Old 06-09-2013, 07:18 PM   #1
glory
Drives: 2012 2DR GTI
Rough Idle - Start up & Warm
For a few weeks now I have been having the problem of my car idling rough (I can feel it shaking through the seat) during cold starts and even when its warm and sitting at a light. I thought maybe it was a bad tank of gas, so I nearly drained her (had 80kms left) and filled her up again with 91 (highest we have in town). Issue is still there though.
What happens is when it's cold it really shakes and once the revs drop and idles normally it still shakes but not as bad. In traffic, idling it shakes enough to notice it. Sat in my mom's car (2012 GTI) and hers idles nicely (same gas station I use) from cold start to normal idling. Even my fathers 2011 Golf 2.5L idles more smoothly then mine.
I tried logging some info on it, and only thing noticeable was the knock sensor voltage on cylinder #1 was higher then the others (0.9V vs. 0.6V) and right off the bat it counted 4 misfires in cylinder #1. But I am unsure if the misfire counts are actual misfires or just from the car starting. After a minute or so the misfire counts went away. Any idea what I should be logging? Or should I just take it to my dealer and have them look at it?
Thanks in advance for the advice!
glory is offline   Reply With Quote
Old 06-09-2013, 07:32 PM   #2
ncampos976
Drives: 2013 GTI Autobahn
i would say, time for carbon scrub.
ncampos976 is offline   Reply With Quote
Old 06-09-2013, 07:50 PM   #3
Bino
Bino's Avatar
Drives: 2010 White GTI 2 Door
Looks like you gonna need a new intake. While there do that take a look at your valves. It's covered untill 60k miles.
Bino is offline   Reply With Quote
Old 06-09-2013, 08:22 PM   #4
glory
New intake? Carbon scrub? Wow was not expecting that. Can is stock engine wise, and has 16000 kms on it (9900 miles). Guess I should take it in under warranty eh?
Sent from the White north with magic
Old 06-09-2013, 08:34 PM   #5
Bino
Bino's Avatar
Well no carbon build up then. But sounds like you have a stuck intake runner. Common in these cars. Stock or not.
Old 06-09-2013, 08:51 PM   #6
kennega
kennega's Avatar
It's under warranty so I'd definitely take it in.
Another test if you're seeing misfires, I'd take cyl 1 coilpack and swap with cyl 2. If the issue follows to cyl 2, it's the coil. If not, swap plugs between the cylinders and again, see if it follows.
Kenny
APR Stage 3 | HEX-CAN
kennega is offline   Reply With Quote
Old 06-09-2013, 09:10 PM   #7
Bino
Bino's Avatar
Well I have new plugs and R8 coils when I had my intake replaced. I had misfires on cyl 1 and 3. After they replaced my intake and did a complete carbon cleanning. All misfires were gone.
Old 06-11-2013, 08:23 AM   #8
Talguy
Talguy's Avatar
Drives: GTI MKVI 2Dr DBP
Yea definitely change out your spark plugs and coil packs first before you do anything else. I've had pretty bad misfires on two occassions and they were solved by new spark plugs and coil packs
2010 GTI, Deep Black, 2DR, 6MT, Detroits @121kmi
APR Stg 2 :: Carbonio :: 42DD TBE :: Tiguan Pipe :: BSH Mounts :: ST :: TT LCA :: S3 Bushings :: APR Rear Sway :: Tyrol Subframe Kit & SSBB :: RSe12 (Silver) :: Hankook V12's @ 235/40/R18 :: DG SS :: HSTuning RSR :: UB & XB :: LED (interior & Exterior) :: MK7 R Reps (2Stroke LED) :: HID Fogs (5500k)
Waiting to be installed: Dreams & four corner BBK
Talguy is offline   Reply With Quote
Old 06-11-2013, 10:57 AM   #9
TXBDan
Drives: .
Holy jump to conclusions mat you people.
There are tons of things that can cause a car to idle rough. Get a VAGCOM and scan it before you go throwing random parts at it.
TXBDan is offline   Reply With Quote
Old 06-17-2013, 07:16 PM   #10
glory
Took the car in today and they said the problem is the fuel pressure regulator. They have to order one in and can't get me in until Friday.
Question, I am going on a 1300km round trip on Friday, should I not use my car or am I fine?
Old 06-17-2013, 07:32 PM   #11
maxtdi
GolfMK6 Elite
maxtdi's Avatar
I wouldn't use the car.
Old 06-17-2013, 10:03 PM   #12
glory
Ya, it's staying at home and taking a different car. Hopefully this fixes it.
Old 06-24-2013, 08:44 PM   #13
glory
Took the car into the dealer today and this is what they fixed:
-Replaced Injectors and seals (not fuel pressure regulator as I was told on the phone before)
-Replaced intake manifold position sensor
Haven't taken it on a long drive or a cold start yet, but hopefully this is all it was.
In the cause part of the write up this is what they put:
Faulty Injectors. Vehicle is running rough. Random misfires in value block 15. Code P2015 had come up for intake manifold runner position sensor. Intake was keeping vacuum.
Old 06-28-2013, 07:13 PM   #14
glory
So been a few days since the car was at the dealer. Didn't know if I was being too anal about it or just over thinking when I got it back, but there was a bit of shudder when idling. So thought a fresh tank of gas would help, well that wasn't helpful.
Still rough idle during cold start up and a slightly less rough idle during idling at operating temp. It is better then before, but I can still feel it. Found out today if idling in neutral and put the clutch in, the roughness becomes greater. Any idea what this could be? I'll be keeping an eye on it over the long weekend and give VW a call after.
