Old 09-28-2013, 01:39 AM   #1
cased
Drives: 2013 CW GTI
Slight Vibration in steering wheel, gas pedal, and sometimes seat
I had my wheels balanced at VW during a check back after I told them I felt a pretty bad vibration in the steering wheel at highway speeds. Took the car home, still didn't feel great. So I took it to a local tire place and had them road force balance it. Got the car back, and the violent steering wheel vibrations caused by needing a wheel balance were gone, but what remained was a slight vibration in the steering wheel, and now gas pedal.
Decided to call VW back, and had them look at it again. Explained what I felt and they called back later in the day and told me a technician HEARD (I never heard anything, only felt) something from the right front wheel. They told me it was a bad wheel bearing. They replaced it under warranty and I went back and picked up my car. The vibration felt through the steering wheel and gas pedal were still there, and now I could feel it in the seat as well. Called them back and dropped it off again. They called me and told me they felt nothing.
I figured I might have been feeling to sensitive to it, so I drove it for a week or so, and it still just doesn't feel right. I can start feeling it at about 40ish, all the way up to in the 70s. I don't really feel it under hard acceleration, but rather just light acceleration, like just keeping your foot on the pedal at cruising speeds.
Its hard to describe, because when people hear "steering wheel vibration" they think wheel balance. It's not quite as violent as that, and my wheels have been balanced twice. It's almost like you're on a rough road, and you can feel every bump. I can mostly feel it in the gas pedal, and steering wheel. Only sometimes in my seat.
Sorry for this wall of text, I've been very frustrated about it, and finally decided to post to see if anyone had any information.
cased is offline   Reply With Quote
Old 09-28-2013, 12:04 PM   #2
Modshack
Modshack's Avatar
You might have a slightly bent/dented wheel. Those are some of the symptoms.
Old 09-28-2013, 01:27 PM   #3
mikeleemk6
mikeleemk6's Avatar
Drives: Shadow Blue GTI MK6
Im gonna go with modshack. Might have to pull the tires and see if a rim is bent/dented.
Old 09-28-2013, 01:42 PM   #4
Burntchicken
Burntchicken's Avatar
Drives: '10 Man. Black Gti
I have the same vibrations as you describe, it's because I have to replace my left control arm bushing. Jack up your car so the front tires are in the air and get up to that speed, if your car vibrates that might be it, if not it might be the wheel or axle or something.
BFI Motor Mount, stage 1 neuspeed intake, resonator delete, godspeed catless downpipe.
Burntchicken is offline   Reply With Quote
Old 09-28-2013, 10:46 PM   #5
cased
Drives: 2013 CW GTI
That was actually what I was thinking.
I'll probably have to bring it somewhere to do this since I don't have the space or resources to do it where I currently live.
Thanks for the input guys, I might call a different VW dealership to see what they say, or I'll bring it to the tire place to see if they think anything of it.
Old 09-28-2013, 11:03 PM   #6
Davespence20
Davespence20's Avatar
Drives: 2011 CW GTI
Could be a warped rotor too couldn't it? But I'm thinking more along the lines of a bent rim too
-Cw-2Dr-6Mt-
-Apr Stage 2-Eurojet TBE-Carbonio 1&2-
-Airlift Slam Xl-Airlift Double Bellow Rears-Airlift Rear Struts-V2 Managment-
-Build Thread-
Davespence20 is offline   Reply With Quote
Old 09-30-2013, 01:11 AM   #7
cased
Drives: 2013 CW GTI
So I was working all weekend and haven't had time to get it checked, and while I was driving home cruising at around 65-70 I didn't notice the vibration as bad. I felt it a bit at lower speeds. Would a bent rim only cause vibrations at some speeds?
Old 09-30-2013, 12:48 PM   #8
valeoray
Drives: 2011 Golf TDI - 5 door
Check if the two bigger tire diameters out of the four wheels are put either at the front or back. I had the two bigger diameter ones on one side, and it gave me weird vibrations. VW might have rotated your tires wrong.
Euroswitch, 35% tint, Window wind deflectors, mud flaps, Clear bra, Blue vinyl rear logo, SMD LED white city bulbs, Homelink/dimming rear view mirror, VACAR LED tails, GTI front bumper, yellow tinted fogs & Nokya 2500k's, auto headlight module VagCom: emergency brake flasher, comfort windows/sunroof via remote, disabled City bulb error, disabled LED tail errors (except rear fog), enabled DRL on MFD, enabled horn on MFD on door locking, disabled license plate light cold diagnostic, coming home
valeoray is offline   Reply With Quote
Old 10-01-2013, 05:40 PM   #9
cased
Drives: 2013 CW GTI
Just picked it up, they said the road force balance numbers weren't great on it, so they redid it and said it felt better. They said drive it for a few days and let them know how it feels. Hopefully it's all better.
Old 04-20-2015, 07:52 PM   #10
mhdelano
Drives: 2010 GTI 6MT
Did you ever find out what caused or fixed the vibration? I'm having a similar issue on my car.
mhdelano is offline   Reply With Quote
