So I got in contact with GFB too asking about the DV relocate for the GTI. If the bore size of the DV adapter is the same as the factory inlet:
Also,
As for any GTI that is K04, you will want the new DV+.
If it is removed remotely and the bore is the same size as stock it will not be a problem.
Also,
we will be doing some testing in a couple of weeks as well to see if the current valve will work on a gti with a remotely located valve.
We are unsure at this stage if the new valve for the Golf R will work on the factory location in the GTI. There will be two separate products we think, as the air discharge diameter is smaller on the turbocharger. With the new DV+ on the GTI we think might have light surging or (fluttering) as it is basically designed for the R situation.
Cheers,
Gunda Adrian
