Old 08-04-2013, 08:43 AM   #15
caffeineTX
caffeineTX's Avatar
Drives: '13 | GTI 2DR | 6spd | Candy White
sub'd, can you maybe add some expanded info with pics for removal to get to your valves?
for the less mechanically inclined
instagram: caffeineTX
caffeineTX is offline   Reply With Quote
Old 08-06-2013, 03:19 AM   #16
redjet
Drives: 2012 red gli
Originally Posted by redjet View Post
So... I just did this today to my car, BUT got a question perhaps someone could chime in...
I kept having cyl4 misfire so I just changed cyl4 injector and then did this cleaning procedure. All went well and put back together, however now I am having this 1 pronounced tick while idle. Car drives better, smoother and more power however that ticking noise worries me. It is more pronounced than the typical valve ticking. It sounds louder and sounds like a pacer.
Ok here I've added the video for sound... for some reason it doesn't sound that loud here but it is loud... the taping sound in the back ground. Sounds like the electrical spark starter of a stove.
Didn't have this taping before the valve cleaning... maybe its because I only swapped out 1 injector???
redjet is offline   Reply With Quote
Old 08-06-2013, 08:43 AM   #17
lilfleck
Drives: '11 GTI Autobahn, DSG
I think thats just a side effect of everything ticking at full efficiency haha.
Old 08-06-2013, 05:50 PM   #18
ToMMyGuN
ToMMyGuN's Avatar
Drives: 2009 Pontiac G8 GT
There is a link to that in the first post:
http://www.golfmk6.com/forums/showthread.php?t=20985
My GTI is gone, but not forgotten:
Bringing an MK6 back from the grave
ToMMyGuN is offline   Reply With Quote
Old 08-06-2013, 05:53 PM   #19
ToMMyGuN
ToMMyGuN's Avatar
The tapping has nothing to do with the valve cleaning, but probably has to do with a loose part upon the re-installation of the intake manifold and throttle body. Can you isolate where the tapping is coming from? Hold a long screwdriver up to the engine block (metal end) and put your ear to the handle - does the tapping get alot louder in your ear? If so, then you may have a head issue. If not, it is probably something you did upon re-installation of all of the parts you took off.
How is your fuel economy after the injector replacement? You don't smell gas when you have the hood up, do you?
Old 08-06-2013, 07:28 PM   #20
redjet
No smell of gas, and the car drives great! and fuel economy got better than before (probably because of new injector and cleaning? )
Anyhow, drove the car about 400 miles so far and no cel either... just the ticking annoys me a lot when i'm next to a wall like my garage or a drive through....
I did have injector 2 get stuck on the fuel rail and when I seat it back on the block, I didn't change the o rings because I didn't have any.. maybe thats making the injector tick?
No visible leaks.
Interesting is that when I open the hood and try to hear closer where the tick is coming from, I can't hear the ticking. Only hear it while standing next to the car with hood down, however for sure it is from the engine bay.
Old 08-06-2013, 07:59 PM   #21
redjet
LOL here! I found another person with the same ticking sound as mine! and he video'd it better...
http://www.youtube.com/watch?v=LR6OoEP6ZXQ
Old 08-07-2013, 01:37 PM   #22
redjet
Upon research, it looks like my ticking is coming from the n80 evap valve.
Old 08-07-2013, 01:43 PM   #23
ToMMyGuN
ToMMyGuN's Avatar
Yeah, I was going to say evap valve. I think the ticking is normal, but if your's got alot louder after the cleaning/reassembly, you should take a second look at it. Try unplugging it and see if it goes away (you will get a cel).
Do you have vagcom?
Old 08-07-2013, 02:03 PM   #24
redjet
Yeup, I do have vagcom.
This is interesting topic... Most people on the forums state that it is normal and perfectly functioning fine and that the ticking is the symptom of a healthy n80 valve! LOL but when I compared this ticking to all my friends VW's, NONE of them tick as loud.
Yes, I do have vagcom and will unplug later see if the ticking goes away and if it does, I will have the dealer replace the n80 under warranty
To all this, did I miss reseting something with vagcom after connecting the battery? on my previous car I needed to align the throttle position and the butterfly position after a battery disconnect...
Old 08-07-2013, 02:06 PM   #25
ToMMyGuN
ToMMyGuN's Avatar
No, no vagcom resets needed apart from any CELs from disassembly. Post back on what you find with the n80 valve!
Old 08-07-2013, 03:15 PM   #26
DBESTGTI
DBESTGTI's Avatar
Drives: 2011 Stage 2 GTI
One major thing missed is covering the opening in the injector while its in the head of your cleaning valves. When carbon debris falls in the hole and clogs up an injector you'll be pissed buying a new one and taking it all back apart again to replace it.
Old 08-07-2013, 03:19 PM   #27
ToMMyGuN
ToMMyGuN's Avatar
Really good point here guys! Thanks DBest!
Old 08-08-2013, 02:07 PM   #28
redjet
Hmmm... so yesterday I unplugged the wire harness from the N80. It gave me a check engine code p0444 which is about right, however the ticking was still there...
I'm wondering if I needed to unplug the hose instead of just the harness..
At this moment, the ticking is exactly the same as
http://www.youtube.com/watch?v=QiAo7OfeAsQ
Wonder if its the new cyl 4 injector that is defective making the noise... don't see what else could have gone wrong during the cleaning...
dubpl8 is 5'6" haha, he can blow standing up, redjetblowsloadsondudes, tommygunsdudesbuttholes
