Old 05-27-2013, 09:57 PM   #1
Mustache rash
Mustache rash's Avatar
Drives: 2011 K04 GTI 6mt
Diverter valve for relocation
So I'm in the market for a new diverter valve. Currently run running oem piston revision c relocated off the tbp.
The piston leaks as some of you may Or may not know. That plastic doesn't seem to seal too well against metal.
I'm comparing APRs R1, Forge 007 or AWEs Borg Warner .....
Anyone have any recommendations on which to go? They are all about the same price and all have different philosophy's to hold boost......
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 05-27-2013, 10:31 PM   #2
xytbyk
xytbyk's Avatar
Drives: FiST, V60 T6 R-Design
I used the 034 Spec DV on the relo for my K04, and it worked flawlessly. I also used these on my old allroad's 2.7TT. AFAIK, it's the same basic design as the Forge unit, which is based on the Bosch 710N design.
On these units, boost pressure holds the valve shut, so as long as it's not damaged, it shouldn't leak. I gutted the stock rev-c dv and kept the carcass plugged in to keep the ecm happy in my mk6, but you can also put a resistor in to make the setup cleaner if you want. There's a thread on here or vortex that shows you how to do that if you're interested.
My 034 DV also happens to be for sale, and I'm very flexible on price as it hasn't had a bite for over four months...
http://golfmk6.com/forums/showthread.php?t=51734
Sorry for the shameless plug (but please PM me if you're interested ).
EDIT: here's the 034 webpage: http://www.034motorsport.com/turboch...pec-p-781.html
xytbyk is offline   Reply With Quote
Old 05-27-2013, 11:01 PM   #3
GreasyGinzo
GreasyGinzo's Avatar
HKS with recirc adapter
Build Thread / Life Story
Old 05-27-2013, 11:09 PM   #4
mdhollis
mdhollis's Avatar
Drives: S3
The diverter valve screws into the tbp correct? It's leaking from the threads? I need a new diverter valve and was thing about relocating it there......
mdhollis is offline   Reply With Quote
Old 05-27-2013, 11:28 PM   #5
GreasyGinzo
You mean stock location? If so it bolts to the turbo itself.
Old 05-27-2013, 11:30 PM   #6
Rotaryknight
Rotaryknight's Avatar
Drives: 2011 GTi CSG
Woot! Old school style!
My Feedback
Old 05-27-2013, 11:38 PM   #7
ClapperHighs
ClapperHighs's Avatar
Drives: Mk7 GTI RS 6MT / 1983 Porsche 944
I'm using the R1 with a relocation kit I put together using the same basic set up as modshack, but with a few different parts to make it a bit cleaner and appealing to look at.
But the valve is great. Insanely quick is the most noticeable thing. If you have a boost guage you can see the before and after difference. So quick that you really can't hear it if you have and exhaust work done, because by the time you've let off throttle to shift and the engine noise drops, the valve has released and shut. So boost builds instantly. Much nicer throttle response. The car just seems to work much smoother in all types of driving. Especially around town. And it's maintenance free!
No complaints with it.
APR Stage 2 : SB stage 3 Drop In : Raceland Downpipe : BSH Race Intake : Coolingmist W/M CMGS : Polar FIS : Pagparts TB Spacer : BSH TB Pipe : Nuespeed TOP : DV Relocation : APR R1 DV : BSH Torque Arm Insert : Unibrace UB : Hotchkis 27mm RSB : 034 RSB End Links : VWR SS : 42DD Shifter Bushings : Verdict Bracket Bushings : Dark Cherry LED Tails : 245 Hankook Evo2's:
ClapperHighs is offline   Reply With Quote
Old 05-27-2013, 11:44 PM   #8
apa11393
I'm in the process of putting a dv relocation together right now, it's a really good idea for people spraying meth post ic. Can't decide on which dv either though...
Old 05-28-2013, 08:31 AM   #9
mdhollis
mdhollis's Avatar
Drives: S3
No, I have a bsh tb pipe I bought for my w/m setup. It has a port for a diverter valve relocate. I think that's where Rash has the valve and he says it's leaking. I was just curious about it because I want to do a relocate
Old 05-28-2013, 08:35 AM   #10
Mustache rash
Thanks for the replies and recommendations.
I'm probably going to go with the APR R1 since its matenance free and I'm a fanboy plus clapper is running a very similar setup as me and he's happy
Reading reviews, some reported sticking pistons in freezing temps with the forge/ other piston valves......ain't got no time for that....
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 05-28-2013, 08:39 AM   #11
Mustache rash
I'm running mine in the bsh pipe using atp diverter relocation adapter.
The OEM piston c does not seal well. It's plastic on metal, and leaks even when it's run in the stock location. Do some searches you will see.
I discovered this when I mounted the valve to the atp addapter and blew with my mouth to see if it was sealing. I was able to get a slight leak using my mouth so I'm sure almost 20psi is defenatly leaking....
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
Old 05-28-2013, 09:00 AM   #12
Djunited
Djunited's Avatar
Drives: K04 GTI
I have the cts tbp and a cts k04 that comes with a relocation. I want to change my rev d and im thinking wether i should relocated it to the pipe. Would it better that way? Also ordering a SP maf based w/m kit that with the nozzle placed it the tbp.what do you think?
BUILD THREAD bczracekar VIDS
Old 05-28-2013, 09:09 AM   #13
twistid
Drives: 2010 Carbon GTI
Similar to topic; Does anyone know a relocation kit that does NOT use the noise pipe?
twistid is offline   Reply With Quote
Old 05-28-2013, 09:22 AM   #14
Mustache rash
Modshacks method, u20-t had a sick setup. Anyway it's going to be a little custom but very easy.
I'm actually running modshacks old kit modified and u20-t hooked me up with the ATP insert and some knowledge...
This is modshacks DIY
http://public.fotki.com/ttschwing/gt...er-valve-relo/
Here's a pic of mine
2011 CSG GTI 6MT
APR K04 3.1
Build Thread
IG@mustache_rash
