Old 09-14-2013, 05:40 PM   #1
lilfleck
Drives: '11 GTI Autobahn, DSG
Mid install of K04 - need some help
Two things,
One, I'm still fighting the 6mm Allen holding the heat shield on top of the exhaust runners.
Two, the downpipe studs on the k04 (used) are a little dirty. I'm going to try to retap the threads to clean them and then try the new downpipe nuts.
One of the studs came out with the nut. Can I reuse the stud? Could I reuse a stud from the ihi? Do I need a special tool?
Sent from my Galaxy Nexus using Tapatalk 4
Old 09-14-2013, 06:47 PM   #2
Cryptic1911
Drives: 2008.5 GTI TSI
don't retap them to clean, hit them with a wire brush to clean the gunk off. As for the other stuff, I'm not sure
Old 09-14-2013, 11:06 PM   #3
Kal-GTI
Kal-GTI's Avatar
Drives: 2002 Jetta TDI; 2008 GMC 2500HD SLT
I ripped the f'n heat shield out by hand on my car because I stripped that third screw out. Not reccomending that but it's an option. Try going in on the right side of the engine where the intake piping was.
VAG-COM in Kentucky; PM me if you need assistance
Kal-GTI is offline   Reply With Quote
Old 09-15-2013, 12:50 AM   #4
lilfleck
Finally got it... Took a special Allen with a ball on the end. Now I'm stuck on the turbo bracket Allen.. Same issue. It's freaking stubborn. Will continue in the morning.
I'm just really scared of stripping bolts.
On a side note, anyone know how to remove this vacuum line?? I was squeezing and pulling like no other.
Old 09-15-2013, 01:01 AM   #5
lilfleck
The garage... Jack stands suck!
Old 09-15-2013, 02:08 AM   #6
Cryptic1911
get a maxjax low height 2 post lift in there!
Old 09-15-2013, 02:52 AM   #7
KKrayZee
Drives: Golf 2.0 TDI
get some loctite stud lock pur the stud back in leave overnight then try taking the nut off again should work,
if you have the exact same size die, should work too clean threads, but a wire brush is safer
KKrayZee is offline   Reply With Quote
Old 09-15-2013, 04:45 AM   #8
GreasyGinzo
GreasyGinzo's Avatar
You can chase the threads for the studs with a tap but its imperative you use the correct size tap and run it in true. When chasing threads you run it straight in and out not 1 turn back a half like you are cutting new threads
Build Thread / Life Story
Old 09-15-2013, 08:35 AM   #9
Kal-GTI
Kal-GTI's Avatar
Comes apart like the Pcv connector on the intake piping. If I'm looking at the right vacuum line.
Old 09-15-2013, 10:11 AM   #10
lilfleck
Well it's morning now. I will try to loctite it first thing. What is the best way to tighten the stud to the turbo?
Ok. Will try a wire brush first.
That was just as difficult...
Old 09-15-2013, 10:34 AM   #11
lilfleck
is removing this necessary?
Old 09-15-2013, 10:35 AM   #12
2013R
FIA Formula 1 Champion
2013R's Avatar
Drives: 2015 Subaru WRX
sucks. almost guaranteed to crack if its old and brittle. like mine did. dont use any sharp tools like screwdrivers, just keep trying with your hands
2015 Subaru Forester XT
LastHumansGarage
Old 09-15-2013, 11:43 AM   #13
Brunkel
Brunkel's Avatar
Drives: 2013 UGM GTI; 6-speed manual
Hey but you have a garage! And it looks like a nice collection of tools too!
Build Thread
Hi-Def Detailing
Brunkel is offline   Reply With Quote
Old 09-15-2013, 02:52 PM   #14
SixSpeeder
SixSpeeder's Avatar
Drives: Dat
Sub
2015 Camaro SS RS NPP
SixSpeeder is offline   Reply With Quote
