Old 11-04-2013, 11:20 PM   #1
Eddy403
Eddy403's Avatar
Drives: 2013 Golf R rising blue
Boost issues on Golf R --- Potential n75 issue?
Hi guys,
Quick background info on the issue:
Had the ECU flashed with REVO stage 1, running 91oct fuel (Shell) with an APR CAI.
I didn't really feel the huge kick in the butt after switching to REVO from stock, but the tuner assured me the map was properly applied. Decided to install a boost gauge to monitor boost pressure and noticed a spike to ~19PSI and holds ~17 to redline.
I've done some 2nd and 3rd gear pulls today, attached block 118, 115, 11 (which i dont quite understand but attached anyways). Block 118, shows the N75 working at 99%, later dropping to 89% at 2,200RPM, to 40% at 4,000RPM, and back to 48% at ~5,800.
The requested/actual boost levels are close and around 2100mbar, and if converted to PSI about 16-17PSI, so the boost gauge is showing true numbers. Stage 1 boost numbers should be spiking ~22 and holding ~19
No CEL, and the fuel economy is average compared to other Golf R on fuelly.com , so the O2 sensor should be alright (haven't confirmed A/F with VCDS).
Doing a search for boost leak/ n75 failure etc returned a bunch of results, but I wanted to have somebody check out "my" logs in hopes of possibly correlating the numbers to the issue I'm having.
A video of 2nd and 3rd gear pull, vs the boost gauge
http://youtu.be/OEsvmiP_xkA
Thanks!
File Type: zip LOG-01-118-005-115 N75 3rd gear WOT.zip (16.1 KB, 82 views)
Eddy403 is offline   Reply With Quote
Old 11-05-2013, 08:23 AM   #2
lilfleck
Drives: '11 GTI Autobahn, DSG
first look at your vid appears normal. will look at logs later.
Old 11-05-2013, 08:26 AM   #3
lilfleck
you didnt include n75 vs requestest vs actual boost that i can see... i don't think you have a leak my friend.
Old 11-05-2013, 09:24 AM   #4
MKV727
Drives: 2013 Drivers Edition GTI
Looks stock to me.
MKV727 is offline   Reply With Quote
Old 11-05-2013, 09:27 AM   #5
lilfleck
Originally Posted by MKV727 View Post
Looks stock to me.
Also felt this way. Didn't want to say it, but it looks slow as balls.
Old 11-05-2013, 10:13 AM   #6
Eddy403
Eddy403's Avatar
the requested vs actual vs n75 are in the second file, columns Q and R, the N75 cycle is column E.
Looks stock to me.
It feels stock. Going to pass these logs to the tuner who has a ticket opened with REVO to take a look at the logs. Had my mk4 1.8t and a mk6 GTI running the APR tune and never had issues with boost...so the APR tune trial is sounding really appealing right now.
Last night I double checked for leaks, ran the MAF test - all seems within specs.
Old 11-06-2013, 10:55 AM   #7
Eddy403
Eddy403's Avatar
UPDATE: Went over to an APR dealer and flashed with the APR 91 map - and what a difference! Now I'm spiking 26psi, holding 22psi - the car feels like a monster!
So tune was the issue here. Not saying that all REVO Golf R tunes are terrible, but the tune I was flashed with didn't feel any different than stock.
Another happy APR customer.
Cheers!
Old 11-06-2013, 12:00 PM   #8
lilfleck
Take another video. Curious to see the difference
Old 11-06-2013, 12:06 PM   #9
MKV727
Cheers!
I'm 99% sure you never got the flash, it looked as though it was in stock mode. The data logs look identical to the stock ECU tune.
Old 11-06-2013, 05:37 PM   #10
Eddy403
Eddy403's Avatar
I thought the same, however the top speed limiter was indeed removed and I was able to rev past the stock fuel cutoff @ 6,800 RPM. So it seems as some features of the tune got applied. My only assumption is since the ECU in the Golf R is the same as in the MKV GTI....maybe...maaaaaybe the flash was for a MKV ECU? Also, tech plugged into my OBDII and double checked and made sure I was on the REVO tune as he was able to adjust the boost value from default 6 to 7.
I'll shoot another video tonight, the difference in butt dyno feels huge as expected from a k04.
2013 Golf R
Instagram: @mrvwguy
Old 11-06-2013, 07:19 PM   #11
Bozz
Bozz's Avatar
/OT cool pic Eddy403
Enjoy your mod high while it lasts!
Old 11-07-2013, 02:47 AM   #12
Hurdy
Drives: Steel Grey Golf .:R DSG
My guess would be that the flash had taken but the settings were still all stock for boost, timing and fuelling.
GOLF R
Hurdy is offline   Reply With Quote
Old 11-07-2013, 12:30 PM   #13
Eddy403
Eddy403's Avatar
Put together a short video, comparing the stock 2nd and 3rd gear pulls to the APR stage 1 tune. Once the turbo spools, the R is an entire new animal. I love the wastegate dump flutter sound while in boost. Car drives great.
http://youtu.be/jqHj3nxy4ZA
2013 Golf R
Instagram: @mrvwguy
