Old 09-13-2013, 05:39 PM   #1
Arin@APR
GolfMK6 Official Vendor
Arin@APR's Avatar
Drives: B8 S4 & MK5 GTI
APRís Pleased to Announce Free Updates to our Golf R ECU Upgrades!
APR’s Engineering Teams have finished final testing of new version 3.31 Stage I, I+ and Stage II+ 2.0T ECU Calibrations for the Golf R. The new ECU Upgrade improves upon power deliver on top of what was previously a tremendous upgrade over stock! Amidst addressing all previous concerns, additional motorsport features were added to further enhance your driving experience. All updates are now available at APR dealers around the globe and are offered as a FREE update for all APR ECU Upgrade customers!
APR’s Calibration and Software Experts focused heavily upon increasing the overall drivability and performance of the 2.0T well beyond dyno numbers alone. Through implementation of the new patent pending APR Boost Control Strategy shared with our Stage III Turbocharger System, the ECU is now able to properly control boost pressure levels much higher than possible with the factory code alone. Specific calibration changes were made to enhance turbocharger spool rates, reducing lag to give the drive a more direct and connected linear feel to the accelerator pedal. Overall volumetric efficiency was enhanced through calibration changes resulting in more ignition advance towards redline, cooler exhaust gases, increased power and torque, and improved fuel economy depending on driving habits.
To further enhance your driving experience, APR outfitted the 2.0T with a Quattro GMBH inspired Motorsport Revlimiter as found on all other R and RS models currently being produced. Rather than softly slowing down acceleration several hundred RPM before the rev limiter, the 2.0T will now freely rev up to the new, clearly identifiable redline at 7,100 RPM and may make all the difference in a competitive head to head sprint on the track!
APR’s pleased to announce intake specific calibrations for use with high quality intake systems removing the factory engine cover. The factory Golf R’s intake is integrated into the engine cover, presenting a restrictive intake setup from the factory. APR’s Calibration Experts were able to extract more power from the engine by running the VWR intake system, which removes the factory cover. By removing the factory intake system, the engine’s operating parameters could be dramatically changed, but in doing so, other parameters were adjusted to ensure smooth operation with strict boost control, no throttle closure and surge avoidance in the low to mid RPM range. Expect more power and a better driving experience!
With now over 60 combinations of ECU Upgrades available for the Golf R platform alone at various levels of modification and fuel grades, APR’s sure to have an ECU upgrade to fit your needs! Take a look at some of the example outputs measured below.
The Following Power Output Charts are available. Click the text below to see the graph.
APR Stage I
91 Octane - Estimated Crank HorsepowerMeasured Wheel PowerGain Over Stock
93 Octane - Estimated Crank HorsepowerMeasured Wheel PowerGain Over Stock
APR Stage I & VWR Intake System
APR Stage I+, APR HPFP & VWR Intake System
APR Stage II+, APR RSC Exhaust, APR HPFP & VWR Intake System
100 Octane - Estimated Crank HorsepowerMeasured Wheel PowerGain Over Stock
To find a local APR dealer, please use our dealer locater tool.
http://www.goapr.com/dealer/
Go APR
Old 09-13-2013, 05:43 PM   #2
ROOSTER1050
ROOSTER1050's Avatar
Drives: MKVI CW GTI K04DR -DSG
DAMMIT, I hope this means we are ever so close(r) to the TSI K04 update!!!!!
SPM DP/SPM CBE track/street/CTS K04+APR V3.1C/APR DSG tune/UNITRONIC intake/VWR springs/Koni Yellows/UNIBRACE UB+RB+XB/Neuspeed FMIC/VMR V810/034 mounts/APR F+R SB/Neuspeed Charge&TO pipes/LED tails w-fog/GFB DV+/P3 gauge/Whiteline-A.L.K.+ end links/R8 coils/TT-RS Brembos/Neuspeed pulley
ROOSTER1050 is offline   Reply With Quote
Old 09-13-2013, 06:12 PM   #3
GP813
Drives: 2015 Audi S3
One less hurdle in front of the K04 update! APR is closing out the year on a roll.
Arin,
I'd like to have that fender decal on my car, how do I go about purchasing one from you guys? I was told it used to be for sale through you folks.
