the torque comparison once again and the rate of acceleration to 7500 rpm. That's over 1.5 seconds faster, just by filling the low rpm area under the Torque curve!
Looking at the performance of Honda's, it is clear that the VW Community has a lot of catching up to do. Horsepower potential is no longer the limiting factor for you.
If a simple Mechanic from BOBA Motoring can build a 16V GOLF 2 all by himself, to embarrass the VEYRON SUPER SPORT and the AMS GTR ALPHA 12, then the American VW Tuning Industry, has a lot of work to do.
VW Golf 2 16V AWD vs Bugatti Veyron Super Sport vs AMS Nissan GTR Alpha 12+ - YouTube
So guys, have fun with this, I will sit down with Popcorn and watch who will get a VW GOLF TFSI first to the 9's, the 8's and finally the 7's...
John
Toledo R is offline   Reply With Quote
Old 05-25-2013, 10:47 AM   #2
2013R
FIA Formula 1 Champion
2013R's Avatar
Drives: 2015 Subaru WRX
i like that HPFP upgrade site, looks like the FSI R fuel pump upgrade is only $500, instead of APR's $1000 or something.
http://hpfpupgrade.com/Products/Show...+Your+New+Pump
oh.......... you have to send them a brand new pump first at your expense... never mind.
2015 Subaru Forester XT
LastHumansGarage
Old 05-25-2013, 10:55 AM   #3
Chef_R_Gamie
Drives: 2013 Golf R 2Dr Candy White
Has anyone done this, is it just as reliable as going through APR?
GIAC STAGE 2-NEUSPEED P FLO-SPM STREET DP-VWR SPRINGS-20% TINT-LED TAILS-ESE COLOR MATCHED SIDEMARKERS-CUSTOM EVOMS ENGINE COVER-R MONSTER MATS
Chef_R_Gamie is offline   Reply With Quote
Old 05-25-2013, 11:47 AM   #4
bayern
bayern's Avatar
Drives: 2012 CW GTI with DSG
Very interesting post! I think many folks are anxiously awaiting someone to actually make the up-graded HPFP and test it, particularly on the 2.0 tsi. I am not shooting for a 9 second car, but it would be great to see!!
APR|HRE|Brembo
bayern is offline   Reply With Quote
Old 05-25-2013, 12:27 PM   #5
GTINAPLES
GTINAPLES's Avatar
Drives: 2010 GTI DSG
Very cool. I'm ready to see what happens.
Sent from my iPad using Tapatalk HD
GTINAPLES is offline   Reply With Quote
Old 05-26-2013, 12:02 AM   #6
XGC75
XGC75's Avatar
Drives: into shit
Nice writeup!
Though I think the strongest limiting factor keeping our cars from hitting 9's isn't technical feasibility but cost. Not parts cost, either - it's always expensive to build an engine. No, it's the cost of the car. If I know I'm going into a project to rebuild an engine, am I going to buy the $5000 car with a decent body and tons of miles or the $18000 car with great body and hardly any miles? In the end, after a ~$10000 rebuild, I'm paying about $13000 for the quality of the body and interior (which I'll just molest with gauges anyways). See where I'm going? Why would I buy the more expensive car?
butchered by autocorrect
Old 05-28-2013, 06:24 AM   #7
Toledo R
Drives: GOLF GTI
Clarification
I just wanted to say that my post simply explains how people can solve the Fueling problem of FSI engines. I never said that Joe Public will sit in front of a computer and do this by themselves. There are many VW Tuning companies which have the means to do this, and then OFFER it to customers.
What is the difference between making CNC Billet Cam covers and doing what I have suggested? Are you familiar with Reverse Engineering Laser 3D Scanning? It is very simple (as I said) to scan a 4 cylinder Cam Carrier, and the TT RS Cam Carrier, and then incorporate the Fuel pump section to the 4 cylinder cam carrier. Then it will be CNC machined automatically, through CAD/ CAM programs. Do you see anything difficult here? Making a Copy of the Variable Vlave Timing cover is even more simple and cheap. If the VW Tuners will offer a CNC TT RS Pump compatible cover for the TFSI engine, do you think people who want more horsepower than is available today will buy it?
If the VW Tuning Industry will ever decide to compete with the Honda's, with 2013 TFSI and TSI tech, can they do it now?
Old 05-28-2013, 07:31 AM   #8
Halvie
Drives: 2010 Penalty Box
is this also a possible tsi solution?
Old 05-28-2013, 09:22 AM   #9
Toledo R
Drives: GOLF GTI
Yes,
It will be more expensive for TSI cars, because you will need to do the Billet Cam Carrier to fit the TT RS pump, but then you can disconnect the Stock TSI HPFP pump, and connect the TT RS one to the Fuel Rail. Before long, it may be possible to control the Electronics to run both pumps, so any engine specification would be possible after that.
Simple response to possible Injector Questions.
When a strong demand will be created for 700+WHP FSI Injectors, someone will fill it. They do not exist now because there is no demand. This is the most fundamental Truth about Tuning:
SPEED COSTS MONEY. HOW FAST DO YOU WANT TO GO?
At a 1400E per injector, BOSCH MOTORSPORT can make any injector you want. How fast do you want to go, and how much do you want to go fast?
For 100 injectors the price goes down to 760E. When the demand will appear, vendors will be able to order in the thousands.
The Vendor who will buy the most BT Injectors, will sell them all, because he will offer the lowest price. It is simple economics.
It goes without saying that Port Injectors would be a lot cheaper, but then it IS NOT AN FSI ENGINE.
Old 05-28-2013, 10:45 AM   #10
trd420
trd420's Avatar
Drives: 2015 S3 Prestige+Performance Pack
Interesting..
Now 2015 Audi S3 Prestige + Performance package, DTUK & K&N drop in. Running E-85 blend
Had 2011 MK6 GTI Unitronic Stage 2+ (K04)
Had 1989 MK2 GTI VR-6 Swap
trd420 is offline   Reply With Quote
Old 05-28-2013, 10:45 AM   #11
NoSpark
NoSpark's Avatar
Drives: 2010 GTI Autobahn
But how do you get 700whp to the ground with a GTI...
2010 GTI Autobahn, Deep Black Pearl Metallic, 2dr, DSG
Engine: APR K04 v3.1 |APR DSG Tune (K04)| APR Carbonio Stage 1 | APR Downpipe | Milltek Street CBE | Neuspeed FMIC
Suspension: H&R 24mm RSB | Neuspeed Rse12 w/ BFG Sport Comp2 | VW Goals w/ Dunlop Wintersport 4D
Cosmetic: Vacar LED Tails w/fog | Euro Switch | Euro Cup Holder | 30% 3M Tint | Carbon Vinyl Wrap
NoSpark is offline   Reply With Quote
Old 05-28-2013, 11:25 AM   #12
Toledo R
Drives: GOLF GTI
The GOLF R does not have traction problems. FWD car owners who want 700WHP, know what to do with it and how to get it on the ground.
Further edit:
I think that it may be possible to fit the TT RS pump mounting bracket on the area of the PCV. Look at the Forge Billet Block off plate and picture the mounting there, with a Billet cam underneath. If this works, then the TSI conversion will be as cheap as the TFSI one.
So, start talking to Forge about this idea.
John
Old 05-28-2013, 11:49 AM   #13
kern417
Drives: '09 Jetta
you have my attention
do a burnout.
Old 05-28-2013, 02:13 PM   #14
Eurononomous
Drives: 2010 GTI Stg3+
I been dabin all day what is this
awesome.
Eurononomous is offline   Reply With Quote
