trd420
Every hero has a journey. Every journey has an end. Two of 034Motorsport's most influential project cars are ready to embark upon new journeys of their own.
With years of development, testing, and racing under their belts, the 034Motorsport GTI-RS and 034Motorsport Time Attack A4 are ready to dominate a track near you
The 034Motorsport Time Attack A4 is a very successful purpose-built track car with a long history of success in various time attack series and magazine shoootouts. With a turbocharged four-cylinder engine putting down over six hundred horsepower at all four wheels, and a highly developed chassis, this car is capable of lap times that put so called "supercars" to shame
The renowned 034Motorsport Time Attack A4 is for sale!
This purpose-built race car is the result of years of extensive chassis, suspension, and powertrain development by 034Motorsport.
The 034Motorsport Time Attack A4 has progressed and evolved through seven years of successful competition in the upper echelons of time attack racing to become one of the fastest Audi time attack cars in the world. It has been featured in numerous magazines, and has secured countless podium finishes in the time attack circuit.
In its current configuration, with a heavily-turbocharged 2.0L four-cylinder engine making approximately 750 horsepower, the Time Attack A4 is seriously fast, and a formidable contender at the track. From a time attack standpoint, this is the fastest the Time Attack A4 has ever been, as well as the most consistent and reliable.
Magazine Features:
2007 Eurotuner Magazine Grand Prix - 1st Place AWD Road Course
2007 Primedia Super Lap Battle - 3rd in Class
2008 Eurotuner Magazine Grand Prix - 1st Place Dyno
2008 Primedia Super Lap Battle - 2nd in Class
2009 Eurotuner Magazine Grand Prix - Overall Winner (1st Place Dyno, 1st Place Drag Race, 1st Place Road Course)
2010 Super Lap Battle - 2nd in Class
2012 European Car Magazine Tuner Grand Prix - 1st Place / Lap Record
Racing:
2007 Redline Time Attack Series
2009 Redline Time Attack Series
2010 Global Tuner Grand Prix
Laguna Seca
2011 Global Time Attack
Infineon Raceway
2012 Pikes Peak International Hill Climb
Track Records:
Laguna Seca: 1:31.221
Sonoma Raceway (Infineon): 1:43.261
Thunderhill: 1:55.359
Streets of Willows: 1:22.386 (Street Tires)
Weight:
2,750 Pounds
Horsepower/Torque:
613.9 Wheel Horsepower
520.8 Wheel Torque
Technical Insight:
Click Here!
http://www.034motorsport.com/034motorsport-time-attack-a4-technical-insight-a-260.html
The vehicle is for sale with the configuration listed below, including spare suspension and drivetrain components
Asking Price:
$60,000.00
Complete, Set-Up, Ready-to-Race
Includes Spares Package
Serious Inquiries:
Email social@034motorsport.com
Call 877-591-9570 and ask for Christian
What you get with this car isn't just the parts list, but the extensive level of testing, upgrading and the knowledge that just about anything that could ever break on this car has and has been re-engineered and tested to ensure it cannot fail again.
034Motorsport B5 Audi A4 Time Attack Car - Technical Specifications
Vehicle:
2001 Audi A4 1.8T Quattro
Engine Block:
Modified TDI Tall-Deck (236mm) 06A Engine Block
Forged 92.8mm Stroke Audi/Volkswagen 2.0T FSI Crankshaft
Forged 159/21 Connecting Rods with ARP Rod Bolts
Forged JE Pistons - 83mm Bore / 8.5:1 Compression Ratio
ARP 06A/06B Main Stud Kit
ARP 1.8T Head Stud Kit
034Motorsport Coated Rod Bearings
034Motorsport Coated Main Bearings
Fluidampr Crank Pulley
034Motorsport Custom Dry Sump Oil System
Cylinder Head & Valvetrain:
Audi AEB "Large Port" 1.8T Cylinder Head
034Motorsport "Stage 3" Cylinder Head Porting
Supertech 1mm Oversized Intake & Exhaust Valves
Supertech Valve Spring Set & Titanium Retainers
Cat Cams 3658 Billet Camshafts
Turbocharger, Intake, Exhaust:
Precision 6262 CEA Turbocharger
Ceramic Ball Bearing
V-Band Inlet/Outlet .64 A/R Turbine Housing
4" Inlet / 2.5" Outlet "SP" Compressor Housing
034Motorsport Custom Tubular Exhaust Manifold
Tial 44mm Wastegate
Tial 50mm Blow Off Valve
034Motorsport Oil & Water Line Kit
034Motorsport Custom 3.5" Side Exit Exhaust
034Motorsport Custom Intake Manifold
034Motorsport Custom 4" Intake with Heat Shielding
Mitsubishi Evolution 8 Front Mount Intercooler
AEM Water Spray for Intercooler
Engine Management, Electronics, Fueling, Ignition:
034EFI Stage IIc Standalone Engine Management
AIM Sports MXL Pro Dash
034Motorsport Direct-Acting Boost Control Solenoid
034Motorsport 1.8T Fuel Rail
Siemens 840cc Fuel Injectors
ATL Fuel Cell
034Motorsport Surge Tank
Dual Bosch 044 Fuel Pumps
-6AN Fuel Lines
034EFI High Output DIS Coils
Drivetrain:
B5 Audi S4 “01E” 6-Speed Manual Transmission with 1-2 Dog Gears
3-6 Close Ratio Gear Set with WPC Low Friction Treatment
5:1 High Bias Center Differential
Drive Shaft Shop High Strength Front Axles
034Motorsport Clutch Type Rear Differential
034Motorsport Custom 6 Pound Aluminum Flywheel
Tilton 7.25” Twin Disc Cerametallic Clutch
034Motorsport Engine Mounts
034Motorsport Transmission Mounts
034Motorsport Rear Crossmember & Differential Carrier
Apikol Rear Differential Mount
JHM Short Shifter
Suspension & Steering:
Ohlins TTX36-Based Coilover Suspension
034Motorsport Custom Blade-Type Rear Sway Bar
Factory B5 Audi A4 Front Sway Bar
034Motorsport Adjustable Front Upper Control Arms
034Motorsport Spherical Front Lower Control Arm Bushings
034Motorsport Adjustable Rear Upper Control Arms
034Motorsport Spherical Rear Tie Rods
034Motorsport Spherical Front Sway Bar End Links
Electric Power Steering Conversion
Brakes:
Alcon Mono 4 Front Brake Calipers
Alcon Floating 330mm Front Brake Discs
034 Motorsport Wilwood Rear Brake Caliper Upgrade
300mm Vented Rear Brake Discs
Stainless Steel Braided Brake Lines
AP Racing Pedal Box
B5 Audi RS4 Aluminum Front Wheel Bearing Carrier
Wheels & Tires:
17x9.5 Enkei RPF1 Wheels
Continental ExtremeContact DW 285/40/17 Tires
Chassis, Safety, Aerodynamics:
034Motorsport Aluminum Front Subframe Mounts
034Motorsport Aluminum Rear Subframe Bushings
Custom Widebody
Complete 12 Point Roll Cage
Carbon Fiber Front Hood & Sunroof Delete Panel
AFFF Fire Suppression System
034Motorsport Custom Carbon Fiber Splitter
034Motorsport Custom Floor Panels & Rear Diffuser
APR Rear Wing
