I just want to double check. There's no way to run the LEDs as DRLs and parking lights (euro switch) other than using the jumper wire inside the harness, right?
I currently recoded my lights to have the LEDs as parking lights and have no DRLs that way i can have full control, but I'd still like them to turn on without me having to turn the switch each time I get in and out of the car.
Correct. (ish)
Not sure I get what you want in second paragraph.
The LEDs are wired as the parking lights. So standard coding is that they are off with switch in off position. In parking light position they come on and also on in low beams position.
Seems like you put your coding back to that.
So are you saying you want them as drls as well?
The lights have no wiring for the drl pin circuit inputs. So you have to add the jumper wire to take the drl circuit signal to connect to the LEDs (parking lights) in order for them to come on and complete the drl circuit. Then the LEDs are on as drls and also as parking lights and with low beams.
You could try changing the coding to have parking lights as drls. This should change the drls circuit signal to be the parking lights (LEDS). So without the jumper wire the LEDs should then be your drls. But when you put it to parking lights the LEDs go off and the they are also off with low beams. So adding the jumper wire, like above, keeps the LEDs on in all three modes.
So the coding doesn't really matter.
I think my coding is set to have drls as parking lights (second way above) and I think I have the sidemarkers also on with drls. This I don't want and have been meaning to investigate to figure it out but I just haven't bothered yet. I also get the HIDs flicker on startup when drls are on.
For completeness, I also have the auto sensor for my euroswitch, depo LED tailights with rear fog and byte 18 coded to 04.
Is this what you wanted to know?
