Old 08-13-2013, 10:17 AM   #43
ToMMyGuN
ToMMyGuN's Avatar
Drives: 2009 Pontiac G8 GT
What does the idle speed show on the tachometer? When you took off the intake manifold, did all of the injectors stay in the head? Or did they come out with the manifold?
My GTI is gone, but not forgotten:
Bringing an MK6 back from the grave
ToMMyGuN is offline   Reply With Quote
Old 08-13-2013, 08:50 PM   #44
redjet
Drives: 2012 red gli
I think the car is back to normal... man my mpg has been amazing these last few days...
Probably the car needed to readjust everything after the battery disconnect....
And yes, when I removed the manifold, all the injectors came out with it LOL... But so far don't smell gas nor see any leaks... Will probably change the injector O rings in another 20k miles when I get inside to clean the valves again.
Cheers! and thanks for all the help!
redjet is offline   Reply With Quote
Old 08-14-2013, 03:01 PM   #45
timneedscoffee10
timneedscoffee10's Avatar
Drives: 2011 VW GTI w Sunroof
How much effort was it to get the intake manifold removed? I've read the DIY over a couple times, but don't have a clear picture of it in my head. I'm going to do the valve cleaning in a couple weekends, and am right at 60k miles now. Since I'm still struggling to diagnose my fluctuating idle during warm-up, I'm wondering if my intake manifold may just be a ticking time bomb at this point. Since a new one is only $150, I'm inclined to just replace it - and since I'm doing the valve cleaning anyway, I feel like I should just pick one up and do it then... but if it's really simple to remove the intake manifold again later, I'll hold off and see how just the valve cleaning does.
Old 08-14-2013, 04:00 PM   #46
ToMMyGuN
ToMMyGuN's Avatar
Haha yeah, if you had a faulty injector your fuel economy will now seem godly compared to before.
Good to know your car is back to normal - same thing happenes with my o2 sensors. It just needed some miles to burn off the crap on thw m from the cleaning and re-adjust.
If you don't have any misfires, your idle is good, your WOT runs are still at full power, and you are getting good mpg, then odds are your injector seals are good to go
Old 08-14-2013, 04:06 PM   #47
ToMMyGuN
ToMMyGuN's Avatar
Well, it took me 3 hours to get the manifold off, and ~ 2.5 to get everything back together. It is a pain in the ass getting the throttle body off, and the fuel injector wiring requires baby hands to unplug. You be the judge, but if it was me, I would just replace it then and not have to worry about it failing in the future either, since that is a common thing to go out with our tsi's anyways.
Put it this way - this is not a simple enough thing to just do when it fails on a moments notice - with this repair/cleaning, you need to plan it out ahead of time that your car will be down for a day at least. If the intake manifold were to crap out on you while on a commute to work or on vacation, you would be severely kicking yourself that you didnt just replace it then.
Old 08-14-2013, 05:58 PM   #48
timneedscoffee10
Put it this way - this is not a simple enough thing to just do when it fails on a moments notice - with this repair/cleaning, you need to plan it out ahead of time that your car will be down for a day at least. If the intake manifold were to crap out on you while on a commute to work or on vacation, you would be seveeely kicking yourself that you didnt just replace it then.
Haha - that's what I needed to know. Just ordered a replacement manifold.
Old 08-14-2013, 09:54 PM   #49
redjet
Tommygun! I'm not gone yet ! LOL
Last night just for the heck of it, I borrowed my friends vag com cable... and I realized that my car has misfire on all cylinders!!! random misfire but it happens when there is not much load on the throttle... arghh..... at full wot, it doesn't misfire. Just misfires randomly on all cylinders when cruising.
So today, I installed back the red R8 coils I had in storage... car idle is perfect I mean it seems like the engine is off! runs smooth, power is great and the great mileage hasn't changed... however still misfire.. will give it a few miles and see if anything adjusts...
Just might have to change the seals on all of them injectors eh?
Old 08-15-2013, 09:11 AM   #50
ToMMyGuN
ToMMyGuN's Avatar
Hmmm.. so did you clear all of the misfire codes after you instaled the r8s but the misfire codes came back?
Can you notice the misfiring? Does the car shudder at all when it idles cold?
A few things for you to try before you rip the manifold back off:
-Lightly tap on coil packs w/ rubber mallet to ensure threy are seated correctly.
-change one spark plug and see if that cyl's misfires go away
-check for boost leaks on the throttle body piping
-buy a decent injector cleaner, add it on your next fill up, and drive it normally to see if that gets any gunk out of your injectors/fuel rail (unlikely to help, but maybe)
Again, make sure your not getting a false reading by looking at old stored misfire codes. Clear everything then take another look.
Can you post your Vagcom results here? I mean a full scan too, not just the engine portion
Old 08-15-2013, 01:09 PM   #51
redjet
The misfires are only shown when logging on vag com. logging 014/015/016
I don't get any cel or epc.
When cold, car vibrates like when you run the A/C on. Nothing Major. but once it warms up, it drives like a champ...
Just concerned that Vag com logs shows random misfires on all cylinders...
Old 08-15-2013, 02:04 PM   #52
ToMMyGuN
ToMMyGuN's Avatar
Wait, so you are not getting misfire codes thrown?
Old 08-15-2013, 05:04 PM   #53
redjet
That is correct. No check engine light and no codes thrown. However when I am data logging the engine with Vag Com (vcds) on reading values 014, 015,016 it shows misfires logged on all cylinders at anytime.
Old 08-15-2013, 08:07 PM   #54
ToMMyGuN
ToMMyGuN's Avatar
As in, always its showing misfires? Or is it random? I guess I wouldn't worry about it if it isn't throwing codes... you said the idle is back to normal now or not?
Old 08-15-2013, 10:09 PM   #55
redjet
Yes, Idle is smooth as silk (when engine warmed up.. ) when cold starting, it hesitates a little...
The misfires are shown random on vcds logs. It happens at any given rpm but usually while cruising. no misfire at Idle. No misfire up top high revs. Oh well... maybe there is a big piece of gunk stuck somewhere after the valves... going to seafoam it and go on a long drive to see if things get better..
Old 08-16-2013, 02:56 PM   #56
ToMMyGuN
ToMMyGuN's Avatar
Hmm, well the seafoam might help, but its unlikely.. can you notice it missing? I mean, if its not throwing a code for it, I would think its fine.. its misfires on all cylinders though, not just one or two?
dubpl8 is 5'6" haha, he can blow standing up, redjetblowsloadsondudes, tommygunsdudesbuttholes
