Old 10-28-2013, 05:27 PM   #1
ali10006
Drives: Golf R 2013
Turbo upgraded
Anyone Replace Turbocharger assembly based on a new Garrett core
On the Golf R? What about the hp reache after replacing?
Any other recommendations to get 400-410hp. Without replacing the turbo K04
ali10006 is offline   Reply With Quote
Old 10-28-2013, 05:39 PM   #2
Davespence20
Davespence20's Avatar
Drives: 2011 CW GTI
Turbo upgraded
I don't know if the ko4 can produce that kinda air flow. But then again I'm no expert
-Cw-2Dr-6Mt-
-Apr Stage 2-Eurojet TBE-Carbonio 1&2-
-Airlift Slam Xl-Airlift Double Bellow Rears-Airlift Rear Struts-V2 Managment-
-Build Thread-
Davespence20 is offline   Reply With Quote
Old 10-28-2013, 05:39 PM   #3
GTiorBust
Drives: 2013 CW 2dr Man GTI
http://www.goapr.com/products/ecu_up...i_trans_r.html
looks like the highest you can go w/o turbo upg (using meth) 380hp
APR Carbonio Stage 1 // DG Springs//DSG Sigma6//UniTronic Stage 2 ECU
GTiorBust is offline   Reply With Quote
Old 10-29-2013, 12:48 AM   #4
CJ2X
CJ2X's Avatar
Drives: MKVI R, Evo IX
I wonder what kind of power is possible with an E85 setup..
CJ2X is offline   Reply With Quote
Old 10-29-2013, 09:42 AM   #5
T is for TURBO
T is for TURBO's Avatar
Drives: 2012 GTI, 1996 Eagle Talon TSi AWD
If 380 is possible on 93 pump, then 400 shouldn't be a problem with ethanol. Though I don't know if there is enough fueling capacity to run straight E-85.
Anyone know what the max airflow (lbs/min) is on the KO3 and KO4?
T is for TURBO is offline   Reply With Quote
Old 10-29-2013, 04:56 PM   #6
TooPoor
Drives: '12 DBP Golf R
DriverMotorsport has a E47 tune. Essentially a 50/50 blend. I will be trying it soon.
From their site:
TooPoor is offline   Reply With Quote
Old 10-29-2013, 05:15 PM   #7
T is for TURBO
DriverMotorsport is certainly doing some cool things over there that's for sure.
I do wish they would re-label their graphs to display "E-47" rather than "E-85". That one you posted of theirs is a little misleading.
Old 10-29-2013, 05:57 PM   #8
Jeffs2013GTI
Jeffs2013GTI's Avatar
Drives: 2013 SB GTI (Sold)
I have heard some scary stories running E85 on a DI motor. Its doable but not as reliably as say in a PI set up.
I would run a 70/30 M1, Distilled water combo should net about the same Octane Rating as E85 anyway.
Silly HP on this platform should only be done with the R. 380whp in a FWD?? Thats just silly. Good luck on the track with that.
Golf R with 380whp?? Now that would be fun. Too bad that Traction Control ruins the fun Thanks VW
Jeff
Old 10-29-2013, 07:49 PM   #9
Lucas_R
Drives: Golf R
Lots of people using the Garrett GT28 and GT30 series turbos on Golf R's now.
You are quoting 400-410hp - no doubt you mean at the engine, rather than measured at the wheels?
-K04 hybrid turbos are getting around 230-235kw/310hp at all four wheels.
- With GT28's they are getting a safe 250kw/335hp at all four wheels. This is on a stock engine and stock injectors.
-With GT30's they are around 300kw/400hp+ at all four wheels, but this power level required new rods and injectors at a minimum. You can push harder if you want, but then you start breaking things and it gets very expensive.
Note that the power figures i have quoted are on Australian dyno's, which tend to read quite a bit lower (more realistic) than American dyno's.
Lucas_R is offline   Reply With Quote
Old 10-29-2013, 07:56 PM   #10
TheMKVI
TheMKVI's Avatar
Drives: 13 GTI DE 6MT
E85 needs alot of injector. Can the stock fuel system keep up?
TheMKVI is offline   Reply With Quote
Old 10-29-2013, 10:55 PM   #11
Bozz
Bozz's Avatar
Do...you realize, that you can now turn off all of the electronic controls?
Old 10-30-2013, 12:41 AM   #12
TDR-380
Formula 2 Champion
TDR-380's Avatar
Drives: 2.0 TDI, R
Ignorance is bliss as they say right...?
2009 VW Golf VI TDI
2013 VW Golf VI .:R
Soundaktor delete
Old 10-30-2013, 01:02 AM   #13
caffeineTX
caffeineTX's Avatar
Drives: '13 | GTI 2DR | 6spd | Candy White
Jeff
you do realize you can defeat traction control in the r with vagcom
they have had this for like a year, apr even has a freeguide for it on their site
http://www.goapr.com/support/esp-defeat.html
instagram: caffeineTX
caffeineTX is offline   Reply With Quote
Old 10-30-2013, 01:18 AM   #14
CJ2X
CJ2X's Avatar
Yea, you'll probably need 1000cc and a bigger fuel pump. That's what most vehicles require..
