XGC75
I had an extremely tough time with the Tyrolsport Deadset Rigid Subframe Collar Kit installation. I wanted to share my story to teach would-be installers what not to do and maybe soak up some sympathy along the way. I'll do my best to keep it concise and brief.
I installed the Tyrolsport Deadset Rigid Subframe Collar Kit after removing my subframe to install a clutch. On assembly, I couldn't get one of the provided ARP bolts to thread into the frame without meeting some serious resistance. It didn't feel like it was even clearing TS's collar. I noted it had a somewhat bulbous mass on one of the threads, so I contacted Tyrolsport and they shipped out a new one as soon as business opened up on Monday. In the meantime I just reused the stock stretch bolt, torqued to spec. All is good, and I felt TS had my back for what I thought was an innocent-enough manufacturing defect in the bolt.
Bolt location #4 was the trouble child.
So 4 or 5 weeks after the clutch install I had the opportunity to replace that stock bolt with the fresh bolt shipped by TS. This time, I met the same resistance as before! The bolt was straight so I didn't suspect cross-threading. I gave it a quarter-turn to see if the resistance would let up, but it just got even harder. So I pulled the bolt out and see the threads had been stripped off. All sorts of things are going through my head but mostly I'm concerned about the threads in my frame! The stock bolt wouldn't go back in without cross-threading, no matter how hard I tried to force it into threading true. What would I do if the threads in my frame had been stripped??
From right to left: The first bolt, the second, now stripped bolt, then the stock stretch bolt that cross-threaded.
I wasn't getting anything into the frame and I wasn't driving around without a bolt holding in the subframe, so I borrowed a car for the week and contacted TS for yet another bolt. They didn't give me any troubles with this, either, which I'm thankful for. Yet I'll have to remove the subframe again to fix those threads so I wasted $130 and an afternoon away from work to get an alignment. Peachy!
That takes us to this weekend. I'd taken the subframe off and propped up the LCA. The threads in the frame were indeed damaged, but not beyond repair. I tapped the threads clean and took a few grams of metal out with the tap. I tested the new threads first with a dummy bolt (the size is M12x1.5, pretty common) and then with the new TS bolt. All's well. I re-installed the subframe leaving the trouble bolt for last. Upon threading the new bolt, I hit the SAME RESISTANCE again!!
The frame threads before cleaning:
I pull the bolt out and the threads are stripped right off. [insert rage here] This is the fourth bolt compromised by some issue I apparently haven't identified yet. Am I going another week without my car, putting miles on someone else's? Will TS even ship me another?!
Off with the subframe again. This time I notice the collar looks terrible. I think the collar must have been getting caught between the frame threads and the bolt threads. Torn pieces of the collar would get squeezed between the bolt and frame threads and generally wreak havoc on my frame. So I tapped the threads out for a second time and take out about a gram of metal. Again I test the threads and, since they hold my weight, I feel good about using them again. I don't have any good bolts to use so I ground down the first few threads of one of the ARP bolts. I installed the subframe without the troubled collar and the bolt threaded up beautifully.
Pictures wouldn't do this piece justice. It's HD so open the link in youtube and watch it full screen: http://youtu.be/Mdv9vWlSwhw
Parting thoughts. I didn't write this to denounce TS's product, I just wanted to throw out a word of caution to those installing their kit. DON'T FORCE ANYTHING. If it's not going well, suck it up and remove the collar. It's far better than what I went through and I didn't even finish with the full set installed.
tl;dr: One of the collars got caught between my frame and the bolt, stripping the bolt, frame threads and collar to pieces. Don't force anything, better to not install the collar at all if you're met with resistance during the install.
Lastly, I have a definite clunking sound from the subframe on hard bumps. I think it's the sway bar, but there's no gap between it and the subframe. Anyone experience this?
