Old 05-31-2016, 02:45 PM   #29
RichBGTI
RichBGTI's Avatar
Drives: 2011 Candy White GTI
DIY K04 Install Notes/Helpful Tips
So brute force prevailed. Removed what bolts I could from the heatshield and then fatigued the shield until it broke off. I'll deal with the bolt once the turbo is off and can access more freely and replace heatshield. Tried a torx and bigger hex hammered in to no success.
Got a screw extraction kit coming tomorrow so will give that a pop.
Got the 5 manifold bolts loosened and with the heat shield out the way. Can see and with relative ease get to the downpipe studs with a socket, so things are looking up!
2011 GTI | Milltek TBE | APR Carbonio | F23T | TTRS Brembo | ST XTA Coilovers | do88 IC | AEM WMI
Instagram: @richbrdfld
RichBGTI is offline   Reply With Quote
Old 06-02-2016, 11:36 AM   #30
lilfleck
Drives: '11 GTI Autobahn, DSG
So the heatshield bolt is connected to the manifold not the head?
Old 06-02-2016, 11:37 AM   #31
RichBGTI
RichBGTI's Avatar
No, it's in the head.
Old 06-04-2016, 09:23 PM   #32
Geryon86
Geryon86's Avatar
Drives: MK7 R
16' LB R | DSG | APR Stage II HT |
11' SB GTI
|DSG|APR v3.1|CTS K04|
Geryon86 is offline   Reply With Quote
Old 06-06-2016, 08:26 AM   #33
Brunkel
Brunkel's Avatar
Drives: 2013 UGM GTI; 6-speed manual
Sub'd! Great write up!
Build Thread
Hi-Def Detailing
Brunkel is offline   Reply With Quote
Old 06-06-2016, 03:21 PM   #34
RichBGTI
RichBGTI's Avatar
These writeups really are invaluable!
Old 06-06-2016, 03:28 PM   #35
RichBGTI
RichBGTI's Avatar
So that plug.
Different position on TSI. It's between cylinder 3 and 4 around the same height as the pic above.
Once the the turbo was off, I was able to get the plug out. I could see what it may have been taken out at some point in the past and was already a bit rounded off which prevent the hex from fully seating. Was able to hammer in a hex and was fine. Hard to check when everything is in the way.
hammering in an XZN bit does the job too!
Old 06-06-2016, 10:58 PM   #36
Geryon86
Geryon86's Avatar
Drives: MK7 R
Originally Posted by RichBGTI View Post
So that plug.
That is a TSI and it is between cylinder 3 & 4. It's a picture of the back of the engine with a mirror.
11' SB GTI
Old 06-07-2016, 01:54 AM   #37
RichBGTI
RichBGTI's Avatar
Ha, didn't spot the mirror!
Old 06-10-2016, 09:28 PM   #38
Brunkel
Brunkel's Avatar
Are these just basic locking plyers? The eBay link you posted is down.
Build Thread
Hi-Def Detailing
Old 06-10-2016, 09:59 PM   #39
XGC75
XGC75's Avatar
Drives: into shit
^^ for those and the bolt holding the banjo on the fluid line to the turbo it's best to use a triple square set with some kind of hex pattern on the bit just before the socket end. What I did was to put the M(something) into the bolt, then used a 10mm crescent wrench to torque the M(something) bit.
Edit: like so:
Sincerely, XGC75
Old 06-10-2016, 10:33 PM   #40
Brunkel
Brunkel's Avatar
Edit: like so:
Sincerely, XGC75
Nice! I have the this kit per this thread: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
so that should definitely work. What other tricks you got for this install!?
Ordered my long reach ball head hex socket set for the 6mm...
Just from reading everything I feel like when the heat shield comes off it should just rain beer from all cylinders in celebration.
EDIT. Holy crap...I see you're in SW Michigan. Where at? I'm 20 minutes from the boarder.
Build Thread
Hi-Def Detailing
