Old 10-31-2013, 03:49 PM   #1
///Audience
///Audience's Avatar
Drives: 2013 GTI Autobahn
Louding Hissing on acceleration
I've recently (since going stage 1+ uni) noticed a loud hissing sound upon acceleration. It seems to do it more often when the car is warmed up. I would say the sound is somewhere in between a pissed off snake and bacon sizzling. It's a smooth sound until I get to 3krpm and it starts to flutter. Once I let off the pedal, I get a loud 'whoosh' and it stops until I accelerate again.
I have a 2013 GTI w/ 2k miles. No other mods besides Unitronic tune.
Does this sound like a DV issue?
///Audience is offline   Reply With Quote
Old 10-31-2013, 04:19 PM   #2
2010_Jersey_GTi
Drives: Uni Stg 2+ MK6
its the dv doing its job. turbo spooling and the flutter is when you hit peak boost and you are actually boosting higher than requested so the oem valve bleeds some pressure to meet what the ecu is requesting which is set by the tune.
2010_Jersey_GTi is offline   Reply With Quote
Old 10-31-2013, 04:25 PM   #3
jay745
jay745's Avatar
Yeah that's normal. A lot of us like the sound >:]
Old 10-31-2013, 04:30 PM   #4
///Audience
Thanks for the info! Ive heard BOV's before (this is my first non-NA vehicle) but this sounded different. Perhaps a bit raspier than I was expecting spool up to sound like. I really want to get a boost gauge so I can make sure im not loosing pressure anywhere.
Old 10-31-2013, 04:41 PM   #5
2010_Jersey_GTi
When do you get your boost gauge, dont be alarmed that the boost will fall off the higher you go in the rpms. The turbos simply cant flow high pressures at high rpm due to their size.
So, you'll see it spike to say 19 psi, it will level out to 17-18 psi and it will gradually fall to under 10 by redline. this is normal. the larger the turbo, the longer the boost can hold in the upper rpms.
Old 10-31-2013, 04:55 PM   #6
theunholy
theunholy's Avatar
Intake?
Old 10-31-2013, 04:56 PM   #7
grambles423
Limited Activity
grambles423's Avatar
Drives: 2008.5 BMP GTI
Normal turbo sounds.
UnNaturally Aspirated
APR Stage 1- ECS Dogbone
Old 10-31-2013, 10:15 PM   #8
4DcWMk6
Drives: CW GTI
i have a 2013 stage 1+ tune ...my oem dv now leaks...which is normal for these cars with a tune... i just got a new one ...
take a look...http://www.techsmartparts.com/Smart+...e/Content.aspx
APR Stage 1 & 2 Intake : APR Stage 1 with APR Mobile : Unitronic Stage 2 DSG: H&R Coilovers
4DcWMk6 is offline   Reply With Quote
Old 10-31-2013, 10:38 PM   #9
iGTI
iGTI's Avatar
thats the sound of boost my friend
S3 16'
STG 1+ Sold
Old 10-31-2013, 10:51 PM   #10
Zonaglxy
Drives: 2011 MKVI GTI
You hittin Vtec yo.
Wrong forum I mean boost .
2011 GTI 6MT / APR K04 #66 / Neuspeed FMIC / BB Stealth TBE / Carbonio Intake / Smoked OEM R Tail lights / Neuspeed Sofsport Springs
Zonaglxy is offline   Reply With Quote
Old 10-31-2013, 10:53 PM   #11
rob618ox
Drives: 2013 GTI 4dr Black
This sound, in a long tunnel, back and forth to work daily is the highlight of my rush hour commute.
rob618ox is offline   Reply With Quote
Old 11-01-2013, 01:27 AM   #12
honda2vw
honda2vw's Avatar
Drives: 2013 VW GTI 4dr DSG with Conv/SR
sweet mother of boost
honda2vw is offline   Reply With Quote
Old 11-01-2013, 02:46 AM   #13
ClapperHighs
ClapperHighs's Avatar
Drives: Mk7 GTI RS 6MT / 1983 Porsche 944
Wastegate
APR Stage 2 : SB stage 3 Drop In : Raceland Downpipe : BSH Race Intake : Coolingmist W/M CMGS : Polar FIS : Pagparts TB Spacer : BSH TB Pipe : Nuespeed TOP : DV Relocation : APR R1 DV : BSH Torque Arm Insert : Unibrace UB : Hotchkis 27mm RSB : 034 RSB End Links : VWR SS : 42DD Shifter Bushings : Verdict Bracket Bushings : Dark Cherry LED Tails : 245 Hankook Evo2's:
ClapperHighs is offline   Reply With Quote
