Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Marketplace > Vendors Classifieds > Exterior Parts
Old 04-22-2014, 09:38 PM   #43
deAutoLED.com
GolfMK6 Official Vendor
deAutoLED.com's Avatar
Drives: VW
All LEDs are packed in easy to open anti-static bags, and labeled.
& now you can shop by your car model, easy to find every LED for your car:
http://deautokey.com/shop-by-car-model
Old 04-25-2014, 06:53 PM   #44
deAutoLED.com
Drives: VW
Search LEDs by your car model, quick and simple.
If you do not see an LED listed, please contact us and we can get one manufactured for your model: deAutoKey@gmail.com
Our LEDs are tested in your car to be the brightest and best LED on the market.
http://deAutoKey.com/shop-by-car-model
Old 05-13-2014, 02:25 PM   #45
deAutoLED.com
Drives: VW
Don't forget! FREE SHIPPING ON OUR ENTIRE WEBSITE FOR ALL US ORDERS!
www.deAutoKey.com
Old 05-17-2014, 09:46 PM   #46
deAutoLED.com
Drives: VW
Like Us on FB for an Instant $3 OFF Coupon!
Click image below to take you to the coupon:
Old 05-31-2014, 11:40 AM   #47
deAutoLED.com
Drives: VW
Get the brightest LED for your trunk with no hassle at our low introductory price. [THIS FITS ALL CAR MODELS]
To purchase:
http://deautokey.com/product/univers...all-car-models
We did the research, and created the best and brightest LED for your trunk, our 48 LED Strip simply lines your trunk, with either 3m tape or velcro which are both included.
This is the best solution for a dark trunk, easily installs and hides:
-Plug & Play
-Error Free
-48 Bright White LEDs (Also comes in red)
-Enough LEDs to light up your entire trunk but short enough to fit any trunk, can install vertically or horizontally.
-Long wire, that is an all stealthy black which allows for an easier clean install, this wire is long enough to place anywhere in your trunk
-Strong 3M tape & Velcro so you can install on any hard surface or trunk lining (please use a blow dryer to heat the 3M glue and cold metal, this will activate the glue)
-Resistor which allows for the light to stay on and not dim if your dome lights shut off while trunk is open. This feature is a must have, it allows for a bright continuous light at all times.
-Trunk LED will not stay dimly lit when your car is off.
-Comes with 3 adapters: Wedge, Adjustable Festoon, and Bayonet, this will fit every trunk adapter on the market.
Actual LED strip measures: 31 inches – this length will fit all trunks, can install vertically or horizontally.
Black Wire measures: 52 inches – please note- excess wire simply tucks into your trunk’s housing/lining so you will not have any leftover in your trunk.
Includes:
1 LED strip with strong 3M tape attached
3 Adapters (Wedge/festoon/bayonet)
3 Pieces of velcro
Old 06-01-2014, 07:34 PM   #48
Ronin
Drives: 2013 csg gti
I didn't see it stated anywhere specifically. Are the reverse LED's compatible w/ the depo reps?
Ronin is offline   Reply With Quote
Old 06-10-2014, 10:23 PM   #49
deAutoLED.com
Drives: VW
Yes, we thought it said in the listing, we need to update it, but our reverse LEDs will work for any euro tail:
http://deautokey.com/product/mk6-gti...ree-and-bright
Thank you
Old 06-28-2014, 09:53 PM   #50
deAutoLED.com
Drives: VW
Old 07-03-2014, 02:43 PM   #51
deAutoLED.com
Drives: VW
There will soon be a new and better way to browse and purchase LEDs - deAutoLED will be launching by the end of the year, like us on FB to keep up to date with progress, new exciting products, and coupon codes you cannot find anywhere else:
www.Facebook.com/deAutoLED
@deAutoLED
Thank you for the support
Old 08-20-2014, 01:37 PM   #52
deAutoLED.com
Drives: VW
Our new color changing footwells allows you to have over 15 different colors with a click of a button.
Add a unique look to any car in seconds
Different colors for each footwell or the same
Product includes 2 bulbs + 1 remote which operates both sides.
http://deAutoKey.com/product/remote-...-bulbs-194-921
Check out the video and see what these can do:
https://www.youtube.com/watch?v=ko1nnEp3W0Q
DIY on how to install bulb-this will replace your stock bulb - no extra wiring or coding required, this installs directly in your stock housing:
https://www.youtube.com/watch?v=P7pGs8tAUDY
Old 09-26-2014, 02:07 PM   #53
Nineeightgolf
Drives: 2011 gti
Originally Posted by deAutoKey View Post
This works with the replica. You just choose the option for 1 reverse LED.
http://www.deautokey.com/product/mk6...ree-and-bright
We provide you with 194 CREE LED Wedge and the resistor/taps you will connect to your brown and yellow wire that are coming from the reverse housing on your taillights.
The DIY video found here will guide you, it takes 2 minutes to install the t-taps:
MK6 Euro Tail Reverse LED Kit Install DIY:
http://www.youtube.com/watch?v=iuX_dXxZjLE
Thank you
I just finished installing my replica led taillights and based on your advice here, I purchased the single reverse light kit. The drivers side of my taillights has a red bulb in a clear housing which lights up when the car is in reverse. I believe this a rear fog? Either way, I want to run LEDs on both sides but before I return the kit I purchased, I am curious if you know whether or not the kit will work on both sides of my car. Thanks!
Nineeightgolf is offline   Reply With Quote
Old 09-26-2014, 02:16 PM   #54
deAutoLED.com
Drives: VW
If you purchased 1 LED reverse, then you can install it on the non-fog light side. For the red fog light, the person who sells them said you cannot replace that bulb.
please let us know what you are trying to do and email deAutoLED@gmail.com for information on how to help you.
Thank you
Old 10-06-2014, 09:31 PM   #55
deAutoLED.com
Drives: VW
BRIGHT - ERROR FREE
This is a small bulb with a lot of power! No other bulb with this many lumens can fit into this housing!
EURO TAIL:
And a new brighter plug and play error free reverse LED for your OEM MK6 Tails:
http://deautokey.com/product/reverse...ite-error-free
Old 10-15-2014, 10:33 PM   #56
jay745
jay745's Avatar
So I couldn't find a thread for the led city lights so I'll post here. I just bought the city lights with resistors that are supposed to be error free, I got a bulb out error right away after installing them. Has anyone else had this problem? I mean I guess I can just code it out with vag com but it sucks that I paid extra for the resistors to avoid this
Sent from my SCH-I535 using Tapatalk