GONE |APR K04 | APR FMIC | APR TBE | APR Carbonio stg1+2 | Neuspeed TOP + TBP | Eurocode Rotamass pulley | APR Boost Tap| VWR Subframe Mount| VWR Streetsport+ Coilovers V2.0 | H&R 24mm/22mm swaybars | Neuspeed rear end links | ST 328mm w/ Motul RBF660 | Neuspeed SS lines | Unibrace XB+UB+RB | P3 Gauge | Daily: 18" BBS CO in Black | Track: 17" Neuspeed RSE05 Red | GONE
Now: 2015 Nardo Grey Audi S3
GP813 is offline   Reply With Quote
Old 09-13-2013, 06:18 PM   #4
Arin@APR
Arin@APR's Avatar
Arin,
https://store.goapr.com/products/APR...r%252dRed.html
Old 09-13-2013, 06:42 PM   #5
Spyder368
Drives: SBM 2012 GTI 6MT 2DR
Hopefully closer to the Stage 2 update for my GTI*!
2012 SB GTI 2D / APR Stg II / FST Stg 3 daily clutch kit / Billy Boat TBE / Unitronic CAI / Unitronic DV Relocation Kit / Neuspeed FMIC / Forge Short Shift / VWR Springs / APR Boost Tap / AWE Boost Gauge / AWE TOP / Integrated Engineering SBB / Spulen DB Insert /Soundaktor Delete
Spyder368 is offline   Reply With Quote
Old 09-13-2013, 06:48 PM   #6
Arin@APR
Arin@APR's Avatar
Originally Posted by Spyder368 View Post
Hopefully closer to the Stage 2 update!
I don't understand?
Old 09-13-2013, 07:15 PM   #7
excelevant
excelevant's Avatar
Drives: '14 5.0 Track Pack
Any word on a TSI 2+ update that fixes the stupid accelerator pedal?
excelevant is offline   Reply With Quote
Old 09-13-2013, 07:18 PM   #8
Halvie
Drives: 2010 Penalty Box
what do you mean?
Old 09-13-2013, 07:19 PM   #9
excelevant
excelevant's Avatar
The general unresponsive nature of the pedal on tip in. GIAC claims to fix it
Old 09-13-2013, 08:29 PM   #10
mwrmt
mwrmt's Avatar
Drives: 2012 MKVI R
Send a message via Yahoo to mwrmt
Arin,
did APR run numbers with the Carbonio set up? I think it would only be fair to see the difference as APR sells both setups.
Either way, thanks for the updates.
You're living inspiration for what I never wanna be - Sully Erna/Godsmack
2012 Deep Black Pearl "R" back on PSS10's; APR Stage 2+(v3.31) w/Neuspeed CAI, TOP & Charge pipe; APR HPFP & TBE; Audi R8 coilpacks; 42DD shifter bushings; TyrolSport Solid Shifter Bracket Bushings, Neuspeed RSe52's on Michelin PSS...
mwrmt is offline   Reply With Quote
Old 09-13-2013, 08:30 PM   #11
Arin@APR
Arin@APR's Avatar
We didn't. Sorry.
Old 09-13-2013, 08:42 PM   #12
Dmueller343
Dmueller343's Avatar
Drives: 2013 RB Golf R
Arin,
I bought this decal a few months ago for my car off their website and switched around the colors
2013 2-Door Rising Blue Golf R, APR Stage 3 Turbo | APR HPFP | APR FMIC | APR RFD | Carbonio Intake | Roc-Euro Midpipe | Magnaflow Catback | Haldex Race Controller | SB Stage 3 Endurance Clutch | DG Short Shifter | BFI Shift Knob | ST Coilovers | H&R Rear Sway Bar | Dogbone Insert | OEM LED Taillights | NSP Boost Guage | 15% Tints All Around | Color Matched Emblems and Sidemarkers | Black Powdercoated Wheels | Maxed Interior Mods |
Dmueller343 is offline   Reply With Quote
Old 09-14-2013, 03:06 PM   #13
lamb110
lamb110's Avatar
Drives: Your mom
^^^ Is that why your car is slow?
I fap to porn. I wont lie.
Old 09-14-2013, 03:09 PM   #14
Dmueller343
Haha 10hp each sticker. We shall see who's car is slower at dyno day. You running 100?
my bung hurts. going uni., tsi owners get shafted
